Page 5 of 9
Posted: Mon Nov 22, 2010 7:58 pm
I've had another look at Dr Naohiko Shimizu's 6502 (and a quick mail exchange with him: I'll call him Naohiko from now. He's a long time 6502 fan and is now aware of this site and this thread.)
Recall that he uses a high level language called SFL (the idea is higher productivity, and he wrote the 6502 core in a week.)
Overtone supplies the SFL tools. For my purposes, a free 30-day
non-profit license is enough...
The
high-level sources - in SFL - are about 1100 lines, which compares favourably with Arlet's 1200 lines of verilog and retromaster's 2100 lines of VHDL. This high-level description is translated to about 2000 lines of low-level synthesisable verilog.
The synthesis results compare against those other two cores like this:
flops slices LUTs RAM16 HDL Notes
A2601 138 467 840 0 vhdl by retromaster
m65 119 452 873 0 sfl by Naohiko Shimizu (O2 mode)
m65 122 549 1058 0 sfl by Naohiko Shimizu (default mode)
cpu.v 155 276 474 8 verilog by Arlet Ottens (not today's version!)
Because the synthesiser sees only the low level verilog, no adders or similar operators were found:
Macro Statistics
# Registers : 36
1-bit register : 25
3-bit register : 1
8-bit register : 10
Macro Statistics
# Registers : 108
Flip-Flops : 108
Note that the speed optimisation then replicates a few of the state bits, which takes us up to 122. The speed is reported as 31MHz (or 38MHz for the O2 version) (again, this is not a carefully constrained synthesis.)
ps. Naohiko has presented various retro FPGA projects:
PDP/11, Space Invaders,
Apple 1, using his high level languages. See slides from
ICCD 2009 and from
ASEAN 2003
Posted: Tue May 24, 2011 8:11 pm
by Arlet
Using ISE 12.4, and pushing the synthesis a little (high effort, optmize for timing), I can get my Atom model (6502 CPU + RAM/ROM/PIA/VDG) to pass synthesis with a 14ns clock:
All constraints were met.
Data Sheet report:
All values displayed in nanoseconds (ns)
clk | 13.893
This is on a Spartan-3 (XC3S200-5FT256). On a Spartan-6, I get a synthesis estimate of 111 MHz. Mapping fails due to bad pin constraints (I just used the Spartan-3 constraints file).
Posted: Tue May 24, 2011 8:30 pm
I notice in some of my experiments that the post-placement timing is sometimes a bit faster than the post-synthesis timing.
a 100MHz atom is quite something!
by ElEctric_EyE
...On a Spartan-6, I get a synthesis estimate of 111 MHz. Mapping fails due to bad pin constraints (I just used the Spartan-3 constraints file).
Nice, no BCD mode?
Posted: Tue May 24, 2011 8:33 pm
by Arlet
Yeah, too bad I don't have a Spartan-6 board.... Digilent has one, but it's $349, which is a bit on the high side.
by Arlet
No BCD mode. I used an old project dir, with the pre-BCD/pre-RDY core in it.
Posted: Tue May 24, 2011 9:38 pm
by fachat
I'm really looking forward to how my 65k core compares, although I think, as a first-timer and writing a complete new core, with extra functionality, this will be much bigger. But it's generic, configurable to 16, 32 or 64 bit registers and a maximum memory interface of 8, 16, or 32 bit, so I could at least try to compare the 16bit registers/8bit memory interface with the numbers here. Maybe I should add a switch to switch off the extra opcodes and registers, just for comparison...
BTW: current status is that I have almost finished writing the fetch/decode logic - which is quite complex (I think this is the most complex part in my design actually) as I do prefix bytes, but it _should_ support decoding one opcode per cycle as long as memory bandwidth permits (so I should be able to break the one opcode / at least two cycles limit of the 6502 :-) It's untested as of now, though.
André
Posted: Mon May 30, 2011 11:57 am
As discussed privately, there are some less expensive options: I've posted to the
FPGA dev board thread.
Posted: Fri Nov 04, 2011 10:17 am
To follow up on
this old observation
... Arlet's is the only design which uses LUTs as 16-bit RAMs - this could be a reason why the slice count is by far the smallest.
I just ran a couple of runs with two versions of
Arlet's core, one of which avoids using RAMs for the register file. The size difference is there, but not enormous. This is with version 12.4 of the xilinx tools, targetting a xc3s50a-5-tq144:
flops slices LUTs RAM16 MHz
6502 153 247 468 8 83.3
189 265 501 81.5
65Org16 202 360 681 16 78.2
271 389 737 76.3
(Note - I also disabled BCD for these runs)
Edit: updated with post-synthesis speed. This is an unconstrained synthesis with default tactics.
Posted: Fri Nov 04, 2011 10:46 am
by Arlet
Any difference in speed ? Can you show the code ? I'm curious how you implemented it.
Posted: Fri Nov 04, 2011 11:57 am
I've updated the table with speeds - the RAM approach is just a little faster.
Here's the code - I dug it up from some old emails:
* write to a register. Usually this is the (BCD corrected) output of the
* ALU, but in case of the JSR0 we use the S register to temporarily store
* the PCL. This is possible, because the S register itself is stored in
* the ALU during those cycles.
always @(posedge clk)
if( write_register & RDY )
// this version will get us a RAM - denser!
AXYS[regsel] <= (state == JSR0) ? DIMUX : { ADD[dw-1:4] + ADJH, ADD[3:0] + ADJL };
//case( state )
// JSR0: AXYS[regsel] <= DIMUX;
// default : AXYS[regsel] <= { ADD[dw-1:4] + ADJH, ADD[3:0] + ADJL };
//endcase
Posted: Fri Nov 04, 2011 12:10 pm
by Arlet
So, you only changed the code a little bit with that case statement, so it didn't recognize the RAM anymore.
I was thinking that instead of the register array, indexed by 'regsel', it's possible to use the register more directly by rewriting some of the code. For instance, when doing stack operations, the S register can be sent directly to the address bus, instead of going through the AXYS[] array. This may be a little faster (at the cost of more logic).
Posted: Fri Nov 04, 2011 1:41 pm
Actually, both versions are your code, from this time last year (private emails)! We did discover at that time how fragile (or robust) the RAM-recognition was.
I see what you mean - the S value from the ALU could be routed to the Address pins. I think I have never looked carefully at the timing reports, to see where the critical path is. I did determine that synthesis tactics could make quite a difference to speed.
Posted: Fri Nov 04, 2011 2:11 pm
by Arlet
It would be interesting to see what would happen if the design was changed from the current one, which mimics the way the original 6502 used the ALU to do everything, to one where the registers are separated, and combined with some logic. So, you could have an X-register unit that was capable of holding the value, but also incrementing and decrementing it. That way you could implement INX and DEX without going through the ALU.
This could still be done at the same number of cycles, but you could also choose to deviate from the original 6502 instruction times, and try to make it faster. In theory, you should be able to do INX and DEX in 1 cycle, for instance.
Posted: Fri Nov 04, 2011 5:59 pm
Single cycle instructions? I always thought that would mean major rework - be interesting to see it though! And we know the 65CE02 managed it. In an FPGA fabric, an incrementer local to the register might well be efficient. It would presumably simplify push and pop type operations.
