Page 8 of 15
Posted: Wed Mar 02, 2011 12:57 pm
by ElEctric_EyE
I don't know why I kept thinking 45MHz as the default frequency of the DS1085-5. It's 48.58MHz. So rewriting the constraint below (after some other fiddling) worked @ 24MHz! I always seem to have the greatest success in the mornings.
. Now if I can get the display to run @48MHz, I will be very happy indeed.
NET "O2" TNM_NET = O2;
TIMESPEC TS_O2 = PERIOD "O2" 20.5 ns HIGH 50% INPUT_JITTER 100 ps;
NET "O2Out" OFFSET = OUT 5.5 ns AFTER "O2" RISING;
I was abit premature in my declaration of success 7 hrs ago. I later realized I had a timing constraint error because my 5.5ns "estimated" delay is shorter than the internal delay (as spec'd by ISE), from O2 to pad, of 11.7ns. Although the circuit still worked the best I had so far, it was locking up after some time (<1min)...
After looking over some of my old schematics from the PWA project, I decided to qualify WE from Arlet's 6502 core with O2/2. In addition, instead of an arbitrary 5.5ns, I calculated the actual time I needed to put O2Out in sync with O2, although the display likes an inverted version of O2.
The 6502SoC has been running now for over an hour with no problems @24MHz using this constraint with the schematic below:
NET "O2Out" OFFSET = OUT 19.0 ns AFTER "O2" RISING;
As I am not a timing diag kind of person, I realized in the middle of posting this, that the diagram below is incorrect. The 2 waveforms below O2 are divided by 2 in the schematic. As usual with me, I happen across my successes sometimes by accident. This "accident" will give me insight to pushing for 48MHz, because for sh*ts and giggles I just now tried to run the 6502SoC @48MHz, and it cleared the display. Although repeatability was not there yet, it did more now than previous attempts @48MHz... I'm zeroing in!
Updated schematic:
Note(s) to self: After reading this
post on my 2nd favorite forum, Xilinx forums, Austin Lesea (their principle engineer) comments on jitter value ranges. "...100ps for synchronous design with single clock...", and "...1000ps for... poor bypassing...".
A
video about switch debouncing an FPGA.
A
video about someone with similar ideas to mine using an XC3S400, T65 core, PS/2 interface, and an SDCard interface. Darn I though I would've been the only one, heh!, I'm always behind the power curve... I asked on his video what speed he is running the T65 core. Waiting for response, doubt I'll get any, been posted a year ago...
Posted: Fri Mar 04, 2011 7:45 am
by Arlet
To relax the timing constraints for writing to the display, you could try registering the outputs with an extra layer of flip-flops. This would add an extra clock cycle pipeline delay, but if you're only writing to the display, it shouldn't matter.
Posted: Sun Mar 06, 2011 7:40 pm
by ElEctric_EyE
...but if you're only writing to the display, it shouldn't matter.
Right, now I am only writing to the display. To start, I think I need to increase my jitter spec much higher i think. And finish a correct timing diag. I would have responded earlier, but I've been gone for two days on a short vacation, in the Outer Banks, away from the internet...
I did take ISE In-Depth tutorial and the laptop with ISE 12.3 and the 6502SoC project file. I had intentions of learning about testbenches, but I came across a debounce circuit in verilog and VHDL and how to implement it in a design on (
Pg.23 to Pg. 28).
I followed the directions, but I'm getting an error. I think I'm putting a semicolon in the wrong spot. I really have no clue of proper syntax. Help?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity debounce is
Port ( sig_in : in STD_LOGIC;
clk : in STD_LOGIC;
sig_out : out STD_LOGIC);
end debounce;
architecture Behavioral of debounce is
signal Q1, Q2, Q3 : STD_LOGIC;
begin
process (<clk>)
begin
if (<clk>'event and <clk> = '1') then
Q1 <= sig_in;
Q2 <= Q1;
Q3 <= Q2;
end if;
end process;
sig_out <= Q1 and Q2 and (not Q3);
end Behavioral;
ERROR:HDLParsers:164 - "C:/a/debounce.vhd" Line 35. parse error, unexpected LT, expecting IDENTIFIER or STRING_LITERAL
ERROR:HDLParsers:164 - "C:/a/debounce.vhd" Line 41. parse error, unexpected IF, expecting SEMICOLON
Posted: Sun Mar 06, 2011 7:43 pm
by Arlet
Can you copy/paste the error message you get ?
