65C02 in PLCC - pinout differences with Rockwell vs WDC
A useful learning experience reported in the steckschwein project: Rockwell's 65C02 in PLCC has a slightly different pinout from WDC's offering.
In this case, the Rockwell parts were relabelled as WDC, and sold as WDC, which is the sort of thing we discuss often enough, as a risk when buying from marketplaces.
- GARTHWILSON
- Forum Moderator
Re: 65C02 in PLCC - pinout differences with Rockwell vs WDC
Wow! That (the difference in pinout) is a whole lot more serious than the situation with the DIPs!
- BigDumbDinosaur
Well, that sucks! Fortunately, it seems likely nothing else on the board was damaged.
Once again, I must remind everyone that the only safe sources for genuine WDC product are their authorized distributors. With a few exceptions, that does not include eBay sellers.
ArnoldLayne
And yes, that one hit very hard after hours of debugging. Also, debugging is still in progress as the wrong CPU is not the only problem with the new board.. a long way indeed.
- BigDumbDinosaur
I went to revisit that page to refresh my memory on what happened and instead got a 404.
ArnoldLayne
- BigDumbDinosaur
That’s why the good Lord gave us logic probes, oscilloscopes and coffee (sorry, tea just doesn't cut it).
ArnoldLayne
Fortunately, we are already a little bit further as we discovered the /OE signal is somehow off. Which is the reason the CPU is reading garbage from the EEPROM.
/OE is generated by the CPLD, so at least this shoud be fixable without making a new board..
(If you haven't yet looked into @hoglet's 6502 protocol decoder, I recommend you do so. For some kinds of bugs, it's just the thing.)
- BigDumbDinosaur
In what way is /OE “off?” Is this a timing issue?
ArnoldLayne
ArnoldLayne
ArnoldLayne
And that's where I screwed up. The experienced viewer will notice that I tied the /CE pin for the data bus buffer to ground, having it drive the bus when r/w is high.
That's what you get for skipping the breadboarding part.
- BigDumbDinosaur
A little bump. I periodically look at the Steckschwein project to see how it’s coming along. Only thing is reading the schematics is tough with all that color.
