Fleet Forth design considerations
Re: Fleet Forth design considerations
The only problem I had with the name 2PICK was the possibility of it being mistaken for the double number version of PICK . I think DPICK is a better name for the double number version of PICK .
I like that the name 2PICK describes what it is doing just as the name DUP>R describes what it is doing.
2PICK performs 2 PICK
DUP>R performs DUP >R
If I needed to perform 3 PICK often enough to justify writing a primitive, there would be no verbal confusion with the name 3PICK , unlike the name FOURTH in your example.
- GARTHWILSON
- Forum Moderator
Fleet Forth's LIT no longer falls through to NEXT and it was rewritten so it no longer has the functionality of PUSH or PUT , which made the combined size of LIT and CLIT smaller. For those new to Forth, Some Forth's for the Commodore 64 have an address in the kernel, PUSH , where a code word pushes the low byte to the return stack, places the high byte in the accumulator and jumps to PUSH (in these Forths, PUSH is a constant in the assembler). The code at PUSH would push the value onto the data stack. PUT is similar but the value overwrites the current top of stack. An excerpt from the source for Fleet Forth's previous kernel.
LABEL PUSH
DEX DEX
LABEL PUT
1 ,X STA PLA 0 ,X STA
LABEL NEXT
Fleet Forth has AYPUSH , which takes the low byte in the accumulator and the high byte in the Y-register and pushes that value onto the data stack. AYPUT is similar but the value overwrites the current top of stack. An excerpt from the source for Fleet Forth's current kernel.
LABEL APUSH
0 # LDY
LABEL AYPUSH
DEX DEX
LABEL AYPUT
1 ,X STY 0 ,X STA
NEXT JMP
This excerpt is from the source for Fleet Forth's (FIND) , so both sets of operations were supported in the previous kernel. With the changes to Fleet Forth's kernel, I've tried to remove the dependencies on PUSH and PUT . Some primitives were relatively easy to change without increasing the code size.
CODE UD/MOD ( UD1 U1 -- U2 UD2 )
DEX DEX
2 ,X LDA N 2+ STA 0 ,X STA
3 ,X LDA N 3 + STA 1 ,X STA
2 ,X STY 3 ,X STY
' UM/MOD @ 6 + JSR
1 ,X LDA PHA \ swapped these
0 ,X LDA PHA \ two lines
N 2+ LDA 0 ,X STA
N 3 + LDA 1 ,X STA
' UM/MOD @ 6 + JSR
' R> @ JMP END-CODE
I swapped the order the bytes were pushed to the return stack and replaced the PLA and jump to PUSH with a jump to the body of R> . I did the same thing with ROLL .
CODE ROLL
0 ,X LDA
POP.JMP 0= BRAN
XSAVE STX .A ASL TAY
XSAVE ADC
// POP.JMP 0< BRAN
TAX INX INX
1 ,X LDA PHA 0 ,X LDA PHA
BEGIN
$FF ,X LDA 1 ,X STA
DEX DEY
0= UNTIL
' R> @ 2+ JMP END-CODE
By the way, POP.JMP is a label in the header-less word TRAVERSE .
NH
CODE TRAVERSE ( ADR1 DIR -- ADR2 )
BEGIN
CLC
0 ,X LDA 2 ,X ADC 2 ,X STA
1 ,X LDA 3 ,X ADC 3 ,X STA
2 X) LDA
0< UNTIL
LABEL POP.JMP
POP JMP END-CODE
I took a different approach with @ . This is the original source.
CODE @ ( ADR -- N )
0 X) LDA PHA 0 ,X INC
0= IF 1 ,X INC THEN
0 X) LDA
PUT JMP END-CODE
And here is the new source.
CODE @ ( ADR -- N )
0 ,X LDA N STA
1 ,X LDA N 1+ STA
LABEL (N)PUT
N )Y LDA 0 ,X STA INY
N )Y LDA 1 ,X STA
NEXT JMP END-CODE
Six bytes bigger and slightly faster than the original in the previous kernel; however, BLOCK , which starts out as a code word, is six bytes smaller because it now has a jump to the label (N)PUT in @ .
A few days ago I got an idea that I thought was either clever or mad. I thought what if I replace N in @ and BLOCK with W ?
