Generating Video Signals
jmthompson
Re: Generating Video Signals
Post by jmthompson »
cbmeeks wrote:
jmthompson wrote:
It outputs a 640x480 60 MHz signal,
Great work. But I think you mean 60 Hz. :-D
Haha yes, 60 Hz. :)
I've also almost got the RAM sharing working; since I only need pixel data at most every 40 ns, and I've got 15 ns RAM, I've updated the design to basically behave as a 128Kx8 SRAM with a 40ns access time. VGA data is fetched on rising clock edges and CPU R/W cycles are executed on the falling edges. 40ns should be good enough for a CPU up to 12 MHz or so if my math is correct.
