I need a USB programmer, I got no parallel port any more, I also don't have a PC but this covered with a virtual machine. In older documents it is mentioned that WinCUPL supports the Altera ByteBlaster cable. Again you need a parallel port for that. Do you know whether the current version of WinCUPL supports the USB Blaster cable?
In some case you might convert the SVF file in the more compact Xilinx format, XSVF. You might need the Xilinx tools to convert a JED file. See
http://hackaday.com/2008/12/11/how-to-p ... ices-cpld/
For example, the Bus Pirate recipe requires XSVF - see http://dangerousprototypes.com/docs/Bus ... SVF_player
Try
http://www.labbookpages.co.uk/electroni ... Chain.html
("Convert your compiled hex file into a SVF (Serial Vector Format) file using the Atmel utility avrsvf.exe. Use the lmilk utility to 'play' the SVF file and program the AVR")
https://www.awce.com/avrjtag.htm
http://www.atmel.com/Images/doc1651.pdf
As for WinCUPL, it would be interesting to hear if it runs happily in WINE on Linux - most Windows programs do. No need for a virtual machine or a Windows installation. It seems to be working for me, once I'd applied "winetricks" -see
http://wiki.winehq.org/winetricks
(One can always check the WINE-compatibility status of a windows program at WINEHQ - for example
http://appdb.winehq.org/objectManager.p ... n&iId=1850