I could change CONSTANT from this:
: CONSTANT ( N -- )
CREATE , ;CODE ( -- N )
LABEL DO.CONSTANT
2 # LDY
W )Y LDA PHA INY
W )Y LDA
PUSH JMP END-CODE
to this:
: CONSTANT ( N -- )
LABEL DO.CONSTANT
2 # LDY
DEX DEX
(W)PUT JMP END-CODE
This would save 4 bytes and remove one more reference to PUSH . The loop index word, I , is the last place where PUSH is referenced. In the new kernel it is:
CODE I ( -- LOOP-INDEX )
XSAVE STX TSX CLC
$101 ,X LDA $103 ,X ADC PHA
$102 ,X LDA $104 ,X ADC
XSAVE LDX
LABEL PUSH
TAY PLA AYPUSH JMP END-CODE
Now that CONSTANT doesn't need to jump to PUSH , it can be coded as this:
XSAVE STX TSX CLC
$101 ,X LDA $103 ,X ADC TAY
XSAVE LDX
DEX DEX
1 ,X STA 0 ,X STY
NEXT JMP END-CODE
It's 4 bytes bigger than the version in the new kernel and 5 bytes bigger than the version in the previous kernel, but it's faster.
Using my convention, it would be 2&PICK that performs 2 PICK and DUP&>R that performs DUP >R. The ampersand has a special significance that's recognized by the reader, making it clear what's going on.
Parenthetically: I recall musing that the ampersand could be more than just a hint to the human. Based on the ampersand, the compiler could quite easily be given an extra level of FINDing capability.
The premise is: the source code might be from some other time or place, and might include a compound word that's not implemented on that particular Forth system. For example, imagine 2&PICK is encountered in the source, but the word isn't found. The name would be scanned and any ampersands replaced by spaces. Then, one by one, we'd FIND the now-unglued constituent pieces! The compiler adapts to the unfamilar compound word.
But the benefit is modest.
- GARTHWILSON
- Forum Moderator
Hmmm... I just had a thought, and looked at the IBM437 character set I use, and character $FF also displays as a blank, so maybe I could have Forth words that have a non-breaking space in them. It could be confusing though, LOL.
After rewriting Fleet Forth's CONSTANT I started thinking about 2CONSTANT . In Fleet Forth, 2CONSTANT is a CREATE DOES> word. For just 9 more bytes, it can be a CREATE ;CODE word.
Here is the source for 2CONSTANT .
: 2CONSTANT ( D -- )
CREATE , ,
DOES> ( -- D )
2@ ;
And here is the source for a CREATE ;CODE version.
CREATE
;CODE ( -- D )
DEX DEX
4 # LDY
W )Y LDA 0 ,X STA INY
W )Y LDA 1 ,X STA
DO.CONSTANT JMP END-CODE
DO.CONSTANT is a metacompiler label in the source for CONSTANT .
: CONSTANT ( N -- )
LABEL DO.CONSTANT
2 # LDY
DEX DEX
(W)PUT JMP END-CODE
: VALUE ( N -- )
CONSTANT ;CODE ( -- N )
DO.CONSTANT JMP
END-CODE
I just don't know if 2CONSTANT would be used often enough to justify the change. I haven't found a single instance of a double constant in my own code.
I'm so used to using >FORTH when I want to run high level Forth in a primitive that I overlooked a case where it was not necessary.
Here is the source for Fleet Forth's EXECUTE .
CODE EXECUTE ( ADR -- )
0 ,X LDA 1 ,X LDY
INX INX
LABEL (EXECUTE)
W STA W 1+ STY
0 # LDY
W 1- JMP END-CODE
Because the Y-register needs to be set back to zero, it is two bytes larger than a version which does not use it. EXECUTE is defined like this because R/W has two places where it branches six bytes into the body of EXECUTE to the code following the metacompiler label (EXECUTE) . The Accumulator and Y-register hold the low and high bytes respectively of the word to execute (a pair of deferred words) without returning to R/W.
The word (T&S) is defined in the system loader. It is smaller as a code word than as a high level word.
CODE (T&S) ( ADR BLK# -- S/T ADR S T D DSI )
DRB LDY DPT ,Y LDA
0< IF
>FORTH T&S81 EXIT
>ASSEM -2 ALLOT
THEN
>FORTH T&S41 ;
' (T&S) IS T&S
This extends T&S so it supports blocks on the Commodore 1581 drive as well as the 1541 and 1571.
Each place where I've used >FORTH only needs to execute one word then exit, and not a longer high level Forth thread. I can use Fleet Forth's EXECUTE just as I did in R/W. The destination address for JMP is six bytes into the body of EXECUTE .
