Here's the Rev 2.4 schematic converted to monochrome... hope this is easier to read.
I think it would be a good idea to read through some of the datasheets on the various chips. You still need a pull-up resistor on the BE line for the CPU. Also, if you're not planning to use a non-WDC processor, you can delete the jumper for VP going to ground.
You can also replace the 555 timer and inverter for the reset circuit and use a single DS1813 supervisor chip, saves space and a lot of components. I'm not sure why you have so many different ROM banks, but perhaps you can give us some logic on how you plan to use them. As already noted, you can easily use higher density memory chips and reduce the count. If you have plans on banking memory (RAM and ROM) you might want to look at the 512KB ROM/RAM card on the RC2014 stuff... the same approach can be used for the 65C02 as well and would likely be more efficient than what you already have.
If you have the ability to program a PLD (ATF22V10 comes to mind), you could replace a lot of decode logic chips with one or two of these and delays will be much less. Also, you show a selectable clock rate for the CPU of 8-, 4- and 2MHz. Yet, your expansion connectors only show the 8MHz clock. Logically I would think you would want the same clock that's driving the CPU to be routed to the expansion connectors. Then again, we really don't know how you plan to use this setup and what expansion cards are planned, etc.
I would also recommend you ditch the 65C51... any non-WDC parts (sans the xmit bug) will be limited to about 4MHz (if you can find 4MHz rated parts). Going to an NXP SC29L92 DUART would make more sense and give you additional function as well. If you plan on using a UART channel to communicate to a modern PC, note that there are UART to USB adapters than can be mounted on board and reduce the chip count further and have a nice high-speed serial connection.
Finally, have you developed any software for this project yet? Did you do any initial prototyping with some code to make something work so you have an idea on how to get the software side started? Starting with something small at first usually gives you some good insight on how to grow the project.
