Acorn Atom PCB
Topics related to older 6502-based hardware and systems including (but not limited to) the MOS Technology KIM-1, Synertek SYM-1, and Rockwell AIM-65.
GrubZero
Acorn Atom PCB
Post by GrubZero »
Hi All.
I have an genuine, unused & unpopulated Acorn Atom PCB that maybe of interest to someone who wants to document the design & / or copy it & get some replica PCB’s made.
I’d be happy to loan the board to someone who wants to do this as long as they cover the postage.
Or, I may consider selling it?
I acquired it many moons ago with the intent of building an Atom from scratch, but, like many things, I never found the time!
Cheers.
Pete.
Re: Acorn Atom PCB
(If it happens that you don't get any interest here, after say a week, you might well find more interest over on the Stardot forums. There's a small but active Atom scene over there.)
Windfall
Re: Acorn Atom PCB
Post by Windfall »
I did. Great fun. Although rounding up all the different parts (all NOS as a matter of principle) was cumbersome.
I probably got the PCB the same way you did.
GrubZero
Re: Acorn Atom PCB
Post by GrubZero »
I probably did!
If I remember correctly, I purchased two PCB’s from a company called Telec Electronics based in the Netherlands.
I think I ordered they’re last two units?!
I wonder where they got them from?
Cheers.
Windfall
Re: Acorn Atom PCB
Post by Windfall »
Same here. Ebay, March 2010, it seems.
From kits that were never built, I suppose. The Atom was my first computer, and at the time they came as a kit or ready built (mine was the latter).
fletch
Re: Acorn Atom PCB
Post by fletch »
Hi Pete,
I sent you a PM. I am working on a redraw of the Atom PCB and would be interested in scans or the board itself.
Fletch
Arlet
Re: Acorn Atom PCB
Post by Arlet »
Ha, I remember building the kit as a teenager, together with my dad. It didn't work, and we didn't know how to fix it, so it sat idly in the bookcase for some time. At some point I remember him shipping it, and getting it repaired.
fletch
Re: Acorn Atom PCB
Post by fletch »
I was saving up for a kit back in 1980 so I've always wanted to build one.
I found some scans of the Atom PCB on the net and have been trying to reproduce the PCB. However, the scans just aren't clear enough and I made a lot of mistakes that I had to correct by hand.
I am having problems getting the prototype working and I still don't know if the problem is a board fault, dodgy components or a construction fault. Having access to a better quality scan or an original board would help.
barnacle
Re: Acorn Atom PCB
Post by barnacle »
I think that the latest version 7 of kicad has a mode in which an image can be used as a template for a PCB layout. At least you'd start with the chips in the right place.
Are you looking to do an exact recreation or e.g. something with modern memory?
fletch
Re: Acorn Atom PCB
Post by fletch »
The plan is to create a reproduction board along the lines of the OSIwebs Superboard II PCBs. I'm trying to duplicate the original layout using a program called Sprint-Layout. This will allow someone with the right chips to make a replica Atom just as if they had ordered a board back in 1980. Once that is done I may make another version that uses modern EPROMs and Cherry keyswitches.
Re: Acorn Atom PCB
(Welcome, fletch!)
rwiker
Re: Acorn Atom PCB
Post by rwiker »
Are the original Atom keyswitches available anywhere? I have two Atoms with a few broken switches each (and most likely some other problems).
fletch
Re: Acorn Atom PCB
Post by fletch »
Which issue of the board do you have? Issue 5 boards use Futaba switches like the BBC Micro and those are still available NOS.
rwiker
Re: Acorn Atom PCB
Post by rwiker »
I believe the two I have use the earlier switches: https://deskthority.net/wiki/MEI_Sabrecoil
fletch
Re: Acorn Atom PCB
Post by fletch »
I wonder if you can 3D print those?
