A W65C02 not being able to run at 14 MHz sounds very odd to me given that they have a 14 Mhz column on the data sheet, and their "F Max vs Vdd" chart goes up to 20 Mhz, with a little cross marked at about 19.5 MHz and 4.2 V.
Looking at the 14 MHz specs (in ns), clock pulse width high and low tPWH = tPWL = 35 min:
Data setup tMDS = 25 max, meaning that it's available at least 10 ns before Φ2↓, and tDHW = 10 min appears to give that another 10 ns after Φ2↓, so that looks no different from the 6810 case in my previous post and data is fine at 14 MHz. (I see now that all these "hold" times are actually holds from the clock edge, which makes things make a lot more sense and really does lock them to that clock edge.)
For the address, address setup time tADS = 30 max, giving at least 5 ns between the address being settled and Φ2↑. The address hold time tAH = 10 min so again, at least 10 ns after Φ2↑.
I guess I need to thank you for forcing me into the data sheets to this depth; it's really been very educational. :-)
But I decided to have a look at a 1979 Synertek SY6500 datasheet I happen to have kicking around on paper, and it turns out that it does give this. (Yay!) Fortunately it's already been scanned and is up on 6502.org. The timing diagram is a full page, so rather than paste it here perhaps it's easier just for you guys to go look at page 4 of that scan.
It gives "Φ₀ Neg to Φ₂ Neg Delay" TO2- = 65 ns max (at 1 MHz), and "Φ₀ Pos to Φ₂ Pos Delay" TO2+ = 75 ns. So finally we seem to have some numbers that might tell us how tolerances change between the two. But I wonder if these take into account the much slower rise time of Φ2 compared to a good Φ0 signal.
Anyway, let's just go with Φ0 edges up to 65/75 ns earlier than Φ2 edges. The minimum length of Φ2low (ref "A" to ref "B") isn't directly given, but it looks like we can get it by adding TD = 5 min + TPWHΦ1 + TO1- = 5 min + TD = 5 min. We get TPWHΦ1 from TLΦ0O - 20 = 480 - 20 = 460, so a Φ2 high pulse is minimum 475 ns. Phew! Is that even right? Maybe I'll stop here while someone checks that and I gird myself for the next steps. And go off and read Jeff's stuff again, since it's been a while.