DRB LDY DPT ,Y LDA
0< IF
' T&S81 SPLIT SWAP
# LDA # LDY
' EXECUTE @ 6 + JMP
THEN
' T&S41 SPLIT SWAP
# LDA # LDY
' EXECUTE @ 6 + JMP
END-CODE
' (T&S) IS T&S
The SWAP after SPLIT is personal preference. I like to load the Accumulator before the Y-register if they hold two bytes of a 16 bit value. SWAP could be left off and this line:
# LDA # LDY
would be:
# LDY # LDA
This version of (T&S) is the same size but faster.
This is what the disassembly looks like:
(T&S)
16015 2252 LDY ' DRB >BODY
16018 10000 ,Y LDA ' DPT >BODY
16021 16030 BPL
16023 55 # LDA
16025 62 # LDY
16027 3873 JMP ' EXECUTE >BODY 6 +
16030 234 # LDA
16032 39 # LDY
16034 3873 JMP ' EXECUTE >BODY 6 +
22
Commodore 64 drives start at device 8 and go up from there. My setup (a simulation on VICE) has three disk drives. Device 10, the third drive, is a 1581. In the drives property table DPT , that would be entry 2, so this line sets device 10 to a Commodore 1581 drive for block access.
$83 DPT 2+ C!
To summarize: With Fleet Forth's version of EXECUTE , when a word which isn't a primitive needs to be effectively branched to, it is more efficient to use EXECUTE than >FORTH .
Interesting muse, indeed! I did think of a case where granting the ampersand special powers might not be such a good idea. Some Forths have the word T&S to map a block to the initial track and sector for that block. Suppose Forth source with T&S is loaded on a system without this word. This system does; however, have two unrelated words, T and S .
Fleet Forth has the following control flow manipulation words:
CS-DUP
CS-DROP
CS-SWAP
CS-ROT
as well as a pair of words to transfer control flow data to and from the auxiliary stack.
These four were chosen over AnsForth's CS-PICK and CS-ROLL because they are code words without bodies. They are immediate aliases for the following.
2DUP
2DROP
2SWAP
2ROT
The inclusion of CS-DROP allows defining a word such as AFT without knowing the number of cells used for control flow data. Drop the control flow data for a backward branch and the branch is not compiled. Drop the control flow data for a forward branch and the new word could crash the system. On the Forth-83 systems I've seen, a BRANCH to address zero is compiled because >MARK is usually defined as the following (when it doesn't add the compiler security data)
: >MARK ( -- ADDR )
HERE 0 , ;
and IF , for example, is defined with >MARK .
: IF ( flag -- )
( -- sys ) \ compiling
COMPILE ?BRANCH
>MARK <possible compiler security data> ; IMMEDIATE
The Forth-83 Standard states:
>MARK -- addr C,83 "forward-mark"
Used at the source of a forward branch. Typically used
after either BRANCH or ?BRANCH . Compiles space in the
dictionary for a branch address which will later be resolved
by >RESOLVE .
so >MARK could even have this definition.
: >MARK ( -- ADDR )
HERE 2 ALLOT ;
The following will compile successfully. Depending on how >MARK is defined, it may crash at run time.
: CRASH
FALSE
IF CS-DROP ;
This trivial example reveals a potential problem. Trying to implement tricky control flow mechanisms and not quite getting it right, or being careless with existing control flow structures, such as trying multiple uses of AFT in a FOR NEXT loop could also cause the compilation of a branch to a non valid address.
Why does >MARK comma a zero in the dictionary on some systems? It's a place holder, obviously. Why zero?
I'm going to try the following with the next build of Fleet Forth's kernel.
NH
CREATE BAD.BRANCH
] TRUE ABORT" BAD BRANCH" [
: >MARK ( -- ADR 1 )
HERE 1 BAD.BRANCH , ;
NH (no header) is a metacompiler word which causes the next target word to be headerless. The name can be found while metacompiling, but will not be in the target system. The 1 in this definition of >MARK is because Fleet Forth compiler security is handled by the words >MARK >RESOLVE <MARK and <RESOLVE to keep it minimal so it stays out of the way of the programmer as much as possible. BAD.BRANCH is just a code field which, like all variables, points to its body. The body is just a fragment of threaded code which aborts every time with the message "BAD BRANCH", although any meaningful message could be used.
