Page 8 of 15
Posted: Sat Feb 26, 2011 12:18 pm
by ElEctric_EyE
I think you're right, it's time. I've had my eye on
GTKWave that I've seen Andre use in another post in another section. Even if it doesn't support DCM's, at least I hopefully can get a feel for the correct delay needed. Right now I'm just pi**ing in the wind.
Posted: Sat Feb 26, 2011 1:01 pm
by Arlet
You can also use the built-in Isim simulation in the ISE program.
In the ISE Design tab, there are buttons to choose between 'Implementation' and 'Simulation'. If you click on 'Simulation', you can highlight the top level schematic, and simulate it.
You'll need a create a small test bench, though. A simple clock, plus a reset pulse is enough to get started.
Posted: Mon Feb 28, 2011 12:44 am
by ElEctric_EyE
I'll be sure to check ISim out first. Give me 2 days (tue,wed) when I can dedicate 2 full consecutive days to get some results. I also need to check the current timing reports for stated delays...
In the meantime, I would like to pose a question about modifying your core for a few very basic 65C02 clock saving instructions. Instructions like PHX, PHY, PLX, PLY, STZ, and TXY, TYX. I'm a novice 65C02 programmer (experienced MOS 6502), but these are the instructions I've intuitively understood, although TXY and TYX are native to the 65816. If you were to ask a programmer of the original 6502 what these instructions meant, he would know immediately.
What are your thoughts on this? In your opinion, how much effort would be involved for a HDL/Verilog coder to mod your core for these instructions?
Posted: Tue Mar 01, 2011 10:17 pm
by ElEctric_EyE
I tried ISim today. Had difficulty creating a testbench where I could input a O2 frequency and control a reset.
I spent a good deal of time on my 20MHz 65C02 proof(PWA) today just to make sure I had the same 6502 code for it, as inside the 6502SoC. The proof is up and running with the same software as the 6502SoC at this point, except for the RAM banking and EEPROM to SRAM copy.
And at this point, the 6502SoC with the main clock @45MHz, nothing runs, the display doesn't even try to init. When I divide the main clock by 2, for 22.5MHz, the display clears after alot of wrong data, almost like the display is receiving correct data, but A0 is changing, thereby changing display characteristics. When the main clock is divided by 4, for 11.25MHz, it works almost flawlessly. I think tomorrow I will focus on A0 delays.
I am trying to learn about timing constraints and manipulate the text file generated by the constraints editor.
Now I have a single .UCF file where pin assignments and bank voltages were made using PlanAhead, and below a few lines made by using the Timing Constraints App. Still experimenting...
NET "O2" TNM_NET = O2;
TIMESPEC TS_O2 = PERIOD "O2" 22 ns HIGH 50% INPUT_JITTER 100 ps;
NET "O2Out" OFFSET = OUT 9.5 ns AFTER "O2" FALLING;
Observations:
1) The /PROGRAM button does work 100%. The faster speeds were locking the system up. After lowering main clock speeds to 11.25MHz, it works fine.
2) The post simulation max speed for this design was 53MHz.
3) Max delay from O2 to pad was ~9ns.
4) Reset is touchy like it needs debouncing, maybe a simple cap/resister.
5) NMI (RES2) interrupt switch works every time, much less susceptible to bounce. Interesting to note as well, action is not taken until the NMI button is released.
Posted: Wed Mar 02, 2011 12:57 pm
by ElEctric_EyE
I don't know why I kept thinking 45MHz as the default frequency of the DS1085-5. It's 48.58MHz. So rewriting the constraint below (after some other fiddling) worked @ 24MHz! I always seem to have the greatest success in the mornings.
. Now if I can get the display to run @48MHz, I will be very happy indeed.
TIMESPEC TS_O2 = PERIOD "O2" 20.5 ns HIGH 50% INPUT_JITTER 100 ps;
NET "O2Out" OFFSET = OUT 5.5 ns AFTER "O2" RISING;
I was abit premature in my declaration of success 7 hrs ago. I later realized I had a timing constraint error because my 5.5ns "estimated" delay is shorter than the internal delay (as spec'd by ISE), from O2 to pad, of 11.7ns. Although the circuit still worked the best I had so far, it was locking up after some time (<1min)...
After looking over some of my old schematics from the PWA project, I decided to qualify WE from Arlet's 6502 core with O2/2. In addition, instead of an arbitrary 5.5ns, I calculated the actual time I needed to put O2Out in sync with O2, although the display likes an inverted version of O2.
The 6502SoC has been running now for over an hour with no problems @24MHz using this constraint with the schematic below:
NET "O2Out" OFFSET = OUT 19.0 ns AFTER "O2" RISING;
As I am not a timing diag kind of person, I realized in the middle of posting this, that the diagram below is incorrect. The 2 waveforms below O2 are divided by 2 in the schematic. As usual with me, I happen across my successes sometimes by accident. This "accident" will give me insight to pushing for 48MHz, because for sh*ts and giggles I just now tried to run the 6502SoC @48MHz, and it cleared the display. Although repeatability was not there yet, it did more now than previous attempts @48MHz... I'm zeroing in!
Updated schematic:
Note(s) to self: After reading this
post on my 2nd favorite forum, Xilinx forums, Austin Lesea (their principle engineer) comments on jitter value ranges. "...100ps for synchronous design with single clock...", and "...1000ps for... poor bypassing...".
A
video about switch debouncing an FPGA.
A
video about someone with similar ideas to mine using an XC3S400, T65 core, PS/2 interface, and an SDCard interface. Darn I though I would've been the only one, heh!, I'm always behind the power curve... I asked on his video what speed he is running the T65 core. Waiting for response, doubt I'll get any, been posted a year ago...
