shopping list
Re: shopping list
allisonlastname wrote:
How do you recommend mapping the hole?
- allisonlastname
Re: shopping list
I've attached a section of a schematic for this,
probably the youngest person on this forum
Re: shopping list
As for programming ROMs, I have an arduino and a raspberry pi. Googling for "arduino eeprom programmer" turns up a lot of results, so I think we're fine there.
Re: shopping list
That was another reason I used a GAL - my systems run at 16Mhz on a simple double sided PCB, but with care, etc. you can go much much faster. I don't feel the need right now.
- floobydust
Re: shopping list
If you think you have to go faster, just use a PLD. My C02 Pocket uses an ATF22V10C and that has much less prop delay.
- allisonlastname
Re: shopping list
Michael wrote:
May I ask which Arduino you have, please? An Uno R3 or Nano perhaps?
Exactly how fast do you plan on running your first system at?
Re: shopping list
I'm aiming for 1mhz. If I can get it reliably working that fast, I might aim for something faster, but I won't be pushing for much above that for a while yet. I only pointed out the design change as an observation, rather than something I was seriously considering.
This:
https://projects.drogon.net/ruby-6502-on-stripboard/
Ran at 16Mhz.
Achieving 1 or 2 Mhz on a breadboard ought to be easy.
- BigDumbDinosaur
Re: shopping list
As designed, your circuit will not work as expected.
You are using Ø2 to qualify chip selects, which is not good design practice. In a 65xx system, chip selection and read/write gating are two separate operations, with the former occurring during Ø2 low and the latter occurring during Ø2 high. Note that everything that occurs during a 65xx bus cycle starts with the fall of the clock.
The MPU drives A0-A15 with a valid address tADS nanoseconds after the fall of Ø2. At that time, the glue logic should decode the address and select the device to be accessed. In particular, chip select and address pins of 65xx peripherals must be valid and stable before the rise of the clock. In your circuit, your 65C22 will not see a chip select until Ø2 goes high and hence will fail to respond.
What does need to be qualified by Ø2 is the write input of non-65xx peripherals, in this case, the SRAM. The data bus cannot be considered valid during Ø2 low and furthermore, the address bus will be briefly unsettled prior to the elapse of tADS. Asserting /WE during that time may result in corruption of RAM contents due to a potential timing race.
Attached is an example of how RAM/ROM and I/O can be controlled in a 65C02 system with three gates and a 3-of-8 decoder. The result is a maximum of 48K of RAM and 12 K of ROM, plus up to 8 I/O devices. This circuit has been tested at 20 MHz.
- allisonlastname
Re: shopping list
Ok, I've done everything except clock generation. Let me know if there's any issues with the design.
- Attachments
- nearly_there.pdf
- (263.32 KiB) Downloaded 123 times
Re: shopping list
Would I be out-of-line suggesting a couple parts changes? Unless you already have 62256 RAM and 28C256 EEPROM IC's, you might consider using a 64K or 128K RAM IC and a 39SF010A Flash ROM IC instead. A new AT28C256 costs $12+ compared to $3+ for a new 39SF010A and a new 128K RAM IC like the AS6C1008 is almost the same price as a new 32K 62256. Also, you could get a 5-pack of skinny 64K W24512AK-15 RAM IC's for about $3.50 (including shipping) from a vendor on AliExpress.
IMO, the 39SFxxx series Flash ROM's are easier to program and the extra active high chip select on 64K / 128K RAM IC's is quite handy but these chips will take up more room on a breadboard or a PCB.
Good luck. Cheerful regards.
- BigDumbDinosaur
Re: shopping list
A few things and you should be ready to build:
- You are mixing logic families. VOH in TTL (i.e., 74LS) logic is a guaranteed 2.4 volts, with a theoretical maximum of 3.4. A CMOS logic 1 is typically VCC × 0.7 volts, which is higher than the capabilities of TTL logic. While it probably will work okay, there is no guarantee it will.
- /OE on the ROM should be connected to the same circuit to which /OE on the SRAM is connected.
A sneaky benefit of gating /OE on Ø2 high is that the ROM will inject milder transients into the power supply circuit than it would if simultaneously selected and enabled. Also, the ROM will get off the data bus more quickly if /OE is enabled only when Ø2 is high. In this circuit, that is not a critical requirement. However, it may become so when you build your next design and decide to amp up the clock. - Add a 3.3K pullup resistor to your reset circuit. The DS1813’s internal pullup is weak and relying only on it to keep reset high may make your reset circuit noise-sensitive.
- You have your Ø2 circuit connected to the 65C02’s Ø2 output. WDC advises against doing so in new designs. They recommend that everything should be driven by the clock oscillator.
A problem with using the C02’s clock outputs is they lag the clock input (Ø0) by an unspecified amount, hence subtle timing errors could be introduced with any device slaved to the clock, e.g., the 65C22. WDC no longer tests Ø1 out and Ø2 out and doesn’t guarantee their behavior. These outputs are present only to provide backward compatibility in systems in which the NMOS 6502 is to be replaced with a 65C02. Modern HCMOS clock oscillators have more than enough fan-out to handle all reasonable loads. - Note that the 65C22S has a totem-pole IRQ output—which can’t be wired OR. While that is of no concern in this design, it is something to keep in mind in a future design in which more than IRQ source is present.
- I recommend you connect NMI and SOB to VCC through 3.3K pullup resistors so those inputs can be put to use. In my POC units, I have a DS1813 attached to NMI so I can manually interrupt a running program that has gotten stuck in a loop.
SOB can be used as a high-speed input, which may be of some value.
- allisonlastname
Re: shopping list
- BigDumbDinosaur
Re: shopping list
Can you please post that in monochrome? I’m partially colorblind and can’t make out all of what is in your graphic.
- allisonlastname
Re: shopping list
This better?
- Attachments
- 2023-04-02_23-57_gray.png (7.45 KiB) Viewed 8209 times
- GARTHWILSON
- Forum Moderator
Re: shopping list
Is phi2 the inverse of phi0?
