65C02 System only works if I run it faster?
Re: 65C02 System only works if I run it faster?
Like Garth, I have a hard time correlating a schematic that is boxes with net symbols to the circuit's intended function, but I think I can offer one sage bit of "wisdom."
I presume you know who "Boss" Kettering was. My mentor back in my railroading days once referred to "Boss" Kettering as the Yogi Berra of the automotive industry due to Kettering's common-sense observations about automobile design and manufacturing. Foremost among those witticisms was "Parts left out don't cost anything and never break." (Note that Kettering's exact words have long been a topic of debate, but what he meant is crystal-clear.) In other words, design for simplicity and your contraption will be cheaper to make and easier to repair.
"Boss" Kettering's aphorism, if applied to computer design, could be paraphrased as "Gates left out don't clutter the design and don't cost propagation time." My impression of your circuit is the glue logic is torturous and needs to be given some more thought. A worthwhile goal, one that I routinely seek in my designs, is to have no more than two cascaded gate delays between the address bus and any one chip select. It's not easy, but can be done.
I haven't looked at the schematic, but BDD's comments remind me of something. If you have complex logic, where various inputs diverge and reconverge to produce a result, it's possible that the result will be glitchy - in fact it's relatively likely. Modern design advice is, as much as practical, to use synchronous design style with a single clock, and in the ideal case glitches (or non-monotonic outputs) are then not a problem, provided everything settles by the time of the next clock edge.
However, if you do have a non-monotonic output, or a glitch, which happens at some time, then the circuit may work if the next clock edge comes either after the glitch has settled, or before it arises.
That's a possible explanation for why a circuit might work at a high speed but some lower speed. It's actually being clocked too fast for the various propagation delays, but happens to come out right in this particular experiment.
It might or might not be the root cause here!
MagerValp
Post by MagerValp »
If I'm reading the schematic correctly you're qualifying CS_RAM with PHI2, while R/W is connected straight to the SRAM's WE pin. You should instead be qualifying WE with PHI2, and CS_RAM should be decoded with as few gates as possible. You have a lot of cascaded logic for the chip selects.
Going along with your theory (which I think is the likely scenario in this case) is the fact that propagation delays are somewhat random in nature, due to the usual device tolerances. Furthermore, temperature and/or voltage variations can vary the aggregate prop delay over the short term and further randomize things to where glitches can come and go with no obvious explanation.
Those are points I earlier mentioned. The main concern with not qualifying /WE is the risk of corrupting data in an RAM cell that is incidentally selected as the address bus settles during Ø2 low. Hence the risk of corruption if /WE is asserted during Ø2 low.
A slightly more complicated situation exists with the 65C816, which drives the data bus during Ø2 low to emit the A16-A23 component of the effective address. Hence a device's /OE must not be asserted until Ø2 high to avoid data bus contention. Lacking that, a bus transceiver would have to be used for isolation.
That he does. Aside from the potential glitching issue mentioned by Ed, there is the question of whether the logic in fact does what is expected. That can be hard to determine when gate after gate is used to generate an output.
