Currently working with an ATF1508AS-7AX100 coding in Verilog on Quartus II 13.0 configured for a Max7000s EPM7128STC100-7.
The problem I'm running into is with my soft power/reset circuit. The reset works perfectly both with button interaction and power on reset. The problem is that the power signal either immediately shuts off, or doesn't come on at all when the commented line of the current code is enabled. I've broken it out to it's own counter and even it's own combinatorial process and even tried being liberal with the begin / end encapsulation all with the same results. I'm really stumped guys, any help would be appreciated.
The goal of this section of code is:
1.) On power up set the power signal to high
2.) on power up hold reset low for 1/10th of a second (8mhz clock)
3.) hold reset low while the button is held high.
4.) hold reset low for 1/10th of a second following a transition of high to low on the button
5.) Set the power signal to low when the button is depressed for 1 second.
reg _rst = 0;
reg _pwrSig = 1;
reg _pwrBtnLast = 0;
reg [23:0] _pwrCnt = 0;
assign pwrSig = (oe && _pwrSig) ? _pwrSig : 1'bz;
assign rst = (oe && ~_rst) ? 1'b0 : 1'bz;
always @(posedge clk) begin
if (pwrBtn) begin
_rst <= 0;
if (~_pwrBtnLast) _pwrCnt <= 0;
else _pwrCnt <= _pwrCnt + 1;
//if (_pwrCnt >= 8000000) _pwrSig <= 0;
end
else begin
if (~_rst) begin
if (_pwrBtnLast) _pwrCnt <= 0;
if (_pwrCnt >= 800000) _rst <= 1;
end
end
_pwrBtnLast <=pwrBtn;
endbelow is the full code just in case it's helpful.
module JB6502ATF1508(
input clk,
input oe,
input rw,
input pwrBtn,
input [7:0] adrBusLo,
input [7:0] adrBusHi,
input [7:0] datBus,
output [5:0] rBanks,
output v0En,
output v1En,
output rLow,
output clkWr,
output roEn,
output raEn,
output hr0En,
output hr1En,
output hr2En,
output hr3En,
output ioEn,
inout datDir,
output srlEn,
output pwrSig,
inout rst
wire _roEn;
assign _roEn = (adrBusHi[7:6] == 2'b11) ? 1'b0 : 1'b1;
assign roEn = (oe) ? _roEn : 1'bz;
wire _hrEn;
assign _hrEn = (adrBusHi[7:5] == 3'b101) ? 1'b0 : 1'b1;
wire _hr0En;
assign _hr0En = (_raBank[7:6] == 2'b00 && ~_hrEn) ? 1'b0 : 1'b1;
assign hr0En = (oe) ? _hr0En : 1'bz;
wire _hr1En;
assign _hr1En = (_raBank[7:6] == 2'b01 && ~_hrEn) ? 1'b0 : 1'b1;
assign hr1En = (oe) ? _hr1En : 1'bz;
wire _hr2En;
assign _hr2En = (_raBank[7:6] == 2'b10 && ~_hrEn) ? 1'b0 : 1'b1;
assign hr2En = (oe) ? _hr2En : 1'bz;
wire _hr3En;
assign _hr3En = (_raBank[7:6] == 2'b11 && ~_hrEn) ? 1'b0 : 1'b1;
assign hr3En = (oe) ? _hr3En : 1'bz;
wire _ioEn;
assign _ioEn = (adrBusHi == 8'b10011111) ? 1'b0 : 1'b1;
assign ioEn = (oe) ? _ioEn : 1'bz;
wire _v0En;
assign _v0En = (~_ioEn && adrBusLo[7:4] == 4'b0000 ) ? 1'b0 : 1'b1;
assign v0En = (oe) ? _v0En : 1'bz;
wire _v1En;
assign _v1En = (~_ioEn && adrBusLo[7:4] == 4'b0001 ) ? 1'b0 : 1'b1;
assign v1En = (oe) ? _v1En : 1'bz;
wire _srlEn;
assign _srlEn = (~_ioEn && adrBusLo[7:4] == 4'b0110 ) ? 1'b0 : 1'b1;
assign srlEn = (oe) ? _srlEn : 1'bz;
assign datDir = (~_ioEn && _srlEn && _v0En && _v1En) ? 1'b0 : 1'bz;
wire _raEn;
assign _raEn = (_roEn && _hrEn && _ioEn) ? 1'b0 : 1'b1;
assign raEn = (oe) ? _raEn : 1'bz;
wire _rLow;
assign _rLow = ~rw;
assign rLow = (oe) ? _rLow : 1'bz;
wire _clkWr;
assign _clkWr = (~rw && clk) ? 1'b0 : 1'b1;
assign clkWr = (oe) ? _clkWr : 1'bz;
reg [7:0] _raBank = 0;
reg [7:0] _roBank = 0;
wire [5:0] _rBanks;
assign _rBanks = (~_hrEn) ? _raBank[5:0] : _roBank[5:0];
assign rBanks = (oe) ? _rBanks : 1'bz;
always @(negedge clk) begin
if (~rst)
_raBank <= 0;
else if (adrBusHi == 0 && adrBusLo == 0 && ~rw)
_raBank <= datBus;
end
if (~rst)
_roBank <= 0;
else if (adrBusHi == 0 && adrBusLo == 1 && ~rw)
_roBank <= datBus;
end
reg _rst = 0;
reg _pwrSig = 1;
if (pwrBtn) begin
_rst <= 0;
end
else begin
if (~_rst) begin
end
end
end
endmodule
