Page 3 of 4
Re: WDC02CC Compiler
Posted: Tue Apr 20, 2021 10:05 pm
Druzyek wrote:
vbc wrote:
tokafondo wrote:
What would be a fair set of tests that could be created to make a comparison between 65xx C compilers?
Well, that is a non-trivial area of science, basically. And it is made harder by the fact that the existing 6502 compilers do vary quite a lot regarding their goals/capabilities, and quite a lot of existing C code does not work on 6502. So, clearly not an easy task, but IMHO at least you should either use code that has not been written/pre-selected with any specific compiler in mind, or it should be adapted/optimized equally for all compilers.
Another way to go about it is to write the type of code you are actually going to be using the compilers for. You may not actually care if a particular compiler is better at doing something you don't need it to do.
And for the truly insane, one could disassemble and examine the code emitted by the compiler and see just how sloppy it might be. :D
The WDC C compiler (at least the 65C816 version) that I played with some years ago seemed to generate reasonably succinct code, although nowhere near what a good assembly language programmer could produce. Of course, compiling C for the 65C816 is "easier" than for the 65C02, since the former has more addressing modes, including stack-relative, as well as the very useful ability to relocate direct (zero) page. such as to the stack.
Posted: Tue Apr 20, 2021 10:43 pm
by tokafondo
I though that there was a set of standard functions like Mandelbrot calculations, or sorting algorythms, or things like that, that could be programmed in a standard C code, not specific to an architecture or compiler. And then fed to the compilers to see what code they do spit out.
I mean...
10 PRINT "HELLO, WORLD!"
20 GOTO 10
Is almost universally understood by every BASIC out there, but when compiled to machine code, there are differences between not only architectures but also compilers, aren't them?
Posted: Wed Apr 21, 2021 4:59 am
by Agumander
Well, I did spend my evening implementing Tetris for my system in C. I didn't consciously do anything to tailor it to the WDC compiler so it might be a good candidate to see how easily I can build the same code with cc65 or vbcc.
Posted: Wed Apr 21, 2021 6:07 am
by BillG
Mandelbrot was discussed here: viewtopic.php?f=1&t=6323
The result is tied too much to output speed.
There was fib and tarai, thought not everyone wants or needs recursion: viewtopic.php?p=78840#p78840
tokafondo wrote:
I mean...
20 GOTO 10
My BASIC compiler generates this:
                          00277          ifdef  __INIT
                          00278          jsr    InitRTL   ; Initialize run-time environment
                          00279          endif
                          00280
 0B06 20 0224         [6] 00281          jsr    NewLine
                          00282
                          00283 ; 10 PRINT "HELLO, WORLD!"
 0B09                     00284 L00010:
                          00285          ifdef  __TRACE
                          00286          ldx    #<10
                          00287          lda    #>10
                          00288          jsr    Trace
                          00289          endif
                          00290
 0B09 A2 A3           [2] 00291          ldx    #<S00000
 0B0B A9 0B           [2] 00292          lda    #>S00000
 0B0D 20 0B6E         [6] 00293          jsr    PStr
                          00294
 0B10 20 0224         [6] 00295          jsr    NewLine
                          00296
                          00297 ; 20 GOTO 10
 0B13                     00298 L00020:
                          00299          ifdef  __TRACE
                          00300          ldx    #<20
                          00301          lda    #>20
                          00302          jsr    Trace
                          00303          endif
                          00304
 0B13 4C 0B09         [3] 00305          jmp    L00010
                          00306
 0B16                     00307 End_
The total binary file size is under 200 bytes.
Posted: Wed Apr 21, 2021 11:06 am
by vbc
Yes, I have seen 6502 C benchmarks using mandelbrot, md5, or dhrystones. However, those are very small and the results are often dominated by the implmentation of a single feature or optimization. E.g. a mandelbrot calculation on the 6502 will mainly test the math libraries used. The dhrystone benchmark was intended to test a mixture of features considered typical use at that time. However, with modern compilers, it emphasizes a few specific optimizations that have far less impact in practice. So you may get hugely varying results using only one or two small tests.
So, if a comprehensive test suite is required, you probably want more and bigger tests. Those, however, are more likely to not work out of the box with all 6502 compilers due to different limitations of either the 6502 or the compilers. So you may have to pick and adapt, i.e. some work.
As another poster mentioned, if you are just choosing a compiler for your project, the best option probably is to test some of that code.
20 GOTO 10
Yes, but that test will probably not be a good indication of how the compilers will translate e.g. a mandelbrot calculation.
Posted: Wed Apr 21, 2021 5:37 pm
by tokafondo
This
20 GOTO 10
was used to make a point, not to be taken as a real compiler test. :) :) :)
I'm reading comments about how to write code tailored for this or that compiler, and what I'm talking about is to create code that would stick to standard C (hence the BASIC example), and then leave up to the compilers how to make assembler from it.
That's why I talked about standard operations like the Mandelbrot stuff, or sorting stuff, or working with arrays... you name it! Those operations would be written in the most standard C (instead of tailored for cc65, vbc, WDC, or what ever) and fed to the compilers.
Then, things like code size and time of the operations the code is written to do would help to know which compiler is best in overall or in certain areas.
Posted: Wed Apr 21, 2021 5:47 pm
Compiler tests which spring to mind, all of which seem to have the property of creating an executable with some kind of function:
- compile a Basic or Logo interpreter
- compile a screen editor
- compile a program like Xmodem
- compile a FAT filesystem
- compile a TCP/IP stack
- compile a compiler
But of course, just blinking an LED or reading a temperature sensor are also in there. Something you might want to do with your '02 system.
