Project: Digital Fuel Injector Pulse Width Analyzer
ElEctric_EyE
Found a 320x240 LCD display made by New Haven that has a familiar 6500 style data bus interface for $130.
Still looking for others...
http://www.mouser.com/Search/Refine.asp ... 40WG-BOSFK
OOOH. TFT LCD color, same 8 bit interface, 65K colors for around same price! And you can order direct from them online.
http://www.newhavendisplay.com/index.ph ... ts_id=1900
- GARTHWILSON
- Forum Moderator
- GARTHWILSON
- Forum Moderator
I've seen the 28-pin green Textool and Textool(like) ZIF sockets on Mouser for $15 each. Now I would have thought this was THE most expensive until I saw some ARIES ZIF sockets. Even more expensive. About 2x the cost at $30 each, but it is a non-stocked item at Mouser.
I feel pretty confident about the memory and adressing logic and timing.
I need a very simple video interface, old school 6545 video IC's I understand. SPI is totally foreign to me, but it seems like it's the norm for displays nowadays. Should I commit to learning the SPI interface? Would it be fast enough to display 8-bit data acquired <5MHz?
The 65SIB (serial interface bus) we've been talking about in other topics is just a way to connect a string of up to seven external SPI (and similar) devices in kind of a daisy chain, with a single pin-header ribbon connector on the controller and two on each device. It's primarily a definition of the connector to make peripheral designs and hardware somewhat portable between forum members. The main limitation to speed will usually be the 6502/816 master, and otherwise the individual devices and line length. The order of the wires in the connector ribbon is specifically arranged for good transmission over the ribbon cable. (Every signal line is next to a ground or virtual ground line.) 65SIB carries power too, so projects that don't use a ton of current won't need their own source of power (although they will need an onboard regulator). Interrupts are supported. 65SIB is not really 65-family-specific, just a 6502.org project. It was intentionally designed so a single port on the master could simultaneously accommodate a wide range of serial ICs from SPI to Microwire to 74HCxxx dumb shift registers for I/O, but also allow autoconfiguration of custom intelligent devices without putting the intelligence requirement on all devices. Non-intelligent ones simply won't respond to or be affected by autoconfiguration-type operations. The seven-device limitation can be exceeded by adding intelligent hubs. 65SIB is very simple to get basic operation from, but also allows much more sophisticated operations for those who want to delve into it that far. I need to write up a spec. sheet for the basics to post on this site, and kc5tja will be developing the autoconfiguration protocol when he has hardware to debug it. (That's my understanding anyway.) At this point the only thing here to refer to is the forum topic where we developed it, which is a lot to read through even if you only read the last half. I was also thinking about making some PC boards available to speed up the construction at the connectors and make them more suitable for fast slew rates.
As for video, There are some graphics LCDs with SPI, and you might even find ones with built-in controllers to take certain commands to for example draw vectors, arcs, etc. without your main processor having to figure out which dots to turn on. Most intelligent modules can do the text (so you just tell it where to start and what to write and it figures out the rest), but the graphics commands would be beyond that.
Other popular, inexpensive synchronous serial interfaces: (Note: even though one company or another started a particular interface, there are many companies that make devices for it. For example, SPI is Motorola's baby, but lots of companies make SPI parts.)
Microwire is National Semiconductor's baby and is very similar to SPI.
I²C is Philips' baby. It uses only two signal lines, one for clock and one for data. Both are bi-directional, so you can even have more than one master, and they can arbitrate who gets control of the bus. Instead of having an individual select line for each device, every transaction starts with an address, and all devices listen for their address and respond only if it is called. Having only two wires makes for even a lot less wiring work than SPI, but its passive pull-up requirement on bi-directional lines and its open-drain outputs put quite a lid on the speed compared to SPI. (400kbits/second is a common limit.) There are two-wire interfaces that are not particularly called I²C but are still the same thing.
1-Wire is Dallas' baby and is even slower than I²C (but taking it too far, if you ask me). It's a little more complex since the one wire handles bidirectional clock and data, telling the difference through timing requirements, so I think you have to really hate wires to drop from I²C or other two-wire interface (TWI) down to 1-Wire! It is more appropriate for slow things like a temperature sensor. Sometimes power is on the one wire too.
SMBus is basically I²C with time-out limits on devices that can tell the controller to wait because they're not ready to take more data yet. (Many I²C devices don't support that clock-stretching "wait" feature anyway, so although I've never used SMBus, I expect that for a lot of applications there would be no difference between SMBus and I²C.)
