Blue April - RC6502 Project Space
- GARTHWILSON
- Forum Moderator
Re: Hardware Interrupts
Paganini wrote:
However, it seems like what's described in the primer is that when two 'S' VIAs are wire-ored together, VIA0 will try to pull IRQ low, but VIA1 will keep it high, preventing the interrupt form being issued. IOW, I'd expect to see *NO* interrupts
Re: Blue April - RC6502 Project Space
OK! I'll cut that wire before I try any other troubleshooting then. Thanks Garth, that was crazy speedy!
Here's a weird one. I've continued making progress on my PS/2 keyboard circuit. It's working as expected, except that I'm getting random intermittent lockups. Also, from time to time, the computer appears to be executing code that it should not be - for example, executing a "Print Message" subroutine that I'm not calling, but that I left in the firmware for future debugging use. It also sometimes re-executes code that is only supposed to execute one time, for example, the variable initialization code at the start of my main routine. My guess is that the lock ups are also due to executing code that should not be executed, but those times just don't happen to have any side-effects that are visible on my LCD.
Through the course of my investigations I've determined that it only happens if interrupts are enabled and actually being issued. For testing I made a simple momentary button circuit. It goes into the CA1 line of VIA0. I've also narrowed it down to one subroutine - the one that reads from my LCD. If interrupts are enabled during this routine, I get intermittent lockups and random code execution. If I disable interrupts during this routine, the problems seem to be fixed. Is there anything in here that looks particularly interrupt unfriendly?
The LCD is operating in 4-bit mode, so I always call LCD_read twice in a row. Note that VIA1 is a second 65c22; VIA0 is handling interrupts; VIA1 is not connected to the interrupt line (as described upthread... snip snip). My ISR is very short - right now it's just counting interrupts:
The only thing I can think is that the stack is somehow getting trashed... but by what?
LCD_R = %00000100 ; LCD R/W signal mask
LCD_E = %00001000 ; LCD Enable signal mask
LCD_read:
; Assume LCD is not busy, returns next nibble in A register
sei
lda #%00001110
sta VIA1_DDRA ; Set VIA1 Port A bits 7..4 to input
lda #LCD_R
sta VIA1_PORTA ; tell the LCD we want to read
lda #(LCD_R | LCD_E)
sta VIA1_PORTA ; send enable pulse
lda VIA1_PORTA ; read the data
and #%11110000 ; clear out junk on low order bits
pha ; save it here
lda #LCD_R
sta VIA1_PORTA ; take enable low again
lda #%11111110 ; set VIA Port A bits 7..4 back to output
sta VIA1_DDRA
pla ; return the data
cli
rts
irq:
bit VIA0_PORTA ; clear interrupt
inc counter
bne exit_irq
inc counter + 1
exit_irq:
rti
The story goes I was working on my own PS/2 Keyboard interrupt routine and also doing something else with the same VIA (just changing some output bits, nothing serious). And I too was getting these random mistakes. It would lock up the keyboard entirely, THEN it would unlock itself but spit out weird garbage. To this day I still don't know exactly what was going on, but clearing the keyboard variables in specific places helped fix it.
That said, I tried using SEI and CLI to fix the issue, and it made it terribly worse! The PS/2 keyboard does not wait for us to be ready for incoming data, it just sends it anyways. As far as this single button / counter code goes, I do not know, but it looks very similar to what I was doing: Altering something on the VIA and then interrupt and everything goes haywire. Not every time, but some times.
Try removing SEI and CLI perhaps? I'm sure you tried that, but it is my first guess. What is your interrupt setup code look like? You know, like the PCR and IER stuff. If I didn't ask, I'm guessing someone else would. Have you tried just like:
inf_loop
INC VIA1_PORTA
DEC VIA1_PORTA
JMP inf_loop
inf_loop
INC VIA0_PORTA
DEC VIA0_PORTA
JMP inf_loop
Sorry I wasn't a ton of help, I just wanted to mainly comment on the PS/2 Keyboard thing.
Hi Chad,
Correct. I'm trying to simplify the problem, so just a single pushbutton to pull CA1 low and generate an interrupt. The weird thing is, the VIA that handles the interrupt is VIA0. The code that seems to be causing the problem is concerned with VIA1, which is driving the LCD display. Since my last post I've narrowed it down a bit:
This is working. If I move sei down one instruction, or cli up one instruction I start to have problems. I didn't originally disable interrupts in this subroutine - I didn't see any reason to. My VIA setup routine looks like this:
I've tried a couple of different test loops; the one I'm using now is a little more complex than what you propose; the ISR just increments a counter in ZP (just like the one in Garth's primer), while my main loop just continuously prints out the value of that counter on the LCD.
