If there are any PET gurus out there, I would appreciate some ideas on why I can't seem to read input directly from PORTB on the 6520 that is connected to the PET keyboard. I am familiar enough with the hardware to know that bits (3:0) feed a 74LS145 BCD decoder that drives one of ten ROW lines LOW. I also know that pressing a key will drive one of the Columns LOW that feeds into the 6520 PORTB input.
I need to read input data from PORTB of the 6520 as fast as possible (for reasons I will explain later), so I made this basic assembly test just to make sure I was on the right track. I fully expected this to show characters change on the screen as I pressed various keys....
; ********** PET BASIC PROGRAM STUB
; ********** SAVE CODE STARTING @ 1025
; START OF BASIC
.ORG 1025
.WORD 1025
; ADD BASIC SYS2000 COMMAND
.BYTE 11,4,0,0,158,50,48,48,48,0,0,0
; START OF PRORAM + BASIC OFFSET
.ORG 2000+2
; DISABLE PET KERNAL
;SEI
; ********** MAIN LOOP
MAIN:
; SET KBD.ROW
lda #0
STA $E810
; RED KBD.COL
LDA $E812
STA 32768
; ALIVE TEST
INX
STX 32769
; LOOP
JMP MAIN
What is odd is that the keyboard has no effect on the first character, it just stays at 255. Even if I alter the 145 value, nothing changes.
I have run this code on 2 real PETs as well as vice, and it is the same on all.
Any ideas? I am almost certain that my addresses are correct; $E819 to set the 145, and $E812 to read the data.
On a side note, this "Basic Stub" just stuffs "SYS 2000" into basic line zero. Address 2000 is the start of assembly code.
I use this for all my PET progs, and it works well.
Here is a Vice shot, showing the 255 character (top left) and my rolling character working...
Cheers!
Brad