BTW: if you use the Verilog version, I can help you better. I know almost nothing of VHDL.
Posted: Sun Mar 06, 2011 7:48 pm
by ElEctric_EyE
Yes, they have a verilog example as well. I will try that if you don't see a problem.
I've edited the post, before I knew you had posted. Line 35 is "Process".
Posted: Sun Mar 06, 2011 7:56 pm
by Arlet
One thing I noticed that you have:
and that the example has:
Not sure if that makes a difference.
Posted: Sun Mar 06, 2011 8:04 pm
by HiassofT
process (<clk>)
begin
Q1 <= sig_in;
Q2 <= Q1;
Q3 <= Q2;
end if;
end process;
Replace "<clk>" with "clk", this should fix it (I guess "LT" means "less than" - ISE is really creative when it comes to error messages :-)
Identifiers in VHDL are not case sensitive, so it doesn't matter if you write "std_logic" or "STD_LOGIC".
so long,
Hias
Posted: Sun Mar 06, 2011 8:10 pm
by Arlet
From the tutorial. See 6c.
6. VHDL only: Complete the VHDL module by doing the following:
a. Move the line beginning with the word signal so that it is between the
architecture and begin keywords.
b. Remove the reset logic (not used in this design) by deleting the five lines beginning with if (<reset>... and ending with else, and delete one of the end if;
lines.
c. Change <clock> to clk; D_IN to sig_in; and Q_OUT to sig_out. Note: You can select Edit > Find & Replace to facilitate this. The Find fields appear at the bottom of the Text Editor.
Posted: Sun Mar 06, 2011 8:27 pm
by ElEctric_EyE
Lack of attention to detail on my part.
I had performed a find & replace, and searched for "clock", not "<clock>"...
Yes sirs, it passes syntax now. Thanks!
Now I'll make the debounce symbol and insert it after the reset buttons in the schematic.
Posted: Sun Mar 06, 2011 9:51 pm
by ElEctric_EyE
Made the symbol and put it in the schematic. Tried to wire it up, but it wouldn't connect.
I right clicked on the symbol in the schematic to edit it. Added pins for sig_in, clk, and sig_out. Now it connects ok. I went back to the vhdl file, expecting ISE to have modified it in some way for having added I/O pins, but it didn't...Anyway,
I copied the debounce.vhd file from the laptop to the desktop that's physically connected to the 6502SoC. Right clicked in Hierarchy to add source and added debounce.vhd. Created the debounce symbol and connected it to the inverter before RES (Reset) and RES2 (NMI) in the schematic, using O2/2 as the clk for the debounce symbols. Now nothing works.
Any input appreciated, I'm off now to give the brain a rest until tue&wed.
Posted: Mon Mar 07, 2011 1:10 pm
by HiassofT
Actually, the logic works as a rising-edge-detector: whenever the the input is low @t-3, high @t-2 and @t-1 the output is high for one clock cycle, otherwise it's low.
I don't know the logic behind your RES and NMI inputs, but this might not be the kind of signal you are expecting.
If you want to protect the circuit against single-cycle spikes you could, for example, add a "best-of-3" decoder: The output is high if the input was high for 2 or 3 cycles, otherwise it's low (if the input was low for 2 or 3 cycles).
The logic is quite simple:
sig_out <= (Q1 and Q2) or (Q1 and Q3) or (Q2 and Q3);
But, this is still not optimal. RES and NMI are usually asynchronous signals which means you should run them through a two-stage synchronizer to avoid metastability problems. Currently the logic uses a one-stage synchronizer, if you add another stage (Q0) you should be fine.