So you are working on the PS/2 Keyboard stuff, but this code is just going back to basic interrupts, correct?
sei
sta VIA1_PORTA
lda #%11111110
sta VIA1_DDRA
pla
cli
VIA_init:
lda #%1111110
sta VIA1_DDRA
lda #%0000000
sta VIA0_DDRA ; Set VIA0 Port A to input (for reading from keyboard)
lda #$01
sta VIA0_PCR ; Set VIA0 CA1 to trigger on Positive Active Edge
lda #%01111111
sta VIA0_IER ; disable all VIA0 interrupts
lda #%10000010
sta VIA0_IER ; enable interrupts on VIA0 CA1
rts
OK,
So I had to take a bit of a break for a week or so, thanks to COVID.
I'm back on my feet now, though, and doing a little more investigating. The interrupt weirdness has to do with where the code is, not what the code is doing. I swapped a couple of subroutines in the source file, and the weirdness immediately started up again. This makes me think of a few possibilities:
1. My ROM is bad in that spot
2. I have something wonky going on with my address bus
3. This has something to do with crossing a page boundary.
My code has only just recently grown larger than 256 bytes. My initial interrupt test code easily fit into 256 bytes, so this is the first time my code has crossed a page boundary with interrupts enabled. I'm going to go google about this; meanwhile, if anyone knows any obvious pitfalls related to crossing page boundaries with interrupts enabled, I'm all ears.
Edit:
Here's a disassembly of the spot with the location counter
(In real life the org is $A000, not $0000):
It seems like it must be related to the page boundary.
Edit:
00fb 78 sei
00fc 8d 01 92 sta $9201 ; VIA1_PORTA is here
00ff a9 fe lda #$fe
0101 8d 03 92 sta $9203 ; VIA1_DDRA is here
0104 68 pla
0105 58 cli
Sounds like an address bus problem (or just possibly an address decode mistake.)
Worth beeping out the address lines - are they all connected to the pins they should be? Did you swap A7 and A8 or similar? Are any pair of lines shorted?
All the address lines seem to go where they're supposed to. They are mostly PCB traces. My custom board only uses A0..A3 (connected to the RS lines on VIA1) and A9..A15) (connected to the address decode logic, which is a couple of 138 line decoders).
I added a page of NOPs at the start of my firmware to see if I would get the same behavior when crossing a different page boundary, and I started getting some TRULY wild behavior. The LCD prints all kinds of crazy gibberish. I'm not even sure how to describe it. It also seems to have something to do with having two VIAs in the system. If I disconnect the second one all the problems go away. The VIA on my LCD board has these lines connected to the system bus:
A15..A9, A3..A0,Phi2,RESB,R/WB,D0..D7
The address decoding is the same as this:
https://github.com/tebl/RC-Project-Boar ... 206502.pdf
Except that I added a jumper block to U3 so that I can use, e.g., the $x200, address range for I/O.
I guess I will have to try and simplify more. Assuming I made a mistake in the address decoding (or something) on my LCD board, I should be able to switch back to the breadboard circuit. Let me ask this: looking at the RC Project Board schematic, other than sharing the IRQB line, which I can take care of with a jumper, can you see any problems having two of them attached to the bus at once?
Well this is encouraging; there's nothing wrong with my LCD board (YAY!), and everything works just fine if I use one VIA to manage both the LCD and the interrupt line. So the problem only happens when I have two VIAs attached to the bus at once. Was it just a coincidence that the problem happened at a page boundary? The plot thickens (or does it thin?)...
The only thing which stands out is that JP2 but I can't quite think it through.
As I understand it, I03B is a bus signal on a different KIM1 clone kit; JP2 is provided for compatibility in case you want to plug the project platform into that kit instead of the RC6502. I have pins 2 and 3 shorted so that the address decode logic supplies the CS2B to the VIA, rather than taking it from the bus.
Thanks for taking the time to look at it!
- GARTHWILSON
- Forum Moderator
On your .pdf, I can't tell what address you might have the second VIA at. It definitely sounds like you have them trying to run on the same addresses though.
The only considerations I can think of regarding page crossings are:
In most circumstances, especially with the CMOS 65c02, there is absolutely no concern about code crossing page boundaries.
- Indexing will wrap ZP on the '02 rather than letting you index into page 1. (The '816 does let you index beyond the direct page though.)
- The 6502's stack pointer will always be in page 1, so there's wrapping there, too.
- Branch instructions on the '02 take one extra cycle if you branch across a page boundary. Most branches won't cross a page boundary. Further, if you're not doing something where the exact number of cycles matters, the crossing won't affect anything.
- The NMOS 6502 has a bug in that if an indirect jump looks to an $xxFF address to get the final address, the page won't increment as it should to get the high byte. This is fixed in all CMOS versions.
- On the NMOS 6502, indexing across a page boundary caused an extra read of an invalid address, which could cause trouble in some hardware. (CMOS does an extra read of the last instruction byte instead.)
- BigDumbDinosaur
But...but...but...I thought masks and vaccines had this under control.
I’d go with number 2. When burning a ROM, almost all programming software does a compare on the ROM contents and reports an error if there is a mismatch.
I've never encountered a problem with page crossings in the CMOS processors. If you are using an NMOS 6502, I suggest you replace it with a 65C02.
I suspect you have a gross design error in you hardware, but lacking a full schematic to read, it’s only a suspicion.
