The input side is curved, the the output comes to a little point, both unlike the AND gate.
6502/65C02 multiplexing
- GARTHWILSON
- Forum Moderator
Re: 6502/65C02 multiplexing
I see what happened. I took the 74xx32's to be AND gates, because that's how you drew them. The '32 is an OR gate, not an AND. Here's an OR gate:
There are different symbol sets for logic gates. The original one was a DIN symbol, yours is the ANSI symbol.
https://en.wikipedia.org/wiki/OR_gate
- GARTHWILSON
- Forum Moderator
I've never seen that before. I've been in this for about 35 years, and all along, I thought that DIN symbol was just a wrong way to draw an AND gate! I strongly recommend sticking with the ANSI symbol.
- BigDumbDinosaur
I remember learning the DIN symbols as a student, but I've mainly used the ANSI symbols myself. Fortunately those horrible IEC symbols are exceedingly rare. I don't know why the DIN symbols are obsolete and the IEC are not. It should have been the other way around.
I didn´t say I like it better. However, it is in the standard Eagle libraries so you should be aware.
Remember Hubble, the space telescope? Measuring in inches or cm - you have to be aware or you send scrap metal into orbit.
- BigDumbDinosaur
Air Canada nearly crashed a Boeing 767 in 1983 due to imperial vs. metric conversion errors.
During the fueling of the plane in Montreal, the required fuel load for the trip had to be converted from pounds to liters, as Air Canada 767s were built to the metric system. The conversion was in error and compounding the problem, the plane's flight computer was told that the correct amount of fuel had been loaded. So the pilots unknowingly took off with about half of the required fuel load to make it from Montreal to Edmonton, plus the required reserve. The plane's engines flamed out while cruising at high altitude over northern Ontario, however the pilots were able to deadstick to a rough landing at the old Royal Canadian Air Force base near Gimli, Manitoba. The plane was banged up pretty badly from the landing. but there were only minor injuries to passengers. When investigators arrived they discovered the plane had run out of gas in mid-flight.
(picture)
(picture)
Anyway, the circuit doesn't work and I am leaning towards that being a timing problem. The actual tested circuit has a 50ns delay between BEL and BER:
BEL 111100000000001111 (left BE=MBE)
BER 000001111111100000 (right BE)
The first design (which worked better, but still error-prone) used a combined OE signal and put that through a NAND with the CLK on the other input to generate WE. That was stable if I only ran one processor at a time (e.g. no same-cycle access).
At time being I am testing my first CPLD designs (Lattice breakboard) to get a more dynamic logic (read: easy to change). I want to run the two processors at different speeds, so a CPLD helps in that it has its own clock. Once I get some more results I will post it here.