Posted: Fri Mar 04, 2011 7:45 am
by Arlet
To relax the timing constraints for writing to the display, you could try registering the outputs with an extra layer of flip-flops. This would add an extra clock cycle pipeline delay, but if you're only writing to the display, it shouldn't matter.
Posted: Sun Mar 06, 2011 7:40 pm
by ElEctric_EyE
...but if you're only writing to the display, it shouldn't matter.
Right, now I am only writing to the display. To start, I think I need to increase my jitter spec much higher i think. And finish a correct timing diag. I would have responded earlier, but I've been gone for two days on a short vacation, in the Outer Banks, away from the internet...
I did take ISE In-Depth tutorial and the laptop with ISE 12.3 and the 6502SoC project file. I had intentions of learning about testbenches, but I came across a debounce circuit in verilog and VHDL and how to implement it in a design on (
Pg.23 to Pg. 28).
I followed the directions, but I'm getting an error. I think I'm putting a semicolon in the wrong spot. I really have no clue of proper syntax. Help?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity debounce is
Port ( sig_in : in STD_LOGIC;
clk : in STD_LOGIC;
sig_out : out STD_LOGIC);
end debounce;
architecture Behavioral of debounce is
signal Q1, Q2, Q3 : STD_LOGIC;
begin
process (<clk>)
begin
if (<clk>'event and <clk> = '1') then
Q1 <= sig_in;
Q2 <= Q1;
Q3 <= Q2;
end if;
end process;
sig_out <= Q1 and Q2 and (not Q3);
end Behavioral;
ERROR:HDLParsers:164 - "C:/a/debounce.vhd" Line 35. parse error, unexpected LT, expecting IDENTIFIER or STRING_LITERAL
ERROR:HDLParsers:164 - "C:/a/debounce.vhd" Line 41. parse error, unexpected IF, expecting SEMICOLON
Posted: Sun Mar 06, 2011 7:43 pm
by Arlet
Can you copy/paste the error message you get ?
BTW: if you use the Verilog version, I can help you better. I know almost nothing of VHDL.
Posted: Sun Mar 06, 2011 7:48 pm
by ElEctric_EyE
Yes, they have a verilog example as well. I will try that if you don't see a problem.
I've edited the post, before I knew you had posted. Line 35 is "Process".
Posted: Sun Mar 06, 2011 7:56 pm
by Arlet
One thing I noticed that you have:
and that the example has:
Not sure if that makes a difference.
Posted: Sun Mar 06, 2011 8:04 pm
by HiassofT
process (<clk>)
begin
Q1 <= sig_in;
Q2 <= Q1;
Q3 <= Q2;
end if;
end process;
Replace "<clk>" with "clk", this should fix it (I guess "LT" means "less than" - ISE is really creative when it comes to error messages :-)
Identifiers in VHDL are not case sensitive, so it doesn't matter if you write "std_logic" or "STD_LOGIC".
so long,
Hias
Posted: Sun Mar 06, 2011 8:10 pm
by Arlet
From the tutorial. See 6c.
6. VHDL only: Complete the VHDL module by doing the following:
a. Move the line beginning with the word signal so that it is between the
architecture and begin keywords.
b. Remove the reset logic (not used in this design) by deleting the five lines beginning with if (<reset>... and ending with else, and delete one of the end if;
lines.
c. Change <clock> to clk; D_IN to sig_in; and Q_OUT to sig_out. Note: You can select Edit > Find & Replace to facilitate this. The Find fields appear at the bottom of the Text Editor.
Posted: Sun Mar 06, 2011 8:27 pm
by ElEctric_EyE
Lack of attention to detail on my part.
I had performed a find & replace, and searched for "clock", not "<clock>"...
Yes sirs, it passes syntax now. Thanks!
Now I'll make the debounce symbol and insert it after the reset buttons in the schematic.
Posted: Sun Mar 06, 2011 9:51 pm
by ElEctric_EyE
Made the symbol and put it in the schematic. Tried to wire it up, but it wouldn't connect.
I right clicked on the symbol in the schematic to edit it. Added pins for sig_in, clk, and sig_out. Now it connects ok. I went back to the vhdl file, expecting ISE to have modified it in some way for having added I/O pins, but it didn't...Anyway,
I copied the debounce.vhd file from the laptop to the desktop that's physically connected to the 6502SoC. Right clicked in Hierarchy to add source and added debounce.vhd. Created the debounce symbol and connected it to the inverter before RES (Reset) and RES2 (NMI) in the schematic, using O2/2 as the clk for the debounce symbols. Now nothing works.
Any input appreciated, I'm off now to give the brain a rest until tue&wed.
Posted: Mon Mar 07, 2011 1:10 pm
by HiassofT
Actually, the logic works as a rising-edge-detector: whenever the the input is low @t-3, high @t-2 and @t-1 the output is high for one clock cycle, otherwise it's low.
I don't know the logic behind your RES and NMI inputs, but this might not be the kind of signal you are expecting.
If you want to protect the circuit against single-cycle spikes you could, for example, add a "best-of-3" decoder: The output is high if the input was high for 2 or 3 cycles, otherwise it's low (if the input was low for 2 or 3 cycles).
The logic is quite simple:
sig_out <= (Q1 and Q2) or (Q1 and Q3) or (Q2 and Q3);
But, this is still not optimal. RES and NMI are usually asynchronous signals which means you should run them through a two-stage synchronizer to avoid metastability problems. Currently the logic uses a one-stage synchronizer, if you add another stage (Q0) you should be fine.
Q0 <= sig_in;
Q1 <= Q0;
Q2 <= Q1;
Q3 <= Q2;
end if;
Of course, keep in mind that this logic introduces a 4-cycle latency. This might not be a problem for RES, but could be for NMI.
so long,
Hias