This is the address >MARK will compile rather than zero. The error isn't caught at compile time, but it is at run time.
The Forth-83 Standard does not specify what is to be compiled for the place holder. It's an extra one to two dozen bytes, depending on the length of the error message. There is no additional overhead and no extra restrictions. This may be a worthwhile addition to any Forth-83 Standard system meant to be used by more than just the author of said system, especially if it's used by someone who likes to experiment in Forth.
I presented the code for a primitive version of CO .
As I was looking at the source for Fleet Forth's subroutine, (>FORTH) , I realized how similar it is to the primitive version of CO . They both swap the top address on the return stack with the address in IP with one difference. Since the JSR instruction saves the return address-1, (>FORTH) adds one to the return stack address before storing it in IP . A little rearranging of the code for (>FORTH) from this
SUBR (>FORTH) ( -- )
CLC
PLA 1 # ADC N STA
PLA 0 # ADC TAY
IP 1+ LDA PHA
IP LDA PHA
N LDA
IP STA
IP 1+ STY
NEXT JMP END-CODE
to this
CLC
PLA 1 # ADC TAY
PLA 0 # ADC N STA
IP 1+ LDA PHA
IP LDA PHA
N LDA
IP STY
IP 1+ STA
NEXT JMP END-CODE
and I can shorten it without making it slower since EXIT falls through to NEXT , the address interpreter.
CLC
PLA 1 # ADC TAY
PLA 0 # ADC
LABEL (CO)
N STA
IP 1+ LDA PHA
IP LDA PHA
N LDA
IP STY
' EXIT @ 4 + JMP
END-CODE
I've also place a metacompiler label just before N STA .
I can now shorten CO from this:
// CO -- COROUTINES
CODE CO ( R: ADR1 -- ADR2 )
( IP: ADR2 -- ADR1 )
PLA TAY PLA N STA
IP 1+ LDA PHA
IP LDA PHA
IP STY N LDA
' EXIT @ 4 + JMP
END-CODE
to this:
// CO -- COROUTINES
PLA TAY PLA
(CO) JMP END-CODE
I haven't tested this yet, I saw this last night and it was getting late.
I realize it looks strange to assemble a JSR to a subroutine which jumps to NEXT rather than returning. It's the only way to get the address to store into IP to start high level Forth.
This technique is also used by Fleet Forth's COLD and WARM start routines to begin high level Forth.
I also realized that if the pair JSR RTS used the actual return address, I wouldn't even need the subroutine (>FORTH) , just the primitive version of CO. >FORTH need not have been this:
ASSEMBLER
: >FORTH ( -- )
?EXEC
(>FORTH) JSR
[ FORTH ]
CURRENT @ CONTEXT !
] ; IMMEDIATE
It could have been this:
ASSEMBLER
: >FORTH ( -- )
?EXEC
[ ' CO @ ] LITERAL JSR
[ FORTH ]
CURRENT @ CONTEXT !
] ; IMMEDIATE
I came across the word NUF? in an article from around 1986. It has similar functionality to Fleet Forth's DONE? . Here is how NUF? would be defined in Fleet Forth.
: NUF? ( -- F )
?KEY DUP 0EXIT
DROP
KEY 3 = ;
Compared to Fleet Forth's DONE?
: DONE? ( -- F )
?KEY DUP 0EXIT
3 = ?DUP ?EXIT
KEY 3 = ;
NUF? is three cells smaller and it works a little differently. The number 3 is the Petscii code returned by the C64's RUN/STOP key.
If no key was pressed, DONE? exits returning a false flag.
If the RUN/STOP key was pressed, DONE? exits returning a true flag.
If any other key was pressed, DONE? waits for a key press. It returns a true flag if the RUN/STOP key is pressed. For any other key, it returns a false flag.
If no key was pressed, NUF? also exits returning a false flag.
If any key was pressed, it doesn't matter if it was the RUN/STOP key, NUF? waits for a key press. It returns a true flag if the RUN/STOP key is pressed. For any other key, it returns a false flag.
I will discuss Fleet Forth's control flow words built around the branch primitives BRANCH and ?BRANCH which use the following words to mark and resolve an address.
<MARK ... <RESOLVE
>MARK ... >RESOLVE
BRANCH is followed by an inline address. It always branches to this address. ?BRANCH is also followed by an inline address. If the top element of the data stack is zero, It will branch to this address. If not, it will increment IP , Forth's instruction pointer, past this inline address.
