It is currently Fri Nov 22, 2024 8:55 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: Heat Sink
PostPosted: Fri Apr 03, 2009 10:26 pm
RichLeary wrote:
All,
One tip I meant to post when I first finished by SBC3 was one regarding the heatsink. I mounted mine so the fins were on the outside of the board. That eliminated any conflict with the caps and might actually improve cooling air flow.
That does restrict mounting but since the power plug sticks out on the same side it did not seem like a big restriction.
Rich
To clarify, this is the voltage regulator heatsink, not the 95108's. You can also leave the leads on the regulator long, so it sits high enough over the caps that the heatsink can be mounted with fins inward.
Either way will work well.
 Post subject: Keyboard
PostPosted: Fri Apr 03, 2009 11:07 pm
Daryl,
I'll run some tests. I'll try my fourth keyboard first.
Thanks for the tips!!
Rich
Rich Leary
 Post subject: Heat Sink
PostPosted: Fri Apr 03, 2009 11:09 pm
Daryl,
You are absolutely correct and I should have made it clear I was talking about the voltage regulator heat sink.
Rich[/quote]
Rich Leary
