It is currently Sat Nov 23, 2024 3:39 pm
Post new topic Reply to topic  [ 118 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
PostPosted: Sat Nov 25, 2023 4:55 pm
Yet more progress! The monitor can now read intel hex records over the serial connection and verify the checksum. Combined with a "j" command that simply jumps to a location in memory, I can now theoretically load and run programs over serial.
probably the youngest person on this forum
PostPosted: Sat Nov 25, 2023 6:20 pm
Excellent... Now, I have this TinyBasic you might want to play with ;-)
PostPosted: Sat Nov 25, 2023 7:14 pm
Blasphemy!!!  People have been burned at the stake for allowing Intel cruft to infiltrate 6502 machines. :D
Seriously, glad to see you are making good progress with this.
PostPosted: Sun Nov 26, 2023 4:35 am
"65 02" in hex
Hm, but shouldn't it be "02 65"?
(Little Endian! :mrgreen: )
You are technically correct. The best kind of correct.
PostPosted: Sun Nov 26, 2023 9:57 am
It's happened surprisingly quickly - I expected writing the monitor to take hours and hours of debugging and poring over hex dumps, but it was pretty painless. In fact, the biggest error I found was with the code running on the AVR, not the 6502.
I'm not fully decided on where to go next - I might write a forth, while following along to https://colorforth.github.io/POL.htm.
PostPosted: Sun Nov 26, 2023 3:08 pm
I'd also like to change how the monitor works a little - as is, it runs at about 8khz at full speed, which... isn't great. Unfortunately, with my current setup, I can't run the clock any faster (say, by using the AVR's timer to output a square wave on a pin) because I need to check the bus every cycle to perform serial operations. I can deal with it for now, but I'd like to have a proper freestanding UART at some point.
PostPosted: Sun Nov 26, 2023 5:21 pm
As I’ve often said when someone tries to do roll-your-own TIA-232 communication, there is a reason UARTs were invented.  :D
BTW, you might want to look at the AVR’s data sheet before using it as a clock source.  WDC MPUs’ clock requirements demand a full CMOS signal with a rise/fall time not to exceed 5ns.  While you can fudge that to some extent, it becomes a question of how stable do you want it.
PostPosted: Sun Nov 26, 2023 11:24 pm
Looks like my earlier maths was completely off, because I just doubled the AVR's clock speed (from 4mhz to 8mhz) and now it's clocking the 6502 at about 330khz. That's a much more acceptable speed, so I think I'll leave the monitor as it is for a while.
PostPosted: Sun Nov 26, 2023 11:29 pm
No, I was just being stupid and forgot to reset the monitor before testing the speed. It seems closer to 60khz, which is still way better than 8.
And if I remove some unnecessary sleeps in the code, I can get it all the way up to 100khz. Result!
PostPosted: Tue Nov 28, 2023 12:44 am
I think my next goal will be talking to a character LCD I have (HD44780, of course). I'm currently thinking of using the 4-bit interface to save on IO pins.
PostPosted: Tue Nov 28, 2023 1:24 am
See the sample LCD driver code at http://wilsonminesco.com/6502primer/LCDcode.asm in several forms, including for the 4-bit interface, linked in the 6502 primer.
PostPosted: Tue Nov 28, 2023 1:55 am
FYI - there are some really nice T6963C-based displays as well (most modern versions come with UCI6963, which is compatible with T6963C). You might need to cut some jumpers though to select a proper font, those are usually marked on display's PCB.
They have built-in fonts, graphic mode, come in sizes up to 240x128 (40*16 chars) and work at up to 5 MHz (5 times faster than HD44780). This allows them to be put directly on CPU bus without having to bit-bang (alternatively, you can use clock stretching circuits for slow LCDs - there have been some recent posts on this topic by gfoot, Jeff & myself over the past month). My Deck65 SBC uses one (240*64, 40*8 chars).
/Andrew
PostPosted: Tue Nov 28, 2023 5:49 pm
Looking at it, I might just put it on the bus and use it in 8 bit mode. I only have one VIA, and port B is already reserved for SPI data in.
However I do it, physically connecting it will be very awkward, because the module I have just has an 8*2 pin header on, which I'm connecting to by jamming jumper wires into the other end of a ribbon cable. Some day I'll make a proper breakout for it, but today is not that day.
PostPosted: Wed Nov 29, 2023 1:02 am
And now the RAM has somehow exploded. This basically kills the computer because (as already mentioned earlier in the thread) the 62256s I have don't play nicely with the 6502 for whatever reason, and the 43256 worked for some reason.
PostPosted: Wed Nov 29, 2023 2:49 am
allisonlastname, without digging back through earlier posts of yours, I don't remember if you've been through the 6502 primer.  It shows using a 62256 SRAM and also how you can multiplex pins on the 6522 for putting loads of things on a single 6522.
Users browsing this forum: DRG and 29 guests
