I feel that SEE can be a useful tool if, instead of attempting to show the source of a Forth word, it shows what actually got compiled. Here are my criteria for a useful SEE:
1 Display what was compiled for Forth words and code words.
2 Recognize the built in data types ( VARIABLE , CONSTANT , 2VARIABLE , 2CONSTANT , and USER ) and display their values.
3 Display a DEFERed word's vector ( the word a DEFERed word is set to execute) .
4 Transition seamlessly from decompiling/disassembling High level code to Low level and back. For example:
SEE 2CONSTANT
2CONSTANT
2F0E CREATE
2F10 ,
2F12 ,
2F14 DOES
2F16 2429 JMP ' DOES> >BODY 15 +
2F19 2@
2F1B EXIT
OK
SEE CONSTANT
CONSTANT
23CF CREATE
23D1 ,
23D3 DOES
23D5 2 # LDY
23D7 FE )Y LDA W
23D9 PHA
23DA INY
23DB FE )Y LDA W
23DD 838 JMP PUSH
OK
SEE DEFER
DEFER
23A6 CREATE
23A8 LIT 237C
23AC ,
23AE DOES
23B0 2 # LDY
23B2 FE )Y LDA W
23B4 PHA
23B5 INY
23B6 FE )Y LDA W
23B8 FF STA W 1+
23BA PLA
23BB FE STA W
23BD 0 # LDY
23BF FD JMP W 1-
OK
5 SEE is just a wrapper word for (SEE) so (SEE) can take a CFA from the data stack.
: SEE ( -- ) ' (SEE) ;
7 Defined with helper words :DIS and DIS that decompile : ( colon) definitions and code definitions respectively. In some situations, the ones that 'trip up' SEE , it is useful to decompile a Forth word starting on a word boundary, inside the body of the definition, with :DIS ,or disassemble a low level word starting on an instruction boundary, with DIS . This example is a partial disassembly of FIND , the high level word that uses (FIND) and VFIND , the find primitives.
2091 :DIS
2091 CURRENT
2093 @
2095 VFIND
2097 EXIT
OK
SEE FIND
FIND
2087 CONTEXT
2089 @
208B (FIND)
208D ?DUP
208F ?EXIT
2091 CURRENT
2093 @
2095 VFIND
2097 EXIT
OK
: DONE? ( -- F )
?KEY DUP 0EXIT
3 = ?DUP ?EXIT
KEY 3 = ;
: SOME.FORTH.WORD
BLAH BLAH BLAH
BEGIN
BLAH BLAH BLAH
TEST.CONDITION DONE? OR
UNTIL
BLAH BLAH ;
A SEE written with these criteria in mind, along with DUMP , a word to display memory contents, can be a useful tool when performing a 'postmortem' after an attempt to add some new feature to one's Forth fails.
Jim
