One other thing in favor of using a socket is the ease at which a part can be removed without damage, should the need arise. That has allowed me to salvage “expensive” parts from older POC units for use in new ones.
Techniques for reliable high-speed digital circuits
- BigDumbDinosaur
Re: Techniques for reliable high-speed digital circuits
Thanks for the reassurance. I just made my 44-pin PLCC socket PCB components. I'll see how the room compares and decide if I want to solder the PLCCs to the board directly, or socket them. I expect sockets will win, in spite of the extra inductance and the fact that they take room on every layer.
(We've mentioned before that PCB technology keeps moving on: for example, four layer boards are now much more affordable. In the same vein, I gather assembly is now affordable from some suppliers: they will deliver assembled, or partially-assembled, boards, if the parts in question are in their catalogue. I think it's worth considering this option, especially when there's some anticipated difficulty with some surface mounted components. A board which already has PLCCs or RAMs soldered in, and perhaps also tiny capacitors, maybe even sockets, can then be finished off when it turns up.)
I'm laying out an '816 board. I thought of just soldering PLCCs directly to the board, but I would need space around them to solder them, meaning sockets wouldn't take any more room. Thru-hole sockets kind of precludes putting parts on both sides of the board right there, but SMT sockets cannot be hand-soldered. I'm also staying away from parts so small I'm not sure I could finish a board and not have soldering defects, so I don't think I want to try the PQFPs for this.
- GARTHWILSON
- Forum Moderator
The problem is the access, not the pitch.
- BigDumbDinosaur
SMT parts are generally cheaper and easier to obtain; pc boards with SMT parts are smaller thus faster & cheaper; and it is actually easier to solder SMT components than comparable through-hole parts once the soldering skill has developed.
Of course, it helps to be able to see those dinky parts and their equally-dinky leads whilst building one’s contraption.
Garth,
These are unusual SMT PLCC sockets. SMT socket's contacts should be visually inspect-able to check for proper solder joints. Photo shows my SMT PLCC44 socket on the right; the PLCC44 socket on the left is through-hole PLCC socket.
- BigDumbDinosaur
pjdennis wrote:
I'm jealous of the microscope camera I recently saw being used at this point in this video: https://youtu.be/nhAisp4dWq8?t=1054
You need steady hands, as well. I didn't watch the video for more than a few seconds before it was interrupted by advertising, at which point I quit. I don't patronize Youtube "content creators" who allow advertising in the middle of their videos so they can make a few extra bucks, euros, pounds, rubles, etc.
- floobydust
Garth,
The mounting studs are nice alignment feature. The hard part about soldering the SMT PLCC socket by hand is not burning the central plastic webbing which is located very close the the soldering tabs.
Alright, I guess maybe it's supposed to limit the depth of insertion of the PLCC into the socket. But you could wait until the soldering is done then put the little rectangle back where it belongs... secured to the PCB with a dab of adhesive. Hmmm...
- BigDumbDinosaur
That stuff might be more temperature-resistant than one might think. After all, the socket has to be able to withstand reflow temperatures of ~450°F for at least 30 seconds.
- BigDumbDinosaur
I also found a PLCC-32 SMT socket that has mounting studs.
Where did you find it?
I guess it's about the same as the stand-off height.
