Page 15 of 15
Posted: Sat Apr 30, 2011 11:10 pm
by ElEctric_EyE
This project is taking a slight trajectory change, and it has to do with software, which has to do with the internal ROMs, which have to do with the hardware design hence my post here. I had originally intended (I hear myself saying that alot :roll:) to put the machine language monitor along with whatever routines it was going to use from the C64 Kernal and Basic ROMs. I was picturing "cutting & pasting" these routines...
But I've decided to include the full C64 Kernal, Basic, and Character ROM's. In fact I have already integrated them into the schematic along with Daniel Quintero's PS2 Core. So all the ROM's are occupying 24K, and I have a 1K RAM at the bottom of memory. ISE is saying 81% of RAMB16s are being utilized. Which leaves about 5K for future use at this point...
Everything passed synthesis, but there is one negative.
Anticipated top speed now is down 10MHz to 44MHz. Still not too bad.
I am anxious to begin testing! Now focused on getting that Micromon image.
Posted: Thu May 05, 2011 10:12 pm
by ElEctric_EyE
I finally got a reliable Micromon image and disassembled it in MK's macroassembler!
It is only using 6 routines from the C-64 Kernal. I will have to replace 2 of them, to get it semi-functional, with my own routines for the keyboard in and display out.
Later on, I'll make the save and load routines for the Flash memory, instead of the original cassette and 5 1/4" floppy device ops.
I have chosen not to incorporate the C-64 Kernal and Basic ROM's into the XC3S400.
If I did, it wouldn't have left enough memory for BASIC to work 100% reliably. Although, it will be for a future side project incorporating a 144-pin QFP Spartan-6 (BTW, they're now in stock for the slower -2 speed grade!! WOOOOO(I just ordered 6)) which has 576Kbits (i.e. 72Kbytes minus some for cpu and logic FF's = 64K+). Would be very interesting to run C-64 BASIC, SUPERBASIC, and other non-sprite/non-graphic programs at higher speeds....
But right now, I just need a functional 6502 monitor to make progress. Progress that will funnel down into the 65816 controlled PWA Project, although only in 6502 compatibility mode, at first.
In that project, I do plan on utilizing the T65 Core and trying to analyze the extent to which it has backwards 6502 compatibility, along with forward 65816 functionality, with this forums' help...
Also, just FYI:
1)There's no intentions to change from Arlet's 6502 core in the 6502SoC.
2) Rethinking RDY here. May just need a 1 or 2 cycle delay just like an original 1MHz 6502 because RDY is only active during the I/O device's active chip select.
Posted: Tue May 10, 2011 12:06 am
by ElEctric_EyE
The next 2 days I focus on the PS2 and I2C cores. If I have early success, I will focus on RDY again...
Posted: Wed May 18, 2011 2:57 pm
by ElEctric_EyE
Having problems trying to make a 16,384 byte ROM with the bin2coe (and bin2coeV2) converter. It's making the .coe file, but it doesn't contain the full 16K. I don't think it even worked for 8K. I've been having problems ever since I combined the original 4K C64 character ROM, the 4K monitor program and my software. Worked for me making a 4K ROM though. Shoulda ran ISim along time ago...
Can anyone confirm please?
Posted: Wed May 18, 2011 6:54 pm
isim will be the quickest way to see what's happening.
In isim you can force signals to certain values. So you only need to run your simulation for a few cycles after reset: force the address bus to some value, and observe the data bus to see what the ROM contains at that address. After a few runs you'll see what you have where. (There might even be easier ways, but that springs to mind.)
The question you're trying to answer is: what's in this design? Once you have that answer, the next question is: how did that happen?
(I'm not using coe files so I don't know what the limitations or pitfalls might be - nor do I have a huge ROM at this point.)
Posted: Wed May 18, 2011 7:06 pm
by ElEctric_EyE
BigEd, thanks for responding. Here's what I'm working with:
I've got a 16K ROM from $C000-$FFFF. Reset, IRQ, and NMI vectors point to $E000, where my software starts to init the display, and clear the screen, etc. Stuff I've tested already... At $C000-$CFFF is the 6502 monitor I've mentioned. $D000-$DFFF data is from an image of a 901225 C-64 character ROM.
I did in fact run ISim and saw that it was starting and reading from an incorrect vector, which made me inspect the .coe file for the correct binary data in notepad. bin2coe is not converting the entire 16K worth of binary data. So I reinspected the 16K binary file, and everything seems to be good there at the binary level. Problem is at the .coe level, heck the .coe file that bin2coe made is only 6.5K. Hence my post about the bin2coe program. Maybe I hit a limit of some kind?
Posted: Wed May 18, 2011 7:18 pm
ah, sounds like a bug... if you're not able to build it yourself, you might have to wait for someone who can rebuild it for you. Sorry, I can't help - not in front of the right kind of computer.
(I wonder if it hit a ^Z and saw that as end of file?)
Perhaps you could put your 16k binary data up somewhere? If nowhere else, sign up for dropbox and use their public folder mechanism. That'll make it a lot easier for someone to reproduce your problem.
Posted: Wed May 18, 2011 7:19 pm
by Arlet
I see that the windows version of the bin2coe program has a problem when there's a CTRL-Z in the bin file.
You can find a fixed version here: http://ladybug.xs4all.nl/arlet/fpga/source/bin2coe.exe
Posted: Wed May 18, 2011 7:25 pm
by ElEctric_EyE
Excellent, thanks! The semicolon should be EOF. I'll try it out :D :D
Posted: Wed May 18, 2011 8:09 pm
by ElEctric_EyE
F'ing A that was it!:evil:
PS/2 core working and displaying characters typed on screen! Many thanks!
Damn control Zed!!! What ascii value is that?
Next tue&wed will add I2C core back in, software already ready...
Posted: Wed May 18, 2011 8:11 pm
by Arlet
ctrl-z = 0x1A
Posted: Wed May 18, 2011 8:53 pm
by ElEctric_EyE
Arlet, let me pick your brain here for 1 moment, or anyone else versed in Xilinx FPGA's...
During this last "episode" of a week+ long troubleshooting, some questions have come to mind. But 1 primary question still remains...
ISE had previously spec'd a top speed of my project right around 37MHz at one point. However, the main DS1085 oscillator feeding the Spartan 3 DCM is at 48.58MHz...
When ISE spec'd a top speed of 37MHz, does that max speed spec apply to a DCM or to everything after a DCM?
i.e., are the DCM's on the four corners always capable of running at the highest speed of the FPGA device spec'd in the Xilinx spec sheet (which would be many hundreds of MHz), or are they (the DCM's) limited by the spec's synth'd by ISE?
Posted: Thu May 19, 2011 5:08 am
by Arlet
The max speed is the speed after the DCM, but the tools also understand the DCM, so if you have timing constraints on the clock feeding into the DCM, and you have constant divider/multiplier ratios, the tools will verify your design correctly.
Posted: Mon Aug 15, 2011 11:39 pm
by ElEctric_EyE
A final update for this thread:
This project is taking a trajectory change right into the heart of the 65Org16 Development board topic thanks to BigEd because of this.
