16-Bit value to single Digits
Highli007
Post by Highli007 »
Hello,
I am looking for a program that will allow me to display a stored 16-bit value on my LC display. For example, I have the decimal value: 16768 and need a subroutine that generates the characters 1, 6, 7, 6 and 8 for display.
Maybe someone can help me.
Greetings
Erik
floobydust
Re: 16-Bit value to single Digits
Post by floobydust »
You can try this routine from my C02 Monitor. Initially based on code adapted from "6502 Assembly Language Subroutines" with changes from me and later Mike Barry.
;HEX2ASC - Accepts 16-bit Hexadecimal value and converts to an ASCII decimal string. Input is
; via the A and Y Registers and output is up to 5 ASCII digits in DATABUFF. The High Byte is in
; the Y Register and Low Byte is in the A Register. Output data is placed in variable DATABUFF
; and terminated with a null character.
; Note: leading zeros are suppressed. PROMPTR routine is used to print the ASCII decimal value.
; Core routine based on Michael Barry's code. Saves many bytes with two updates/changes ;-)
HEX2ASC         STA     BINVALL         ;Save Low byte
                STY     BINVALH         ;Save High byte
                LDX     #5              ;Get ASCII buffer offset
                STZ     DATABUFF,X      ;Zero last buffer byte for null end
CNVERT          LDA     #$00            ;Clear remainder
                LDY     #16             ;Set loop count for 16-bits
DVLOOP          CMP     #$05            ;Partial remainder >= 10/2
                BCC     DVLOOP2         ;Branch if less
                SBC     #$05            ;Update partial (carry set)
DVLOOP2         ROL     BINVALL         ;Shift carry into dividend
                ROL     BINVALH         ;Which will be quotient
                ROL     A               ;Rotate A Reg
                DEY                     ;Decrement count
                BNE     DVLOOP          ;Branch back until done
                ORA     #$30            ;OR in $30 for ASCII
                DEX                     ;Decrement buffer offset
                STA     DATABUFF,X      ;Store digit into buffer
                LDA     BINVALL         ;Get the Low byte
                ORA     BINVALH         ;OR in the High byte (check for zero)
                BNE     CNVERT          ;Branch back until done
;Conversion is complete, get the string address, add offset, then call prompt routine and return
; note DATABUFF is fixed location in Page 0, carry flag need not be cleared as result can never
; set flag after ADC instruction.
                TXA                     ;Get buffer offset
                ADC     #<DATABUFF      ;Add Low byte address
                LDY     #>DATABUFF      ;Get High byte address
                BRA     PROMPTR         ;Branch to PROMPTR to Print numeric string
;PROMPT routine: Send indexed text string to terminal. Index is contained in A Reg.
; String buffer address is stored in variable PROMPTL/PROMPTH.
PROMPT          ASL     A               ;Multiply by two for msg table index
                TAX                     ;Xfer to X Reg - index
                LDA     MSG_TABLE,X     ;Get low byte address
                LDY     MSG_TABLE+1,X   ;Get high byte address
;PROMPTR routine: takes message address in Y/A and prints via PROMPT2 routine
PROMPTR         STA     PROMPTL         ;Store low byte
                STY     PROMPTH         ;Store high byte
;PROMPT2 routine: prints message at address (PROMPTL) till null character found
PROMPT2         LDA     (PROMPTL)       ;Get string data (5)
                BEQ     HINEXIT         ;If null character, exit (borrowed RTS) (2/3)
                JSR     B_CHROUT        ;Send character to terminal (6)
                INC     PROMPTL         ;Increment low byte index (5)
                BNE     PROMPT2         ;Loop back for next character (2/3)
                INC     PROMPTH         ;Increment high byte index (5)
                BRA     PROMPT2         ;Loop back and continue printing (3)
Note that the B_CHROUT routine outputs a character to a serial port on my Pocket SBC. You can replace it to send the data to wherever you need it.
Erik
Post by Erik »
Hey, thanks a lot!
But: STZ-OP-Code is only for 65C02, I guess!
