Kernel User Interrupt
- speculatrix
Re: Kernel User Interrupt
Coincidentally, I’ve just been grappling with something similar. Although my skills here are basic, I have documented what I did here: https://mansfield-devine.com/speculatri ... ng-system/
It either works or catches fire. Either way is fun.
Zolatron 64 project (on Medium)
Ah, thanks, I see now!
Hi
Spotted an error if anybody was looking closely.
the line BCC _exit_irq should be a BCC to _not_via
otherwise the JMP(indirect) for vector3 will be missed.
This is still all work in progress so testing is limited.
Regards
Andre
...yes it was a 10ms timer interrupt
JMP ($04F0) ; jump to vector1 interrupt
_vector1_return:
INC SYSTEM_TIMER
CLC
LDA SYSTEM_TIMER
CMP #$64 ; HAS TIMER REACHED 100 (0x64)
BCC _exit_irq
LDA #$00
STA SYSTEM_TIMER
INC SYSTEM_SECONDS
JMP ($04F2) ; jump to vector2 interrupt
_vector2_return:
_not_via:
JMP ($04F4) ; jump to vector3 interrupt
_vector3_return:
_exit_irq:
PLA
PLX
PLY
_irq_last_byte_address:
RTI ; Return from IRQ interrupt
_vector1_return:
INC SYSTEM_TIMER
CLC
LDA SYSTEM_TIMER
BCC _exit_irq
LDA #$00
STA SYSTEM_TIMER
INC SYSTEM_SECONDS
_vector2_return:
_not_via:
_vector3_return:
_exit_irq:
PLA
PLX
PLY
Regards
Andre
- BigDumbDinosaur
_vector1_return:
INC SYSTEM_TIMER
CLC
LDA SYSTEM_TIMER
BCC _exit_irq
LDA #$00
STA SYSTEM_TIMER
INC SYSTEM_SECONDS
_vector2_return:
_not_via:
_vector3_return:
_exit_irq:
PLA
PLX
PLY
RTI ; Return from IRQ interruptSurrounding your code snippets with code brackets will make it a little easier to read.
teamtempest
_vector1_return:
INC SYSTEM_TIMER
CLC
LDA SYSTEM_TIMER
BCC _exit_irq
LDA #$00
STA SYSTEM_TIMER
INC SYSTEM_SECONDSCode: Select all
JMP ($04F0)
_vector1_return:
DEC SYSTEM_TIMER
BNE _exit_irq
INC SYSTEM_SECONDS
LDA #100
STA SYSTEM_TIMER
- Sheep64
- In Memoriam
Andre on Fri 22 Apr 2022 wrote:
_exit_irq:
PLA
PLX
PLY
