Embedding/Manipulating Assembler in Higher Level Languages
leepivonka
Re: Embedding/Manipulating Assembler in Higher Level Languag
Post by leepivonka »
Here are some small samples of inline assembly using a STC 65816 Forth.
Inline assembly is really easy since all the code (both Forth & assembler) compiles to 65816 machine code.
D:\65816>\65816s\release\65816s h\0265sxb.lst
65816S Oct 16 2020 14:29:43
65c265 mode on
A=0000 X=0000 Y=0000 S=0180 EnvMXdIzc D=0000 B=00 7818FBC2 008f3e sei
.g
65816F 2020Dec06
A=00FE X=00A6 Y=F6D0 S=0458 envMxdIZC D=0000 B=00 2BB00728 00f6dd pld
.@z2.txt
.g
\ Run on 65816F (An STC Forth for the 65816 in native mode)  ok
  ok
\ Show inline assembly mixed with Forth  ok
$f0 constant ScreenBank  SeeLatest     \ starts at $f00000
04BB A9F000     LDA #00F0 {' ScreenBank}
04BE 4CBE96     JMP 96BE {PsuA}
 ok
$100 constant ScreenWidth  SeeLatest
04CF A90001     LDA #0100 {' ScreenWidth}
04D2 4CBE96     JMP 96BE {PsuA}
 ok
: ScreenWidth* ( n -- n )  \ fast version, hard-coded Screen_Width  compiled
  [ ScreenWidth $100 <> [if] abort [then] ]  compiled
  PluA [ xba, $ff00 ## and, ] PsuA ; inline  SeeLatest
04E4 B500       LDA 00,x                        PluA
04E6 E8         INX
04E7 E8         INX
04E8 EB         XBA                             [ xba,
04E9 2900FF     AND #FF00 {LED+0048}            $ff00 ## and,
04EC CA         DEX                             ] PsuA
04ED CA         DEX
04EE 9500       STA 00,x
04F0 60         RTS                             ;
04F1 60         RTS                             inline
 ok
: ScreenGetPixel ( y x -- color )  compiled
  PluA PsuA swap ScreenWidth* +  compiled
  PluA [ txy, tax, 0 ScreenBank al,x lda, tyx, $ff ## and, ] PsuA ;  SeeLatest
0503 B500       LDA 00,x                        PluA
0505 E8         INX
0506 E8         INX
0507 B400       LDY 00,x                        PsuA swap
0509 9500       STA 00,x
050B 98         TYA
050C EB         XBA                             ScreenWidth*
050D 2900FF     AND #FF00 {LED+0048}
0510 18         CLC                             +
0511 7500       ADC 00,x
0513 E8         INX                             PluA
0514 E8         INX
0515 9B         TXY                             [ txy,
0516 AA         TAX                             tax,
0517 BF0000F0   LDA F00000,x                    0 ScreenBank al,x lda,
051B BB         TYX                             tyx,
051C 29FF00     AND #00FF {' ScreenBank+000F}   $ff ## and,
051F CA         DEX                             ] PsuA
0520 CA         DEX
0521 9500       STA 00,x
0523 60         RTS                             ;
 ok
  ok
: Test1  \ Show a compile-time expression  compiled
  [ ScreenBank u>d 16 DLShift 2Literal ] D. ;  SeeLatest
052C A0F000     LDY #00F0 {' ScreenBank}        [ ScreenBank u>d 16 DLShift 2Literal ]
052F A90000     LDA #0000 {' SInIndx0}
0532 20C5B9     JSR B9C5 {D.+0003}              D.
0535 60         RTS                             ;
 ok
  ok
: Digit1 ( u -- char )  \ Show the Forth compiler doing some 65816 optimizations  compiled
  dup 9 u> if  7 +  then  [char] 0 + ;  SeeLatest
053F B500       LDA 00,x                        dup
0541 C90900     CMP #0009 {' SInIndx1+0001}     9 u>
0544 F002       BEQ 0548 {Digit1+0009}          if
0546 B003       BCS 054B {Digit1+000C}
0548 4C5305     JMP 0553 {Digit1+0014}
054B A90700     LDA #0007 {' SInCnt0+0001}        7
054E 18         CLC                               +
054F 7500       ADC 00,x
0551 9500       STA 00,x
                                                 then
0553 A93000     LDA #0030 {' SOutCnt0+000A}     [char] 0
0556 18         CLC                             +
0557 7500       ADC 00,x
0559 9500       STA 00,x
055B 60         RTS                             ;
 ok
: Digit2 ( u -- char )  \ But hand-coded 65816 assembly is still smaller & faster  compiled
  [ 0 d,x lda, 10 ## cmp, IfCs, 6 ## adc, Then,  char 0 ## adc, 0 d,x sta, ] ;  SeeLatest
0565 B500       LDA 00,x                        [ 0 d,x lda,
0567 C90A00     CMP #000A {' SInEnd1}           10 ## cmp,
056A 9003       BCC 056F {Digit2+000A}          IfCs,
056C 690600     ADC #0006 {' SInCnt0}             6 ## adc,
                                                 Then,
056F 693000     ADC #0030 {' SOutCnt0+000A}     char 0 ## adc,
0572 9500       STA 00,x                        0 d,x sta,
0574 60         RTS                             ] ;
 ok
: Digit3 ( u -- char )  \ assembler, using local labels  compiled
  [ 0 d,x lda, 10 ## cmp, LRefR @b bcc,  ok
    6 ## adc,  ok
    LDef @b  char 0 ## adc, 0 d,x sta, ] ;  SeeLatest
057E B500       LDA 00,x                        [ 0 d,x lda,
0580 C90A00     CMP #000A {' SInEnd1}           10 ## cmp,
0583 9003       BCC 0588 {Digit3+000A}          LRefR @b bcc,
0585 690600     ADC #0006 {' SInCnt0}           6 ## adc,
                                                LDef @b
0588 693000     ADC #0030 {' SOutCnt0+000A}     char 0 ## adc,
058B 9500       STA 00,x                        0 d,x sta,
058D 60         RTS                             ] ;
 ok
  ok
$ff01 constant VIA2DDRA  SeeLatest
0599 A901FF     LDA #FF01 {' VIA2DDRA}
059C 4CBE96     JMP 96BE {PsuA}
 ok
$ff02 constant VIA2PA  SeeLatest
05A8 A902FF     LDA #FF02 {' VIA2PA}
05AB 4CBE96     JMP 96BE {PsuA}
 ok
: INIT_D/A  $FF VIA2DDRA C!  ;  ( -- )  SeeLatest
05B9 A9FF00     LDA #00FF {' ScreenBank+000F}
05BC E220       SEP #20 {Loc+0004}
05BE 8D01FF     STA FF01 {' VIA2DDRA}
05C1 C220       REP #20 {Loc+0004}
05C3 60         RTS
 ok
: WR_D/A        VIA2PA   C!  ;  ( c -- )  SeeLatest eof
05CD B500       LDA 00,x
05CF E8         INX
05D0 E8         INX
05D1 E220       SEP #20 {Loc+0004}
05D3 8D02FF     STA FF02 {' VIA2PA}
05D6 C220       REP #20 {Loc+0004}
05D8 60         RTS
 ok
johnwbyrd
Post by johnwbyrd »
gcc and clang both understand the asm and asm volatile keywords, as Daniel Thornburgh aptly demonstrated:
int main(void) {
	const char *cur = "HELLO, WORLD!\n";
	while (*cur) {
		char c = *cur++;
		asm volatile ("JSR\t$FFD2" : "+a"(c));
