It is currently Sat Nov 23, 2024 3:09 am
 Post subject: Re: BIT Instruction
PostPosted: Sat Jan 22, 2022 9:23 pm
I never know how to portray the *+1 when displaying here as some assemblers use *+1 and some use *+3. I don't know what the common understanding is. I guess I should have used a label instead. BTW, I do short tests like this in the mini-assembler and have to type it in to the forums.
But I missed a line anyways.
It should have been
lda #0
   sta $6
   lda #$FF
   bit $6
   beq label
   rts
label
   brk
   brk
In my tests this routine falls through an doesn't crash. If it is a bug in my emulator, that has been the reason I have avoided programming that way. But I just tested again and it and DOH! it works.
PostPosted: Sun Jan 23, 2022 12:06 am
IamRob wrote:
I never know how to portray the *+1 when displaying here as some assemblers use *+1 and some use *+3. I don't know what the common understanding is. ...
Since I used an C64 assembler back in the day that used the "+" for transient labels, and now use ACME, I never got into using "*" based relative branch addressing ...
... and, yes, why I noted that it might be assembler dependent. Testing, I see that ACME takes it as set at the beginning of the line of assembly, presumably until that line of assembly is completed, so it would be *+3 for ACME to get a branch operand of $01 (given that 6502 branch operands are relative to the start of the following opcode).
But when I first used it, it was the MOS6510 that decided for me how an opcode works, and AFAIR, setting the zero flag the same as an AND would have done is how BIT has always worked.
PostPosted: Wed May 25, 2022 8:26 pm
I cannot pass up the opportunity to recommend the excellent programming manual, "Programming the 65816 including the 6502, 65C02, and 65802" by David Eyes and Ron Lichty. This is a .pdf file of a rather large book that is well laid out and is much better than the description there lets on. Note: There were many problems with the earlier .pdf version that were not in the original paper manual; but in late March 2015, WDC scanned and OCR'ed the paper manual and posted the new, repaired .pdf. Chapter 18 gives at least a page for every instruction, telling exactly what it does, and covering all the addressing modes, cycle counts, etc..
What do you think of the Kindle Unlimited version of the programming manual, Garth? J
PostPosted: Wed May 25, 2022 9:09 pm
I don't know. Is there a date on it? (I don't do Kindle, only PC.)
PostPosted: Wed May 25, 2022 9:20 pm
It looks like its the 2015 soft-cover version.
PostPosted: Wed May 25, 2022 9:56 pm
Jmstein7 wrote:
[It looks like its the 2015 soft-cover version.
In late March 2015, WDC scanned and OCR'ed the paper manual and posted the new, repaired .pdf. The .pdf that was distributed before that had problems. I bought my paper version in the 1990's, and it came in a ring binder. I was never aware of a soft-cover version.
PostPosted: Thu May 26, 2022 3:33 pm
Yeah, it looks like it was released along with (at the same time as) the single-board dev boards (SBX, QBX, etc.).
Users browsing this forum: Google [Bot] and 18 guests
