First 6502 project
HansO
Post by HansO »
spinnaker wrote:
I have a small boat load of 6522s. Could I use those for my hex display?
Yes you can. If you want the hex keyboard and the LED display you may ha ave a look at the KIM-1 design. The KIM-1 usies 6532, but nothing in the keyboard/display is special that you can also do with 6522. Simple and effective.
PaulF
Post by PaulF »
RIOTs be fairly hard to get. 65C22 VIAs are much more common to get these days
You can get a 6532 RIOT easily and cheaply by buying an old ATARI 2600 VCS on ebay & unplugging the RIOT chip. I know there are some who see this as sacralige but it is certainally the easiest way to get one. They usually have an Atari part number on them instead of 6532 but it is the same chip.
Shift to the left,
Shift to the right,
Mask in, Mask Out,
BYTE! BYTE! BYTE!
HansO
Post by HansO »
HansO
Re: First 6502 project
Post by HansO »
spinnaker wrote:
Where can I get a Hex keyboard? I have looked everywhere. I guess I could buy a 16 button pad and label the buttons myself but I would rather have a hex keypad.
Futurlec sells socalled tactile switches with buttons. The TACT006 can be equiped with a button, the seethrough plastic cap can be taken off and a legend on paper added.
$0.67 total per button. Perfect to make you own keyboard with the layout you want and the legends can be as good as your printer can produce.
See http://www.futurlec.com/SwTactile.shtml
Hans
Futurlec sells socalled tactile switches with buttons. The TACT006 can be equiped with a button, [and] the seethrough plastic cap can be taken off and a legend on paper added.
Neat! Who makes them? I'd like to see a little more info. A search for TACT006 only turned up Futurlec's website, but I'm sure someone else makes them and this is just Futurlec's number.
