Page 2 of 2
Re: Orac Draughts.
Posted: Mon Jul 15, 2024 12:01 pm
by John West
llvm does considerably better if you ask for optimised code. With -O (I don't know what optimisation levels llvm-mos supports), it gives
showcharset(): ; @showcharset()
ldy #0
ldx #30
tya
.LBB0_1: ; =>This Inner Loop Header: Depth=1
sta __rc2
stx __rc3
sta (__rc2),y
clc
adc #1
cmp #0
bne .LBB0_1
rts
which is pretty good. If I had a lot of code to write and didn't need all of it to be the fastest possible, that's more than acceptable.
Re: Dynamo Draughts (with source)
Posted: Mon Jul 15, 2024 3:42 pm
by vbc
Now the interesting(?) thing is - I cannot find any 6502 program that plays 10x10 International draughts! So I was trying to get the c99 text version of Dynamo to compile with cc65, but it keeps throwing out-of-memory, even targeting a plus4 or c64. Can anyone suggest a better 6502 (C89) C compiler?
It is unlikely that any compiler will get this down to fit onto a bare C64 without changes. The code is pretty big and uses a lot of replication. I could get it to compile using vbcc for a C64 with REU, distributing the code into several banks. The resulting binary draws the board and can display the help screen, but executing a move seems to throw an error. However, this also happens with a version compiled on Linux, so there may be additional problems. Perhaps I will have a more thorough look into this.
I did start thinking in terms of pattern recognition within the intemediate code, so for example
#define VDU 0x1e00 /* C64 0x0400 etc */
void showcharset ()
register BYTE x;
x=0;
do {
*(VDU+x) = x;
x++;
} while (x);
Changing this code to be compilable and compiling it with vbcc gives:
$ cat l1.c
#define VDU ((BYTE*)0x1e00) /* C64 0x0400 etc */
typedef unsigned char BYTE;
void showcharset ()
register BYTE x;
x=0;
do {
*(VDU+x) = x;
x++;
} while (x);
$ vc +c64 -O -S l1.c
$ cat l1.asm
;vcprmin=10000
section text
global _showcharset
_showcharset:
lda #0
sta r2
l6:
lda r2
tay
sta 7680,y ;am(r2)
inc r2
lda r2
bne l6
rts
Using x as index as well as value to be written prevents vbcc from using the x register here. This code, for example, uses the x register:
$ cat l2.c
extern BYTE src[];
void showcharset ()
register BYTE x;
x=0;
do {
*(VDU+x) = src[x];
x++;
} while (x);
$ vc +c64 -O -S l2.c
$ cat l2.asm
;vcprmin=10000
section text
global _showcharset
_showcharset:
ldx #0
l6:
lda 0+_src,x ;am(x)
sta 7680,x ;am(x)
inx
bne l6
rts
Re: Orac Draughts.
Posted: Wed Jul 17, 2024 1:42 pm
by orac81
Thanks for all the input and comments, very useful! I will have to try the latest versions of LLVM and VBCC, and do a bit experimenting. Both those examples seem better than earlier compilers. I am impressed that VBCC is realising that it can use sta abs,x directly.
As for register vars, maybe a compiler directive could be implemented, something like:
//$$6502:PREFER_REG_X (tell compiler to prefer/try to use X for next var)
BYTE x;
//$$6502:PREFER_ABS_CONST (tell compiler to prefer lda/sta ABS[,x] mode for next constant PTR)
const BYTE *pVdu = 0x0400;
etc..
(PREFER_ZP_CONST or PREFER_REG_A might be alternative use cases.)
The source of DYNAMO is very untidy, my only excuse is that goes back to pre-web work with Turbo C and PCs with floppys. Did stdint exist then? There are probably bugs lurking in the code. Anyway I can improve the code with time. Also I can reduce the size of the arrays used, particularly if I set a limit to search depth. Some arrays can be BYTE rather than int, etc.
I should be able to make a 6502 compile work eventually.
Re: Orac Draughts.
Posted: Wed Jul 17, 2024 5:21 pm
Thanks for all the input and comments, very useful! I will have to try the latest versions of LLVM and VBCC...
I’ve not done anything with either compiler—programming in C is low on my list of interests, but I have read plenty of positive commentary about VBCC in my travels around the Internet. Developing a C compiler for the 6502/65C02 that emits reasonably succinct machine code is a significant programming challenge. What I’ve read seems to indicate VBCC’s output is pretty efficient despite the challenges. It also helps that the individual who developed VBCC is a member of this forum.
Re: Orac Draughts.
