Re: Looking for floating point libraries
Posted: Sun Jun 15, 2025 1:29 pm
BillG wrote:
I know you want something with a permissive license.
I am not a patent lawyer and I do not play one on television; if you were to paraphrase code from one processor architecture to a different one, is the result considered to be infringing? If not, that may be a relatively easy way to get there. I have always presumed that to be safe; it is not unlike coding from an algorithm in a book or journal.
Floating point code has been published for the Motorola 8-bit processors. Same for 8080/Z80. Source code for 8087 emulation from the Borland compilers (80x86) is also out there.
Are you picky between BCD versus binary?
A long time ago, I set out to write IEEE 754 compliant floating point for the 6800. I have single precision generally working but have yet to work out how to implement the guard, round and sticky bits. Because the AVR instruction set looked so easy to program, I also built a version for that. Future steps:
* Figure out the guard, round and sticky bits
* Improve the speed
* Implement 6-byte, double and extended precision
* Port to other processors
* Improve the speed
If you have any resources, optimization techniques, or advice for improving speed, I would greatly appreciate your input. I believe that by sharing our experiences, we can both enhance our projects. I look forward to exchanging ideas with you.
https://github.com/zu2/chibicc-6800-v1
