Speeding up the 65C02
ElEctric_EyE
I didn't realize it at the time, but this is where (as far as this thread is concerned) address decoding met a fork in the road. Refresh here: viewtopic.php?t=1503&postdays=0&postorder=asc&start=33 .
Does one use Phase 2 with address lines(A0-A15) or Phase 2 with R/W to qualify a valid memory access? I bring it up now because there's a link to schematics of older arcade machines here: ( viewtopic.php?t=1609&postdays=0&postorder=asc&start=7 )...
I was young in the days of the original Vic-20/C-64. I had a friend. His father and mine worked at SSS (Solid State Scientific, now Allegro), both EE's. We were always exchanging ideas... Anyway, I see now where I/we got the idea to use Phase 2 with Address decoding and it has persisted to this day...
The original (version e) Vic-20 schematic uses A0-A15 & Phase 2 to qualify memory decoding.
Compare to Battlezone for example. Focus on A0-A15, Phase 2 & R/W...
Most of the arcade games were based on 80XX/Z80, some 68K, and yet a few on 6502/A. ALL of the PRO's (i.e Atari, etc.) incorporating 6502's, did in fact qualify R/W with Phase 2.
Edit: links, weak links edited out
I think it depends on the needs of the bus.
The 6502 is perfectly happy qualifying R/W with PH2, providing you don't have any other peripherals using the bus during PH1.
The 65816 isn't so nice about this, regrettably, since A16-A23 is only available during PH1. Hence, your address isn't complete until PH2, and all address decoding must be done during PH2 if you intend to use more than 64K of address space.
- BigDumbDinosaur
in my POC design, I don't use A16-A23, but I have carefully studied the relationship of A0-A15 relative to Ø2 and can see (on my dual trace scope) that the address bus is valid well before Ø2 goes high.
I'd disagree with that. The '816 timing diagram (page 29 in the data sheet) clearly shows that a full address is valid before the rise of Ø2.
- BigDumbDinosaur
I plan in the next iteration to generalize the VDA/VPA qualification to all hardware, although testing with the current design doesn't indicate there's any particular problem in that regard with RAM and ROM access. BTW, when both of these signals are high, they reflect what SYNC means on the 65C02, making it possible to set up single step circuitry if desired.
Another signal I'm going to play around with is *ABORT. Owing to the way the MPU behaves in response to *ABORT, I believe it should be possible to implement hardware-based memory protection.
Re: Speeding up the 65C02
See http://www.6502.org/users/andre/csa/auxcpu/index.html I'm still pretty proud that this one worked in a 1.0 version :-)
André
- BigDumbDinosaur
André
André
- BigDumbDinosaur
Lattice PLDs
8BIT wrote:
The Lattice brand GAL's program fine in my programmer.
Mouser has 10ns, 24 pin GAL22V10D PDIP's for $5.50
Part # is 842-GAL22V10D10LPN
- GARTHWILSON
- Forum Moderator
Regarding the fear that the addressed device's output data will disappear too soon for the processor to read it after it is disabled when φ2 went down, I wrote:
In testing my tester for the 4Mx8 10ns 5V SRAM module a couple of weeks ago (data sheet available here), I found, by accident, that the bus capacitance held the data reliably for over a millisecond (a million nanoseconds) in the absense of anything driving the bus. I did not experiment to find out how much longer it could go, like a whole second or what. Anyway, it definitely was not collapsing after 10ns, or even 10µs.
http://WilsonMinesCo.com/
For one, his glue logic takes most of that 10ns, and for another, bus capacitance will easily hold the data for the rest of the time, as nothing else is driving the data bus yet. The small CMOS leakage along with the capacitive loading on the lines would hold the logic state for a good dozen microseconds (and possibly much longer) if you were to stop the clock immediately after phase 2 goes down.
- BigDumbDinosaur
Bumping Somewhat Dormant Topic
http://wilsonminesco.com
- GARTHWILSON
- Forum Moderator
Yes, but where is the bulk of this bus capacitance coming from, the memory module itself or the test rig?
- BigDumbDinosaur
Something to think about is this: Garth's memory module has 4 Mb x 8 of RAM. A maximized 65C816 system in which A16-A23 is selected via the MPU's multiplexed bank address can use 16 MB, which would require the installation of four modules. Ergo capacitive bus loading will increase by at least a factor of 4, most likely more due to the added length of the motherboard address and data bus traces needed to connect the sockets. The module uses Cypress CY7C1049D DRAMs, each of which has an 8 pf loading spec—Cypress doesn't state if this number varies when the device is selected. There are eight SRAMs per module, so aggregate loading of a maximized system of four modules would be 256 pf. Would the '816 even be able to drive that loading, regardless of the Ø2 rate?
- GARTHWILSON
- Forum Moderator
Re: Bumping Somewhat Dormant Topic
it would be interesting to see how much bus capacitance would vanish with an edge-connected PCB. All those pins in close proximity to each other have to be adding mucho capacitance
(plus a wee bit of inductance).
As I mentioned in another post, the industry got away from SIP memory modules many years ago. While the lower cost of edge-connected PCBs had to have been a significant factor in this change, reduced stray capacitance was probably considered as well, especially as memory speeds were being jacked up.
Daryl had no trouble running it at 12MHz with a barefoot '816 (ie, no bus trasceivers), driving this module and three daughter boards at the same time, which I was pleased to hear.
Edit: More info on measured capacitance of the board and connectors at viewtopic.php?f=4&t=2172&start=6 . (Take the "&start=6" off the end to see the posts leading up to it.