Posted: Sat Jul 20, 2024 1:31 am
by vbc
Out of curiosity I compiled it with my work-in-progress vbcc65816 which obviously has no problem with the memory requirements. I can have the computer make moves and (when deactivating randomization) it seems to give the same results as the linux version. However, I always get "Bad move!" whenever I try to make a manual move (even when using the same move the computer would choose). The same behaviour with the linux version. I did not investigate it further. Is this a bug or am I missing something?
Re: Orac Draughts.
Posted: Mon Jul 22, 2024 5:48 pm
by orac81
Well I have been experimenting with VBCC, and I am impressed, it is fast! Using a connect4 program I have written, it seems about twice as fast as cc65. This program is deliberately written in old k&r C so I can also test with really old compilers like Aztec c on the apple 2 or super C on c64, etc.
Other alpha beta type search progs also show VBCC to be fast. I am trying to make a version of DYNAMO compile for the c64. I will post some examples up at some stage.
One thing that really helps with these sorts of programs is moving the board array and some frequently used vars to zero page. On most 6502 machines about halve of zero page is used by basic, and can be reused. In fact nearly all of it can be reused if you make your own routines for key scans, printing to screen etc. As a guide ORAC speed up by 10% with the board in zero page, and also was smaller..
It's possibly a bug, the text version is nowhere near complete/fully tested. I will check it.
Thanks for making VBCC, it is very good!
Re: Orac Draughts.
Posted: Wed Jul 24, 2024 11:54 am
interesting finding!
Re: Orac Draughts.
Posted: Wed Jul 24, 2024 5:12 pm
That would concur with the comparison posted at https://www.videogamesage.com/forums/to ... ent-163145
Re: Orac Draughts.
Posted: Wed Jul 24, 2024 10:46 pm
by fachat
Does vbcc still have that closed source license mentioned in the linked article? Would be a no go for me.
Is there a speed comparison with llvm-mos?
André
Re: Orac Draughts.
Posted: Thu Jul 25, 2024 2:21 pm
by vbc
Unfortunately these benchmarks seem a bit dubious to me. It seems to be using its own framework and emulator, so it is a bit cumbersome to verify. Therefore I just looked at some points that seemed suprising to me.
Many of the tests have been written for or optimized/adapted to certain compilers. Obviously this can make a difference compared to neutral code. For example, the RLE/unzip benchmark for kickc has been adapted, so that the compiler sees the entire input data as a constant C array, whereas the unmodified version just gets an external reference to data from an assembly file.
Also, the declarations do not seem to match and probably random data will be decompressed:
kickc_unzip.c:
extern const uint8_t* zipped_data;
kickc_unzip_data.c:
const uint8_t zipped_data[] = { ...
Not sure how much of a difference that makes, but it does not raise confidence.
Then I had a look at the RPG example, because the gcc results were so much better. I did not reproduce his tests or the gcc results, but I had a look at the code generated by vbcc:
$ cat rpg.c
#include <stdint.h>
// Your typical RPG foo
typedef struct {
uint8_t pv;
uint8_t attack;
} Monster;
static void monster_init(Monster* monster) {
monster->pv = 10;
monster->attack = 2;
static void monster_take_hit(Monster* monster, uint8_t attack) {
if (monster->pv > attack) {
monster->pv -= attack;
}else {
monster->pv = 0;
// A hero wielding his weapon
typedef struct {
uint8_t attack;
uint8_t durability;
} Weapon;
typedef struct {
uint8_t pv;
uint8_t mana;
Weapon weapon;
} Hero;
static void hero_init(Hero* hero);
static void hero_change_weapon(Hero* hero, Weapon new_weapon);
static void hero_hit_monster(Hero* hero, Monster* monster);
static const Weapon fist = {.attack = 1, .durability = 255};
static const Weapon sword = {.attack = 3, .durability = 10};
static void hero_init(Hero* hero) {
hero->pv = 10;
hero->mana = 10;
hero_change_weapon(hero, fist);
static void hero_change_weapon(Hero* hero, Weapon new_weapon) {
hero->weapon = new_weapon;
static void hero_hit_monster(Hero* hero, Monster* monster) {
monster_take_hit(monster, hero->weapon.attack);
--hero->weapon.durability;
if (hero->weapon.durability == 0) {
// Benched routine: initialize things and begin a fight!
void benched_routine() {
// Game state:
// hero is in zero page,
// There is 3 monsters at the begining of page 4xx
Hero* hero = (Hero*)0x0080;
Monster* monsters = (Monster*)0x0400;
const uint8_t NB_MONSTERS = 3;
// Initialize gamestate
hero_init(hero);
hero_change_weapon(hero, sword);
for (uint8_t monster_num = 0; monster_num < NB_MONSTERS; ++monster_num) {
monster_init(&monsters[monster_num]);
// Fight!
