It is currently Fri Nov 22, 2024 9:31 pm
 Post subject: 16-bit Subtraction
PostPosted: Wed Nov 03, 2021 7:15 pm
Hello all! I am working on expanding the Ben Eater 6502 project and I started looking at implementing a serial function, with data coming from an Arduino and being loaded into RAM. I managed to get the code to work properly, but only for an 8-bit amount of instructions. If the number of instructions is > 255, my code breaks down. I'm not sure exactly what the issue is, though. I've tried the "standard" 16-bit subtraction code snippit from https://dwheeler.com/6502/oneelkruns/asm1step.html to completely replace what I have, but it didn't work, even for an 8-bit number. Here is the code I'm using:
(BYTECOUNT and BYTECOUNT+1 are used to keep track of how many instructions are to be sent from the Arduino)
(These numbers are 1 based, i.e. when the BYTECOUNT (and BYTECOUNT+1) are 0, there are no more instructions left and the code should branch out to the end)
.byteToRam:
  ; Receive 8 individual bits and construct them into a byte
  jsr .receiveBits
  ; Builds up IECDATA as the byte
  ; Save byte to RAM
  ; USRMEM is the location in RAM the code can start writing to = $0400
  ; X starts at 0
  lda IECDATA
  sta USRMEM,X
  INX
  dec BYTECOUNT
  beq .highByte
  jmp .byteToRam
.highByte:
  lda BYTECOUNT+1
  bne .decBC1
  jmp .end
.decBC1:
  dec BYTECOUNT+1
  lda #%11111111
  sta BYTECOUNT
  jmp .byteToRam
.end:
  cli ; enable interrupts
  jmp USRMEM
I have one thought that the above code is missing the 0th byte when there is more than 255 instructions to pass in, i.e. byte 256 or 512, etc. I tried coding for that, but it still didn't work as I expected. Does anyone have any ideas and/or simplifications? I really appreciate it! Please let me know if more detail is required and I shall add it.
 Post subject: Re: 16-bit Subtraction
PostPosted: Wed Nov 03, 2021 7:33 pm
[quote="ty9000"]
  ; Save byte to RAM
  ; X starts at 0
  lda IECDATA
  sta USRMEM,X
  INX
Before going any further, you know that the X register is only 8-bits wide and will wrap to zero after 255 ...
PostPosted: Wed Nov 03, 2021 7:43 pm
Doh! That's what my issue is! I even thought about that a few days ago before I started to code anything and I must have just forgotten about it in all the excitement of getting the code to initially work. Thanks for the second set of eyes - I couldn't see the forest for the trees. Haha! :lol:
PostPosted: Wed Nov 03, 2021 7:50 pm
If using a 65C02 (which I think you will be with the Ben Eater setup), then
; Initialisation
dataStore = $0400
    lda    #<dataStore
    sta    usrmem+0
    lda    #>dataStore
    sta    usrmem+1
; Store value
    sta    (usrmem)
    inc    usrmem+0
    bne    foo
     inc    usrmem+1
foo:
; do the length subtraction here, etc.
    jmp    dataStore
PostPosted: Wed Nov 03, 2021 9:28 pm
Yes, that was it - thank you so very much! That has been kicking my butt for way too long. Adding in that code even made the program shorter, overall. Still trying to get the hang of this all. Thanks again!!
PostPosted: Wed Nov 03, 2021 9:33 pm
Welcome to the land of 65xx, ty9000, and welcome to this forum! :)
PostPosted: Thu Nov 04, 2021 2:23 pm
For your subtraction set, another idea is:
    sec
    lda bytecnt
    sbc #<1              ; ie., 1
    sta bytecnt
    lda bytecnt+1
    sbc #>1              ; ie., 0
    sta bytecnt+1
    ora bytecnt
    bne bytetoram         ; b: both not zero yet...
or something like this:
    lda bytecnt
    bne notzero
    lda bytecnt+1
    beq finished
    dec bytecnt+1
notzero
    dec bytecnt
    bra bytetoram
finished
PostPosted: Thu Nov 04, 2021 2:50 pm
That second example is properly optimized ... neat!
[Be careful about using it though, because it checks for zero before the decrement instead of after ...]
PostPosted: Mon Nov 08, 2021 5:34 pm
I'm curious as to how your .receieveBits routine works.
I have some code I'm working on that also involves converting a serial stream into bytes:
lda piaPortA
ror A
rol presentSIByte
; piaPortA is port A on a MC6821 PIA
; roll bit 0 to carry, then into current byte being received
(test status of transmitter flag)
dec bitcount
; bitcount is continuously decremented - only last 3 bits are important
lda bitcount
and #$07
beq itsmathtime
; if we have counted off 8 bits, continue into math section, else exit interrupt
rti
.itsmathtime
lda presentSIByte
sta lastSIByte
(continue with the math)
PostPosted: Sun Nov 21, 2021 5:56 pm
So, I did move away from bit-banging the code into RAM one bit at a time and instead moved over to "byte-banging" the code using a '595 shift register. It's much more stable this way. But, I do still have the .receiveBits code around:
BITCOUNT is reset to 8 before getting to .receiveBits
.receiveBits:
  lda PORTA ; the bit coming in needs to be shifted left 4 times (for my hardware setup) in order to get it into the carry bit
  asl a
  asl a
  asl a
  asl a
  ror presentSIByte
  dec BITCOUNT
  bne .receiveBits
  jsr .byteSetup
Does this help some?
Users browsing this forum: kenames99 and 33 guests