Fleet Forth's control flow words are like building blocks. Other than the DO LOOPs, there are six fundamental control flow words.
BEGIN
AGAIN
UNTIL
IF
AHEAD
THEN
BEGIN marks the target of a backward branch which is resolved by AGAIN or UNTIL . AGAIN compiles BRANCH and UNTIL compiles ?BRANCH . AGAIN and UNTIL resolve the address placed on the stack by BEGIN or any other word which uses <MARK .
IF and AHEAD are for forward branches and leave an address to be patched by THEN. IF compiles ?BRANCH and AHEAD compiles BRANCH. THEN resolves the address from a single IF , a single AHEAD or any word which uses >MARK .
Here are the control flow structures possible with these six words.
BEGIN ... AGAIN
BEGIN ... UNTIL
IF ... THEN
AHEAD ... THEN
If a branch word which branches on true is added, there would be two more fundamental control flow words.
NIF
NUNTIL
or something similar. The prospective names are irrelevant for this post. There would be two more control flow structures.
BEGIN ... NUNTIL
NIF ... THEN
Fairly simple and seemingly limited; however, these six words plus immediate versions of DUP DROP SWAP and ROT for the control flow stack can be used to build all the other control flow words. These control flow stack manipulators are CS-DUP CS-DROP CS-SWAP and CS-ROT . Since there is compiler security (a single number on top of the address), each element of the control flow stack is a double number. Fleet Forth's control flow stack is the data stack, which means the control flow stack manipulators are aliases. They have no bodies of their own, each one's code field points to the body of the word it is aliasing.
CS-DUP is an alias for 2DUP
CS-DROP is an alias for 2DROP
CS-SWAP is an alias for 2SWAP
CS-ROT is an alias for 2ROT
The other control flow words can be built from these fundamental control flow words.
WHILE is just IF CS-SWAP
: WHILE ( CS1 -- CS2 CS1 )
[COMPILE] IF [COMPILE] CS-SWAP ; IMMEDIATE
In Fleet Forth it's defined like this.
[COMPILE] IF 2SWAP ; IMMEDIATE
REPEAT is AGAIN THEN
: REPEAT ( CS2 CS1 -- )
[COMPILE] AGAIN [COMPILE] THEN ; IMMEDIATE
BEGIN ( begin.cs )
WHILE ( if.cs begin.cs )
AGAIN ( if.cs ) \ BEGIN was resolved
THEN ( -- ) \ IF (within WHILE) was resolved
REPEAT combines AGAIN and THEN in a single word. Multiple WHILEs can be in a BEGIN loop, but each one needs resolved by a THEN . It wasn't until after Fleet Forth's WHILE and REPEAT were implemented that I found I had inadvertently achieved Ansi compliance with their implementation. Sometimes conforming to multiple standards just happens.
ELSE is just AHEAD CS-SWAP THEN
: ELSE ( CS1 -- CS2 )
[COMPILE] AHEAD [COMPILE] CS-SWAP [COMPILE] THEN ; IMMEDIATE
Or as it's defined in Fleet Forth.
[COMPILE] AHEAD 2SWAP [COMPILE] THEN ; IMMEDIATE
ELIF is IF CS-SWAP THEN
: ELIF ( CS1 -- CS2 )
[COMPILE] IF 2SWAP [COMPILE] THEN ; IMMEDIATE
In Fleet Forth two bytes are saved by defining ELIF as this.
[COMPILE] WHILE [COMPILE] THEN ; IMMEDIATE
IF ( if.cs )
ELSE ( ahead.cs ) \ IF was resolved
THEN ( -- ) \ AHEAD (within ELSE) was resolved
When the auxiliary stack is loaded, there are two more control flow stack manipulation words.
CS>A moves control flow data to the auxiliary stack.
A>CS moves control flow data from the auxiliary stack.
I recently read an article about Forth control structures in the July 1986 issue of Dr Dobbs Journal. The article was "A Forth Standards Proposal: Extended Control Structures" by George W Shaw II. The author sites what he believes are five shortcomings in Forth's control structures. I find his proposed solution overly complex.
The first three shortcomings concern LEAVE . To paraphrase the author: The standard control structures can't handle multiple LEAVEs without retesting the exit condition, nor the loop termination separately from LEAVE , nor can LEAVE exit through multiple levels of DO LOOPs.
One of the author's proposed extensions.
