Venn diagram of psuedo-ops and assembler directives
jeffythedragonslayer
On a Venn diagram, if I drew circles for things that are "psuedo-ops" and things that are "assembler directives," would these be concentric circles? (And if so which circle is inside which?) Or are they partially intersecting circles, or even identical circles (synonyms)?
- GARTHWILSON
- Forum Moderator
Re: Venn diagram of psuedo-ops and assembler directives
I've always thought they were the same thing. They're instructions for the assembler, rather than for the processor that will run the final assembled code.
- BigDumbDinosaur
The two terms refer to the same thing. “Pseudo-op” is an informal term that has been around as long as assembly language has been in use.
I see, thanks. "directive" sounds like a more formal term.