Q0 <= sig_in;
Q1 <= Q0;
Q2 <= Q1;
Q3 <= Q2;
end if;
Of course, keep in mind that this logic introduces a 4-cycle latency. This might not be a problem for RES, but could be for NMI.
so long,
Hias
Posted: Tue Mar 08, 2011 7:50 pm
by ElEctric_EyE
I am familiar with synchronizers. I'll have to look into it again and would appreciate your help when the time comes. I'm back to trying to get this thing running @48MHz.
Today I made a little progress and was able to get ISim to run a simulation. Instead of writing a testbench in a HDL, I was able to force NMI inactive, active reset for a initial time of 5000ps, and force a 20.58ns clock for O2. Below is a pic from ISim with system successfully running @24MHz. One thing I don't understand is the display (chip select) signal goes low 3 times and that's it? I ran the sim for a full 8sec and it never again goes low, even though the display in real life is constantly clearing the display with incrementally changing colors.
LDA #$01 ;software reset
STA dcom
STA dcom
STA dcom
LDX #$ff ;delay
a DEX
BNE a
LDA #$e0 ;start PLL
STA dcom
LDA #$01
STA ddat
LDX #$ff ;delay
b DEX
BNE b
LDA #$e0 ;lock PLL
STA dcom
LDA #$03
STA ddat
LDA #$b0 ;set LCD mode, 640x480
STA dcom
LDA #$0c
STA ddat
LDA #$80
STA ddat
LDA #$02
STA ddat
LDA #$7f
STA ddat
LDA #$01
STA ddat
LDA #$df
STA ddat
STZ ddat
LDA #$f0 ;set interface format:8-bit
STA dcom
LDA #$00
STA ddat
LDA #$3a ;set RGB format, 18 bits per pixel
STA dcom
LDA #$60
STA ddat
LDA #$e6 ;set pixel clock
STA dcom
LDA #$04
STA ddat
LDA #$ff
STA ddat
LDA #$ff
STA ddat
LDA #$b4 ;set Horizontal Period
STA dcom
LDA #$02
STA ddat
LDA #$f8
STA ddat
STZ ddat
LDA #$44
STA ddat
LDA #$0f
STA ddat
STZ ddat
STZ ddat
STZ ddat
LDA #$b6 ;set Vertical Period
STA dcom
LDA #$01
STA ddat
LDA #$f8
STA ddat
STZ ddat
LDA #$13
STA ddat
LDA #$07
STA ddat
STZ ddat
STZ ddat
Posted: Wed Mar 09, 2011 9:37 am
by Arlet
What you can do is add the signals for the internal PC, and A, X, Y registers. That way you can see what the CPU core is doing, and if that matches what you expect.
Posted: Wed Mar 09, 2011 10:21 am
by PontusO
Exactly, and possibly the IR as well, cuz I don't get what the data bus is doing. I can't see an instruction fetches, or are they strictly internal ?
Posted: Wed Mar 09, 2011 5:38 pm
by ElEctric_EyE
@PontusO. I will post another pic with IR and address bus. O2 feeds a divider. O2Out is what the display sees. An inverted O2Out is what the internal core/RAMs/ROM sees as per
this schematic.
I should have included the address lines as well. Looking at them reminded me of the fact that I had increased those 2 delays from what I had posted above because I had increased the speed of O2 to 24MHz from much slower speeds. I think what I thought was 8sec's was maybe more like .8sec's...Turns out the display still init's ok with those short delays @24MHz.
Looking at A0, Display, and R/W with respect to O2out, it is in spec with the
SSD1963 datasheet (Fig.13-2 on pg. 78.), even at 48MHz.
At this point I'm thinking the values I have for initializing the display are not up to speed. I would think, for example, the pixel clock would have to be faster that the O2 speed? I suspect this because right now the pixel clock is set for 33MHz.
I'm focusing on 2 registers, $E2 (Set PLL frequency, Pg. 72) and $E6 (Set Pixel clock, Pg.74).
Any comments or suggestions? TIA
A better insight:
