Working SBC-3
Topics related to the SBC- series of printed circuit boards, designed by Daryl Rictor and popular with many 6502.org visitors.
8BIT
Re: Heat Sink
Post by 8BIT »
RichLeary wrote:
All,
One tip I meant to post when I first finished by SBC3 was one regarding the heatsink. I mounted mine so the fins were on the outside of the board. That eliminated any conflict with the caps and might actually improve cooling air flow.
That does restrict mounting but since the power plug sticks out on the same side it did not seem like a big restriction.
Rich
To clarify, this is the voltage regulator heatsink, not the 95108's. You can also leave the leads on the regulator long, so it sits high enough over the caps that the heatsink can be mounted with fins inward.
Either way will work well.
RichLeary
Keyboard
Post by RichLeary »
Daryl,
I'll run some tests. I'll try my fourth keyboard first.
Thanks for the tips!!
Rich
Rich Leary
RichLeary
Heat Sink
Post by RichLeary »
Daryl,
You are absolutely correct and I should have made it clear I was talking about the voltage regulator heat sink.
Rich
Rich Leary
