Re: NINA - a homebuilt 6502 machine [video]
Posted: Tue Dec 04, 2012 11:36 am
I`m intrigued by the 68C50 idea, if the humble 1MHz 6850L will cope with a CPU running at 8+MHz, then it seems reasonable to assume that a faster UART could handle a higher CPU speed, maybe even 16.384MHz?
the problem Now of course is that everywhere I`v looked doesn`t have any.
So... any ideas where I could get one from (at a reasonable price)?
also, I had a look at the WDC chips I have and you`re quite right about the 14MHz thing, there are indeed marked up as such, so No idea where I got the 10MHz number from (unless it was from the guy on Twitter mentioning it), eitherway, if this 68C50 idea works, then 16+MHz isn`t too much of a push room temp or otherwise I should think.
currently I have a few projects on the go in the area of CPLD and also AT1284P chip defines/libraries, so work on NINA is on the back burner for a bit, but not Too long in case I forget where I was! (I keep lousy notes).
