It begins! (Wren Prototype build log)
- allisonlastname
Re: It begins! (Wren Prototype build log)
Yet more progress! The monitor can now read intel hex records over the serial connection and verify the checksum. Combined with a "j" command that simply jumps to a location in memory, I can now theoretically load and run programs over serial.
probably the youngest person on this forum
- BigDumbDinosaur
Blasphemy!!! People have been burned at the stake for allowing Intel cruft to infiltrate 6502 machines.
Seriously, glad to see you are making good progress with this.
"65 02" in hex
(Little Endian!
- allisonlastname
I'm not fully decided on where to go next - I might write a forth, while following along to https://colorforth.github.io/POL.htm.
- allisonlastname
I'd also like to change how the monitor works a little - as is, it runs at about 8khz at full speed, which... isn't great. Unfortunately, with my current setup, I can't run the clock any faster (say, by using the AVR's timer to output a square wave on a pin) because I need to check the bus every cycle to perform serial operations. I can deal with it for now, but I'd like to have a proper freestanding UART at some point.
- BigDumbDinosaur
As I’ve often said when someone tries to do roll-your-own TIA-232 communication, there is a reason UARTs were invented.
BTW, you might want to look at the AVR’s data sheet before using it as a clock source. WDC MPUs’ clock requirements demand a full CMOS signal with a rise/fall time not to exceed 5ns. While you can fudge that to some extent, it becomes a question of how stable do you want it.
- allisonlastname
Looks like my earlier maths was completely off, because I just doubled the AVR's clock speed (from 4mhz to 8mhz) and now it's clocking the 6502 at about 330khz. That's a much more acceptable speed, so I think I'll leave the monitor as it is for a while.
- allisonlastname
No, I was just being stupid and forgot to reset the monitor before testing the speed. It seems closer to 60khz, which is still way better than 8.
And if I remove some unnecessary sleeps in the code, I can get it all the way up to 100khz. Result!
- allisonlastname
I think my next goal will be talking to a character LCD I have (HD44780, of course). I'm currently thinking of using the 4-bit interface to save on IO pins.
- GARTHWILSON
- Forum Moderator
They have built-in fonts, graphic mode, come in sizes up to 240x128 (40*16 chars) and work at up to 5 MHz (5 times faster than HD44780). This allows them to be put directly on CPU bus without having to bit-bang (alternatively, you can use clock stretching circuits for slow LCDs - there have been some recent posts on this topic by gfoot, Jeff & myself over the past month). My Deck65 SBC uses one (240*64, 40*8 chars).
/Andrew
- allisonlastname
Looking at it, I might just put it on the bus and use it in 8 bit mode. I only have one VIA, and port B is already reserved for SPI data in.
However I do it, physically connecting it will be very awkward, because the module I have just has an 8*2 pin header on, which I'm connecting to by jamming jumper wires into the other end of a ribbon cable. Some day I'll make a proper breakout for it, but today is not that day.
- allisonlastname
And now the RAM has somehow exploded. This basically kills the computer because (as already mentioned earlier in the thread) the 62256s I have don't play nicely with the 6502 for whatever reason, and the 43256 worked for some reason.
- GARTHWILSON
- Forum Moderator
allisonlastname, without digging back through earlier posts of yours, I don't remember if you've been through the 6502 primer. It shows using a 62256 SRAM and also how you can multiplex pins on the 6522 for putting loads of things on a single 6522.
