It is currently Tue Jul 02, 2024 10:45 am
PostPosted: Tue Aug 20, 2019 9:13 am
Just putting this here in-case someone else mis-reads their assembler documentation as I did recently ...
The mnv and mvp instructions take a source and destination bank numbers, so it's a 3-byte instruction, so naively, you might code it
        mvn    1,4
to move from bank 1 to bank 4. (after setting up A, X & Y).
However this won't work as the assemblers (at least ca65, and I think some others) want the full 24-bit address, even though they strip off the bottom 16 bits, so this ought to be:
    mvn    $01000000,$04000000
I now use a little macro in ca65 for simple moves with immediate values
; bmn
;       Block move macro
.macro  bmn     len,from,to
        lda     #len-1
        ldx     #(from & $FFFF)
        ldy     #(to   & $FFFF)
        mvn     (from & $FF0000),(to & $FF0000)
.endmacro
and so on for other variants.
Anyway. might help someone wondering why random RAM appears to be clobbered..
It's also a shame in a way that the from & to banks can't be easily changed dynamically without self modifying code. (No change from the PDP-8 there, then :-)
PostPosted: Tue Aug 20, 2019 9:53 am
That's very unexpected!
PostPosted: Wed Aug 21, 2019 1:53 am
ca65, at least the version I'm running atm, seems to assemble mvn/mvp just fine with only 8-bit operands:
000082r 1  44 00 00             mvp     0,0                     ; remove parameters
EDIT: it occurs to me it may be assuming they are 24-bit and expanding them, but since they are both bank 0, it's not obvious from my code. I'll have to try a non-bank 0 example.
PostPosted: Wed Aug 21, 2019 6:16 am
It assembles OK and is correct - for arguments 0,0. This is what initially threw me in my 65K 6502->65816 board. It was only with the 65816 board with 512K of RAM that I found different..
e.g. Trying with arguments 1,2 to copy from bank 1 to bank 2
000306r 1  54 00 00             mvn     1,2
this assembled just fine but appears to put the wrong parameters to the instruction, but if I use:
000306r 1  54 02 01             mvn     $010000,$020000
then it does the right thing.
PostPosted: Thu Jun 09, 2022 5:18 pm
I found this post when looking for using the 65816 move block instructions with self-modifying code. I had a similar problem in a straightforward port of my 6502 MOVE function to the 65816.
mvp 1,2
assembled as
I found that ca65 will accept the following syntax:
mvp #1,#2
to give
Apparently in the first place it's treating the operands as addresses.
PostPosted: Thu Jun 09, 2022 6:56 pm
tmr4 wrote:
mvp 1,2
assembled as
mvp #1,#2
to give
The MVP #1,#2 syntax is not in agreement with the official WDC syntax, but actually makes more sense, since the source and destination addresses are loaded into the index registers. The MVN/MVP instructions are kludges that are of very limited usefulness if all code is running out of ROM. What would have been better is if the operand was an address at which the source and destination banks would be found.
PostPosted: Thu Jun 09, 2022 8:59 pm
I suppose that would have added a few more cycles to each byte moved. Since the instructions are interruptible, I don't think they could avoid this.
Maybe that's why they decided to go this way.
PostPosted: Thu Jun 09, 2022 9:24 pm
They might have put the bank addresses in the high and low halves of the accumulator, but I don't know if that would have opened up an engineering can of worms.
PostPosted: Thu Jun 09, 2022 11:16 pm
The accumulator is used as the “bytes copied” counter, so it’s spoken for.
What is really needed is a 65xx bus-compatible “blitter” to take care of mass memory copies and DMA-type operations.
PostPosted: Thu Jun 09, 2022 11:31 pm
OOf ... shows how many times I've used those instructions ... I think the last time was around 1988, when I had an '802 installed in my ][+ for some harmless fun with the hi-res graphics pages.
