Aha, so that error posted above is probably the same as I see randomly - it's just displayed differently on Windows (or maybe IE) than in Chromium or on the Android browsers, which are what I use. When I get those I simply edit the url so that https becomes http and reload, and it works. I still haven't figured out a reliable way to provoke that problem every time, except the one that I mentioned earlier - whenever I post anything in a thread, at least when starting with the 'frames' version, it'll return to a https (SSL) link afterwards.
-Tor
AnyCPU forum announcement
Re: AnyCPU forum announcement
Error code 12263 is "SSL received a record that exceeded the maximum permissible length."
- BigDumbDinosaur
What kind of cryptic error?
Same message. I was about to post that but you beat me to it.
I made a small modification on the control panel, let me know if the problem persists.
Have there been any more SSL issues since my last fix?
I made a new post since you announced the change, and the error message I was used to seeing didn't appear. So that seems like cause for optimism