All of these things have in common a need to perform I/O, which is going to be somewhat platform-specific.
Edit: I seem to be answering the question "Is this compiler useful" rather than "Which compiler is best" and I think I'm happy with that.
Posted: Thu Apr 22, 2021 1:10 am
by BillG
Here is someone who is comparing compilers...
https://bestofcpp.com/repo/sgadrat-6502-compilers-bench
Posted: Thu Apr 22, 2021 1:12 am
by BillG
Guilty as charged...
viewtopic.php?p=79347#p79347
Posted: Thu Apr 22, 2021 3:43 pm
by enso
..And for the truly insane, one could disassemble and examine the code emitted by the compiler and see just how sloppy it might be. :D
Uh-oh. It is true, then...
Posted: Thu Apr 22, 2021 11:47 pm
by Agumander
Has anybody else had the WDC compiler just crash when there's an error of any kind in your C code? Mine prints out the offending line but then segfaults leaving the reason as an exercise for the reader.
Posted: Thu Apr 29, 2021 3:54 am
by BillG
Andrew had been working on this compiler with WDC before his passing.
Does anybody know what he had accomplished and whether his changes are in the latest official version?
Posted: Mon May 03, 2021 1:47 am
by Andre
Hi
I have just started my journey down the 6502 road, or perhaps continuing where I left off back in the 80's.
I started with an "Aloha 66" clone of an Apple 2. Unfortunately I no longer have any of the gear that I collected back in the day.
I am currently looking at the WDC compiler.
I am a (Electronics Engineer) embedded C programmer and not really that keen to go back to assembler if I can help it. (though I think assembler it may be)
Tide is a waste of time. I thought it would be something like AVR studio....IDE as in "Integrated Development Environment"....as in editor.
It can call an external editor...that's about it.
If I try to change anything in options I get an Error message "Failed to set data for 'Version'" ...don't know what this means.
Though, when I finally exit options and come back in the changes are there. I had other problems too.
I would not bother with Tide, seems buggy.
(If I supplied software like this to a customer I would be out of business)
After finding the startup.asm files in your posts, (Thanks)
I have managed to compile a simple program for example,
unsigned char x, y;
void main(void)
y = 100;
for(x=0;x<10;x++)
y++;
while(1);
Error reporting is rudimentary. For example drop the semi-colon at Y=100 above and you get
WDC 65C02 C Version 3.49.1 Feb 6 2006 16:25:18
Copyright 1992-2006 by The Western Design Center, Inc.
for(x=0;x<10;x++)
So the problem is possibly on or above this line....but we can't tell you any more.
I then add these lines and re-compile
#include "stdio.h"
char WrkSpc[20];
sprintf(WrkSpc,"HELLO WORLD");
WDC 65C816 Linker Version 3.49.1 Apr 24 2006 15:40:38
Copyright (C) 1992-2006 The Western Design Center, Inc.
Undefined symbol: _unlink
Undefined symbol: _close
Undefined symbol: _isatty
Undefined symbol: _write
Undefined symbol: _lseek
Now, the documentation (https://www.wdc65xx.com/wdc/documentati ... Linker.pdf) mentions in CHAPTER 7 WDCLN (LINKER)
that
Note: There are calls to user defined functions that are system dependent.
Example: _unlink, _ _close, _ _isatty,_ _write, _ _lseek, _ _fseek.
_ _read, _ _open, _ _creat, _ _ access (see WDC_SDS/INCLUDE/FCNTL.H
So I guess I need to write some code to perform these functions or maybe do nothing.
I don't see how sprintf uses them because the result from sprintf goes back to memory.
Actually, after this compile and link there is a HEX file. Not sure if the code will run or not.
As was pointed out, without the ability to recompile the libraries (with modified zpage and cfg files) you are stuck with the standard zpage layout.
This to me is a major problem for what I had in mind.
It would be nice to get this compiler working and to see some (even if limited) support from WDC. It could only benefit them in the long run.
(Off topic)
I receive a first (prototype) 6502 PCB in a few days. Was to lazy to breadboard or use vero board. Some people have too much time.
Was hoping to have the compiler ready to test. The board is pretty much just CPU + memory + 2 expansion slots. I did breadboard a potential video card based loosely on Ben Eater's videos. Bread boarding it is painfully slow and fixing errors means hours of rework. I bought an Altera CPLD programmer and dev board instead. Much easier to change logic on the fly.
Please keep this post alive with new information on the compiler, bug reports/fixes, etc. anything you think will help others.
I will try to use the compiler and see how far I get.
Thanks
Andre
Posted: Mon May 03, 2021 7:24 am
(Welcome!)
Posted: Mon May 03, 2021 12:33 pm
by Druzyek
Hi Andre, welcome and thanks for helping try to get the compiler working. I was able to get some simple test code working but I get the same errors as you when I try to use sprintf. I also get the annoying non-sensical error messages. I think if I were ever to use this compiler, I would find some pre-existing tool that checks C code for errors and let that run first.
If you just need a C compiler, have you tried CC65? The output is not especially well optimized (hence our interest in WDC) but it's very reliable and doesn't force you to recompile libraries when you change zp usage or anything stupid like that.
EDIT: and you may want to avoid sprintf and printf anyway since they can take up a huge amount of ROM even when you're only using a small percentage of their functionality. I just handle strings myself since something like puts is basically a 1 line function. You can devise sprintf/printf functionality with very, very little code if you know exactly what you want. I've done something like this in C with CC65: PrintInt("Three is % and five is %", 3, 5); You can give a dummy argument for the second int if you only need to print the first one in the string.