There are good Wikipedia write-ups on these.
Nightmaretony
- In Memoriam
- GARTHWILSON
- Forum Moderator
ElEctric_EyE
Are you guys talking about an interface to a TFT/LCD? An interface between a 6502 (i.e. 8 bit parallel data) and straight 18bit RGB? That's what I would really like to see... I would be looking at a 640x480 display if this is so.
The data sheet on my earlier post is confusing me. I see data but no address lines. How are the registers accessed?
Here's their link again:
http://www.newhavendisplay.com/specs/NH ... _8-bit.pdf
For video, a CPLD with RAM base is a good way to go.
It has built-in decoding for a 65816 processor's upper address bus, up to 512k, which allows the programs to reside in the first 64k block, and graphics above.
I had thought about modifying it to drive an LCD directly, vs. providing composite video, but I just don't have enough time to start it.
- GARTHWILSON
- Forum Moderator
ElEctric_EyE, I think you'll be interested in the video discussion at viewtopic.php?t=28 , especially the last part starting after the middle of page 8.
ElEctric_EyE
I read all of it thanks for digging that up for me. Noone seemed to reply to your investigation which is pretty much where I am starting at. I am only interested in a TFT display that has a built in 8 bit controller. Now the display I am interested in has a controller with part #FSA506. If I could find the datasheet for it I am sure I could understand how to communicate with it. But looking at other forums people are having similar problems, as noone can find out where the datasheet is. Someone said it is made by Microchip. So I am still looking...
Came across another company called ampdisplay making the identical product using the same controller. Their datasheet explains abit more...
http://www.ampdisplay.com/pdf/tft/ADI_5 ... 20ver,.pdf
Ah sweet, here is the controller:
http://www.ampdisplay.com/pdf/tft/ADI_F ... _Board.pdf
ElEctric_EyE
Have you checked the bus loading? I haven't looked up the data on the 74F stuff, but it looks to me like you have an awfully heavy bus load.
It may develop into a multiprocessor system, where 1 CPU will have full control over each 16 bit counter section and I won't have to worry about that aspect. It may be overkill, but I don't know yet... I still have yet to do some wirewrapping. Also from initial calculations, for a pulse width of 100ms and 16-bit resolution, gets me into a clock frequency of close to 2MHz, well in the range of HC/T...
Which brings me to something else I have been thinking about. The 65C02 has a SOB (Set Overflow Bit) pin for setting a status register bit which I think would be useful when connected to the /TC (Terminal Count). If I could have a CPU controlled oscillator, I could max the resolution by lowering the frequency just abit each time /TC was triggered. But I need a high resolution frequency divider. Any suggestions?
As of now I have all my IC's, vectorboard, EEPROM Programmer. 500ft spool of 30AWG wire, and wire wrap sockets are due here on 4/3. A wire strip tool, called the "stripmaster" for $30 from mytoolstore.com is due here on 4/7. I hope this tool is worth it. I've seen it being sold for over $100 on many sites. One other site was selling it for $40.
http://www.mytoolstore.com/ideal/ide11-24.html
http://www.hmcelectronics.com/cgi-bin/s ... xgodtnpnuw
ElEctric_EyE
Programmable frequency generator
Forget the divider, I am thinking of going with a 74s124 VCO, and an 8 bit D/A to control the Injector counter frequency. Also a set voltage will be used for the O2in signal for the 65c02 on the other 1/2 of the 74s124.
Here's a block diagram and physical layout (-therelay and display). Expect this diagram to change... I changed it 4 times already.
6502.org wrote:
Image no longer available: http://i207.photobucket.com/albums/bb73/ultimateroadwarrior/BlockDiagram.jpg
6502.org wrote:
Image no longer available: http://i207.photobucket.com/albums/bb73/ultimateroadwarrior/Final.jpg
- GARTHWILSON
- Forum Moderator
ElEctric_EyE
...I deleted what I wrote here last night, I was up too late and I was a ramblin'... So I will just post a pic of my new baby I got from ebay. The manual was written in '91 so I am assuming the unit is 18 years old as well. It was calibrated in '08, military surplus, and seems to be in excellent condition.
6502.org wrote:
Image no longer available: http://i207.photobucket.com/albums/bb73/ultimateroadwarrior/DSCF0003.jpg
