Re: Tali Forth for the 65c02
Posted: Fri Dec 02, 2022 9:28 pm
Standard numbers in Tali are 16-bit so -32768 to +32767. If you use words like U. (u is for unsigned) to print the numbers, those same 16-bits can represent 0-65535 instead. There are other "unsigned" words like U< and U> to operate on unsigned values.
"Double" numbers in Tali use two 16-bit cells on the stack to make up a 32-bit number. This allows numbers from around -2.1 billion to +2.1 billion. You can deal with the halves as separate 16-bit values (most significant half is on top of stack) or use words like D. to print them and D+ to add them. To enter a double number, put a period after the last digit, eg: 1234567890.
Tali doesn't have the full double word set, but it has enough that all the "missing" words can be created if you need them. Here are some that I made while playing with FAT32 - some are ANS 2012 standard and some are just words I needed. In the stack comments, d = double, ud = unsigned double, n is a normal (signed 16-bit) number, u is an unsigned (16-bit) value, and f is a flag (true/false).There's also unsigned double words, like UD. that would print an unsigned double (values 0 to about +4.2 billion). Note that Forth expects the programmer to keep track of whether single or double values are on the stack and to use the appropriate words for them.
There are also 2CONSTANT and 2VARIABLE for constants and variables, 2DUP and 2DROP etc to manipulate them on the stack, etc. Most words that start with 2 (except 2* and 2/) work with double values. It's a bit unfortunate that some of the words start with 2 and others start with D, but that's how it is. You'll sometimes see the words used even with non-double values on the stack because (for example) 2DROP drops two items off the stack - it doesn't care if that was both halves of a double or two unrelated values.
Words that start with M are usually for "mixed" calculations, where one side is double and the other is not, eg M* (single value times a single value with a double result) and I bet you can figure out what UM* does now.
https://forth-standard.org, if you haven't found it already, will be very handy for reference as it covers the ANS 2012 Forth standard and I use the search function at the top all the time. The gotcha is that you kinda need to know the name of the word you want to know more about.
\ Tali2 needs some extra double words.
: d= ( d1 d2 -- f )
rot = -rot = and ;
: d0= ( d -- f ) 0= swap 0= and ;
: d0<> ( d -- f ) or ;
: d2* ( d -- f ) 2dup d+ ;
: d< ( d -- f ) rot 2dup = if ( use LSBs ) 2drop <
else ( use MSBs ) 2swap 2drop > then ;
: d0! ( addr -- ) ( store double 0 at address )
0. rot 2! ; allow-native
: d+! ( d1 addr -- ) ( Add d1 to double at addr )
dup >r 2@ d+ r> 2! ;
: d1+! ( addr -- ) ( Add 1 to double at addr )
1. rot d+! ;