hero_hit_monster(hero, monsters + 1);
$ vc +c64 -O3 -S rpg.c
$ cat rpg.asm
;vcprmin=10000
section text
global _benched_routine
_benched_routine:
ldx #10
stx 128
stx 129
lda #1
sta 130
lda #255
sta 131
lda #3
sta 130
stx 131
stx 1024
lda #2
sta 1025
stx 1026
sta 1027
stx 1028
sta 1029
lda 130
sta r0
lda 1026
cmp r0
bcc l47
beq l47
lda 1026
sec
sbc r0
sta 1026
jmp l48
l47:
lda #0
sta 1026
l48:
dec 131
lda 131
bne l49
lda #1
sta 130
lda #255
sta 131
l49:
rts
For the life of me I do not see how gcc could generate code several times faster than that. So I kind of doubt that vbcc was used correctly.
As a problem was mentioned with vbcc and the cc65-optimized game code (which apparently was the reason to call vbcc "buggy" in the summary), I tried to look into that and found this in the code:
#define SCREEN_ADDR ((unsigned char*)0x300)
and this in the linker file:
Now obviously that is not going to work. So I would take those results with a few pounds of salt.
Re: Orac Draughts.
Posted: Thu Jul 25, 2024 2:36 pm
by vbc
There has been no change to the license. The source is available, but modified versions must not be distributed. Non-commercial use is free, but commercial use is free only for Mega65 and Amiga68k due to sponsorships.
I am aware of those 6502 compiler benchmarks:
https://raxiss.com/article/id/30-MOS650 ... -benchmark
https://gglabs.us/node/2293
Re: Orac Draughts.
Posted: Fri Jul 26, 2024 2:15 pm
by orac81
This is a bug in that version of DYNAMO. In routine do_human_move, line 3326 change:
If (doamove(src, dest, 1)) {
To:
If (doamove(sqpos[src], sqpos[dest], 1)) {
And that should work for square numbering for 10x10, so from new you can type 31-27 <ENTER>. etc. (I had changed if for internal numbering testing and forgot to change back) I will release an update sometime, and some benchmarks/examples on 6502 compilers.
As for a 6502 version of DYNAMO, I was thinking it may be easier to rewrite a neater version, I'm looking at old code and thinking "what the heck was I doing?".. I used large arrays and unrolled code macros to make faster move generator under turbo c, which doesn't suit the 6502.
I think a (relatively) strongish 10x10 program should be possible in pure 6502 asm in less than 8k, obviously more in C. The unexpanded vic20 version of ORAC (with front-end) playing simpler 8x8 checkers is just 3300 bytes.
As for choice of compiler it's worth noting that it's often possible with a few #if and #define macros to make code that builds on a range of compilers..
EDIT: I have added an update to DYNAMO that corrects the above bug.
download:
https://github.com/orac81/Orac-Draughts ... na920a.zip
Re: Orac Draughts.
Posted: Mon Dec 01, 2025 12:58 am
by orac81
Ok, another "Draughts" release, not exactly 6502 related, but you can see the progression in this thread from an 8k 1981 PET program (Orac) to a win32 program with 6 piece "perfect play" endgame database with 30 billion positions!
Sage Draughts is a very comprehensive Draughts or Checkers playing program from the late 1990s. I am releasing this with the source code.
https://github.com/orac81/Orac-Draughts ... latest.zip
SAGE is a 32 bit Windows program, which should run on any version from XP up to Windows 11. It can can run under LINUX or MAC-OS using a windows emulator like WINE. It can be installed by simply downloading and extracting the zip file. To run, open the SAGE folder and click/run SAGE.EXE.
It has a very wide range of features, levels, analysis, game replay/save/load, handling PDN game databases, endgame "perfect play" databases, large opening databases, and so on.
Sage can play Checkers on any size Board from 4x4 to 12x12. It can also play Italian rules checkers.
Or you can just enjoy a game of Checkers!
For more details/source for Orac(6502), Dynamo and Sage see here:
https://github.com/orac81/Orac-Draughts/
To compile the source MSVC4.2 is needed, see src folder and sagemake.bat.
I did start writing a new engine based on Dynamo to play all the variants, inc 10x10 international draughts, able to run with SAGE, but small/fast enough to build with Oscar64-C/VBCC for the 6502, but its not finished yet.
Its interesting to note there are no 10x10 international draughts programs for the 6502!