DO IF LEAVES ... LOOP THEN
Apparently, LEAVES has a built in THEN and the THEN after LOOP resolves the branch from LEAVES .
The Forth-83 Standard LEAVE can't do this; however, the Standard IF along with UNLOOP AHEAD and an auxiliary stack can.
DO IF UNLOOP AHEAD CS>A THEN ... LOOP A>CS THEN
or without AHEAD
DO IF UNLOOP ELSE CS>A THEN ... LOOP A>CS THEN
Fleet Forth's BLOCK branches out of a ?DO LOOP .
CODE BLOCK ( BLK -- ADR )
DEY
BLK/BUF STY
' MRU >BODY LDA W STA
' MRU >BODY 1+ LDA W 1+ STA
6 # LDY
W )Y LDA 0 ,X CMP
0= IF
INY W )Y LDA 1 ,X CMP
0= IF
INY (W)PUT JMP
THEN
THEN
>FORTH
#BUF 1+ 2
?DO
DUP I >BT @ =
IF
DROP I UNLOOP
AHEAD CS>A
THEN
LOOP
LRU 2+ 2+ @
IF
LRU 2@ 0 B/BUF R/W
LRU 2+ 2+ OFF
THEN
BLK/BUF C@
IF
LRU ON
LRU 2+ @ OVER 1 B/BUF R/W
THEN
LRU ! #BUF
A>CS THEN
DUP >BT MRU 6 CMOVE
MRU 1 >BT ROT 6 * CMOVE>
MRU 2+ @ ;
Here is an explanation for what it is doing.
DEY \ store $FF in zero page location BLK/BUF.
\ BUFFER's cfa points to the following.
BLK/BUF STY \ BUFFER will store a zero at BLK/BUF.
if the requested block is the most recently used,
replace the block number with the buffer address for that block
ends with a jump to an address which jumps to NEXT.
if the requested block is not the most recently used
>FORTH \ transition to high level Forth.
#BUF 1+ 2
?DO
search buffer table for matching block number.
if it's found, drop the block number
and branch out of the loop with the index.
IF
DROP I UNLOOP
AHEAD CS>A \ save control flow data to the auxiliary stack.
THEN
LOOP
it's not in the buffer table.
save the least recently used block to mass storage.
BLK/BUF C@ \ is this BLOCK or BUFFER?
if this is block, read in the requested block.
LRU ! #BUF \ store block number in the table
\ at the entry for the least recently used block.
\ and place the address for this entry on the stack.
A>CS THEN \ resolve the branch from the loop.
the stack now has the number for the table entry
with the desired block.
move that entry to the top of the buffer table
and slide the others down.
place the buffer address of that block on the data stack.
As for simply exiting a word from within a DO LOOP nested within another DO LOOP
DO
<DO-SOMETHING>
DO
<DO-SOMETHING> <TEST>
IF
UNLOOP UNLOOP EXIT
THEN
<DO-SOMETHING>
LOOP
<DO-SOMETHING>
LOOP
As for branching out of a nested BEGIN loop
BEGIN
<DO-SOMETHING>
BEGIN
<DO-SOMETHING> <TEST0>
IF CS>A
<DO-SOMETHING> <TEST1>
UNTIL
<DO-SOMETHING> <TEST2>
UNTIL
<DO-SOMETHING>
A>CS THEN
<IF-BRANCHES-HERE>
The last two shortcomings sited are that the standard control structures can't handle multiple WHILE exits separately from each other or from UNTIL without retesting the exit condition.
This is not an issue with the WHILE from Fleet Forth and the Ansi Standard.
BEGIN
WHILE
WHILE
WHILE
<DO-SOMETHING>
UNTIL
<UNTIL-EXIT-FROM-LOOP> EXIT
THEN
<LAST-WHILE> EXIT
THEN
<SECOND-WHILE> EXIT
THEN
<FIRST-WHILE> ;
Although Fleet Forth's assembler uses reverse polish notation and control flow similar to Ragsdale's assembler, it is not based on his assembler.
The control flow words for Fleet Forth's assembler are modeled on the high level Forth control flow words presented here. The control flow data is also two items, an address and a security code. The security codes used for the assembler control flow words are different.
Fleet Forth's control flow words, like the Ansi Standard control flow words, are the blocks upon which other control flow words can be built. This is, in my opinion, a more elegant solution than the one presented by George W. Shaw II.
0 >R CR .S CR .AS R> CR . CR
EMPTY
EMPTY
0
OK
With the new interpreter, this no longer works in Fleet Forth. I did mention it was not portable.