Best
Erik
barrym95838
Post by barrym95838 »
Highli007 wrote:
Hello,
Greetings
Erik
Have you looked in the code section of this site?
floobydust
That's a good idea to prompt newbies to the site to look at the code section. Granted, I've gone thru it a number of times, but I really don't think about it much. Perhaps a gentle reminder when creating a new post to look at the other sections of the site would be useful.
Welcome, Erik!
BillG
Post by BillG »
Converting a binary number to decimal or BCD has previously been discussed extensively.
Two recent threads include
viewtopic.php?f=2&t=6579
and
viewtopic.php?f=2&t=4894
I posted my code for doing it on several processors at
viewtopic.php?p=90926#p90926
It was designed to convert quantities up to 64 bits in size using an optimized Double Dabble algorithm. For 16 bit numbers, it is probably overkill.
pjdennis
Post by pjdennis »
Here's my implementation (vasm assembler,) which is based on code shown in one of Ben Eater's videos:
; Requires TO_DECIMAL_PARAM (9 bytes)
TO_DECIMAL_VALUE = TO_DECIMAL_PARAM + 0  ; 2 bytes
TO_DECIMAL_MOD10 = TO_DECIMAL_PARAM + 2  ; 1 byte
TO_DECIMAL_RESULT = TO_DECIMAL_MOD10 + 1 ; 6 bytes
; On entry A, X = low, high bytes of value to convert
; On exit A, X point to the result
;         Y is preserved
to_decimal:
  ; Initialize result to empty string
  stz TO_DECIMAL_RESULT
  ; Initialize value to be the number to convert
  sta TO_DECIMAL_VALUE
  stx TO_DECIMAL_VALUE + 1
to_decimal_divide:
  ; Initialize the remainder to be zero
  stz TO_DECIMAL_MOD10
  clc
  ldx #16
to_decimal_divloop:
  ; Rotate quotient and remainder
  rol TO_DECIMAL_VALUE
  rol TO_DECIMAL_VALUE + 1
  rol TO_DECIMAL_MOD10
  ; a = dividend - divisor
  sec
  lda TO_DECIMAL_MOD10
  sbc #10
  bcc to_decimal_ignore_result ; Branch if dividend < divisor
  sta TO_DECIMAL_MOD10
to_decimal_ignore_result:
  dex
  bne to_decimal_divloop
  ; Shift result
  ldx #5
to_decimal_shift_loop:
  lda TO_DECIMAL_RESULT-1,X
  sta TO_DECIMAL_RESULT,X
  dex
  bne to_decimal_shift_loop
  ; Save value into result
  clc
  adc #'0'
  ; If value != 0 then continue dividing
  lda TO_DECIMAL_VALUE
  ora TO_DECIMAL_VALUE + 1
  bne to_decimal_divide
  lda #<TO_DECIMAL_RESULT
  ldx #>TO_DECIMAL_RESULT
  rts
Erik
Post by Erik »
Welcome, Erik!
Thanks a lot!
Erik
Erik wrote:
Welcome, Erik!
Thanks a lot!
Erik
P.S. Welcome as well.
See here for a “universal” binary to ASCII conversion function, “universal” meaning it will run on NMOS 6502s, as well as the 65C02 and the 65C816 in either mode. It’s probably overkill for your application, but maybe not.
electricdream
Post by electricdream »
Erik wrote:
Hey, thanks a lot!
Best
Erik
Is it possible to modify that part of the code? I think an "LDA #$00" followed by a "STA location" achieves what "STZ location" does.
Yup -- good thought.
Just be aware that "LDA #$00" followed by a "STA location" achieves more than what STZ does, because the accumulator and the flags get altered by the LDA. But that's acceptable in this case because the accumulator and the flags aren't important -- the immediately following instruction (at CNVERT) overwrites them anyway.
                STY     BINVALH         ;
                LDX     #5              ;
                STZ     DATABUFF,X      ; <---- replace this with "LDA #$00" followed by a "STA DATABUFF,X" ?
CNVERT          LDA     #$00            ;
