My original
Mand: 14.104
Bench 8250,7954
Pi 6.489
Copro (Atmega @ 16Mhz)
Mand: 10.977
Bench 11805,11298
Pi 6.148
8x8
Mand: 10.943
Bench 12238,11532
Pi 6.101
BDD
Mand 12.964
Bench 9258,8895
Pi 6.313
MB
Mand 9.336
Bench 13735,13659
Pi 5.585
Mand 10.844
Bench 12329,11519
Pi 6.051The 2 numbers after bench are 2 runs of the test, one with I *N, the other with N * I. I is from 0 to 9999 and N is fixed at 12345. This may favour small numbers in one case (or the other) but it's interesting to see that all routines exhibit different timings based on the order of operands.
And bear in-mind, there is a lot more overhead here in that this is a bytecode interpreted by the '816 although I do a separate null-loop timing to help correct for the actual loop overhead. In a pure '816 ASM environment the multiplies per second will be faster.
The Mandelbrot inner loop looks like:
WHILE cy <= ymax DO
cx := xmin
WHILE cx <= xmax DO
LET q=?
LET x,y,x2,y2,iter = 0,0,0,0,0
WHILE iter < maxiter DO
IF x2+y2 > 16384 THEN
BREAK
q := x*y
TEST q < 0 THEN
y := (-(-q >> 11)) + cy
ELSE
y := ( q >> 11) + cy
x := x2 - y2 + cx
x2 := (x*x) >> 12
y2 := (y*y) >> 12
iter := iter + 1
sawrch (' ' + iter)
cx := cx + dx
sawrch ('*n')
cy := cy + dy
}the Pi calculation code possibly does more divide and MOD operations than multiply, but this function is called a lot:
AND divide(src, dst, d, l) BE {
LET rem, n = 0, ?
FOR i = 0 TO l DO
{ n := src%i + 100 * rem
rem := n MOD d
dst%i := n / d
}If anyone is interested in the BCPL code and cintcode, then this is the BCPL code of the 2nd loop in my multiply benchmark:
FOR i = startVal TO endVal DO
res := i * multiplierCode: Select all
303: L16:
303: LL L4 -- Load constant at L4 (12345) into regA
305: LP10 -- regB := regA ; regA := Local variable 10 (stack)
306: MUL -- Multiply regA := regA * regB - Our code!
307: SP3 -- Store regA at local variable 3 (stack)
308: L1 -- regA := 1
309: AP10 -- add local variable 10 into regA
310: SP10 -- store at local variable 10
311: LP11 -- regB := regA ; load local variable 11 into regA
312: JLE L16 -- jump back if <=Maybe enough for now unless someone else wants to stand up to the podium?