I just noticed that Tali Forth doesn't transfer the stack pointer to the X-register to update the loop index in place. It pulls the index off the return stack. I tried that method with Fleet Forth's (LOOP) and (+LOOP) . The resulting code was smaller and somewhat faster, especially for (+LOOP) .
Fleet Forth's DO LOOPs store three parameters on the return stack based on a suggestion from GARTHWILSON. Fleet Forth's previous (LOOP) and (+LOOP) with some details and code removed for clarity.
CODE (LOOP)
XSAVE STX TSX $101 ,X INC
0= IF // BRANCHING OUT OF WORD
SEC TYA
LABEL I.HI+A
$102 ,X ADC $102 ,X STA
VS IF // BRANCHING OUT OF WORD
XSAVE LDX
LABEL LEAVE.BODY
PLA PLA PLA PLA
LABEL EXIT.BODY
PLA IP STA PLA IP 1+ STA
CS>A CS>A
LABEL NEXT
\ fall through to NEXT
CODE (+LOOP) ( N -- )
INX INX XSAVE STX
$0FF ,X LDY $0FE ,X LDA
TSX CLC
$101 ,X ADC $101 ,X STA
TYA 0 # LDY
I.HI+A JMP
END-CODE
\ Section of code between ?BRANCH and BRANCH
A>CS THEN A>CS THEN \ Branch from (LOOP) to here
XSAVE LDX
LABEL BRANCH.BODY
\ fall through to BRANCH
I did not indent after either occurrence of IF because I am using them to conditionally branch out of (LOOP) and into another primitive.
Here are the new versions of (LOOP) and (+LOOP)
CODE (LOOP)
PLA TAY INY
0= IF // BRANCHING OUT OF WORD \ BRANCH1
SEC PLA 0 # ADC
VS IF // BRANCHING OUT OF WORD \ BRANCH2 -- compiles BVC
VS NOT IF \ -- compiles BVS
LABEL LEAVE.BODY
PLA PLA
THEN
PLA PLA
LABEL EXIT.BODY
CS-SWAP CS>A CS>A
LABEL NEXT
INX INX CLC
PLA $FE ,X ADC TAY
PLA $FF ,X ADC
VS IF CS>A \ BRANCH3 -- compiles BVC
LEAVE.BODY 2+ VS BRAN \ -- compiles BVS
END-CODE
\ The section of code between ?BRANCH and BRANCH
A>CS THEN A>CS THEN \ BRANCH2 and BRANCH3 branch to here
PHA
A>CS THEN \ BRANCH1 branches to here
TYA PHA 0 # LDY
LABEL BRANCH.BODY
The two PLA instructions which are skipped over are to support LEAVE . This adds four bytes to (LOOP) but eliminates the need to add five bytes to LEAVE .
All comments beginning with a backslash '\' were added to hopefully aid in understanding.
As I mentioned previously, Fleet Forth uses >FORTH to transition from the cold-start routine to high level Forth. Here is the tail end of Fleet Forth's cold start routine.
WARM SPLIT SWAP
# LDA $300 STA \ store address of warm-start routine
# LDA $301 STA \ at $300
(WARM) JSR
>FORTH
EMPTY 0 DRIVE CONFIGURE
12 SPACES
[ HERE 18 + >A ]
." C64 FLEET FORTH COPYRIGHT (C) 1995-2022 BY JAMES BOYD "
[ HERE 1- >A ]
INITIAL QUIT -; \ don't compile EXIT
$D A> C! $D0D A> ! \ replace some blanks in startup message string with CR.
-; (dash semicolon) works like ; (semicolon) but without compiling EXIT .
This is what is assembled and compiled by the source fragment above.
10947 134 # LDA N 1+
10949 768 STA
10952 42 # LDA
10954 769 STA
10957 10829 JSR ' BOOTCOLORS >BODY 19 +
10960 3382 JSR ' (>FORTH) >BODY
10963 10773 EMPTY
10965 3293 0
10967 9935 DRIVE
10969 9311 CONFIGURE
10971 3308 CLIT 12
10974 6662 SPACES
10976 7787 (.") C64 FLEET FORTHMMCOPYRIGHT (C) 1995-2022 BY JAMES BOYDM
11034 2955 INITIAL
11036 8621 QUIT
I know how Blazin' Forth handles the transition. How do other ITC Forths handle it?
