It is currently Fri Nov 22, 2024 2:10 am
 Post subject: 16 bit subtraction
PostPosted: Tue Mar 14, 2023 7:29 pm
Hey guys, this is likely a noob question, but Ive seen some other 16 bit subtractions that dont seem to take into account a rollover. What I mean is:
C000: 01 FF
If I subtract $05, and the carry is set, then i know I can DEC $C001. But if its zero, I cant. So my subtraction code is no good, since im using BCS.
The most Id be adding or subtracting is less than 256, so its going to only be a single byte. Can someone show some code for this (apparently pretty simple) issue?
 Post subject: Re: 16 bit subtraction
PostPosted: Tue Mar 14, 2023 8:27 pm
It's not very clear what you mean here—which might be why you're having problems.  Subtracting 5 from 1 or 0, either way, regardless of what the C flag was when you started, will end up with it clear (because 1-5, or 0-5, either way, had to borrow), and your BCS will be correct, to branch, or not branch, around the DEC $C001, to whatever the next lower number is, regardless of rollover, like from $FF to $FE, or 00 to $FF.
PostPosted: Tue Mar 14, 2023 8:46 pm
Looks like you're subtracting an eight-bit value from a sixteen bit minuend, no?
Why not just subtract zero from the second byte, irrespective of the carry value? It'll all sort itself out.
Or are you desperate for space or speed?
   lda $c000
   sbc #5
   sta $c000
   lda $c001      ; 4 cycles
   sbc #0         ; 2 cycles
   sta $c000      ; 4 cycles
   lda $c000
   sbc #5
   sta $c000
   bcs label      ; 2 cycles
   dec $c001      ; 6 cycles
label:
I would submit that while the first version is both smaller and faster, it more clearly shows your intent. Unless I've misunderstood you.
PostPosted: Tue Mar 14, 2023 9:57 pm
Correct. Subtracting an 8 bit number from a 16.
Looking at your examples, i think i see my issue. Im putzing around with the carry flag, doing a SEC before the SBC, etc. Seems your code works without worrying about the carry.
Im still scratching my head though trying to understand why subtracting 0 from the second byte ($FF) results in $FE
PostPosted: Tue Mar 14, 2023 10:21 pm
If any Commodore 128 users (or VICE) would like to see what Im working on:
https://github.com/Commodore64128/ataripac128
Movement is still a bit wrong.. its taking me some time to figure things out.
PostPosted: Tue Mar 14, 2023 10:41 pm
That seems to be a small booboo on barnacle's part, xlar54.
(I know what kind of dodgy excuses I make when I slip up, but in this case I'll leave Neil to deal with the matter himself! :wink: )
Unless the programmer has reason to be sure Carry is already set, there needs to be a SEC somewhere before the first SBC.
        sec
        lda $c000
        sbc #5
        sta $c000
        sbc #0         ; 2 cycles
        lda $c000
        sec
        sbc #5
        sta $c000
label:
You need to review the exact definition of what the SBC instruction does, and how it enables multi-byte subtract operations. (It might be helpful to firstly review how the ADC instruction enables multi-byte addition operations.
PostPosted: Tue Mar 14, 2023 10:42 pm
xlar54 wrote:
I'm still scratching my head though trying to understand why subtracting 0 from the second byte ($FF) results in $FE
The carry flag being clear is the same as a borrow flag (if such a flag existed) being set; so $FF, minus 0, minus 1 for the borrow, is $FE.
PostPosted: Wed Mar 15, 2023 6:12 am
Oh, of course the carry should be set before the start of a subtraction chain; er, er, I just didn't want to clutter up the discussion. Yes, that's it. Or a big boy did it and ran away. Um. Or cosmic rays?
Also, the line
should read
I would submit that the second version is both smaller and faster, the first more clearly shows your intent.
Here I go again, contributing to the total amount of wrong on the internet! Obviously I shouldn't post late at night.
(When I had to work with PIC assembly ten or a dozen years ago, I had to do multi-precision arithmetic. The PIC didn't have add-with-carry or subtract-with-borrow and as a result the carry had to be rippled through after every addition/subtraction. At the time, *every* example on the net with the sole exception of a single Microchip datasheet got that wrong...)
Though with my statement 'shows intent' I suspect that many of the code writers here would agree with this premise: optimising too early is always a bad idea. In initial code, write for clarity of intent and simplicity of logic; that way you will have more chance of remembering what it's supposed to do when you come back to it in six months, or next week. Come up with clever tricks to optimise code length or clock cycles if and only if it turns out to be necessary, or aesthetically desirable.
Users browsing this forum: Google [Bot] and 13 guests
