Here is the description:
The 65c816 is the 8/16-bit big brother of the 65c02, used in the SNES and Apple II GS. https://www.westerndesigncenter.com/wdc ... 5c816s.pdf The 65c816 core is adapted from a SNES FPGA project.
The SoC has a small monitor in ROM ($C000-$FFFF), a soft ACIA at $8000, and (distributed) RAM from $0000-$7FFF. The LEDs indicate reset status, and BTN0 serves as the reset (active high). The constraints file shows which pins to connect from the 'c816 to the Arty. The monitor resides in the COE file.
This design also requires a 1.8432mhz external oscillator (clock) to be connected to the Arty so that the ACIA will work properly (currently at pin IO33).
Note: You must clock the device itself ABOVE 2mhz. I've tested it up to 7mhz.
You can load your programs into RAM as .prg files. Enter "X" at the monitor prompt, and you can load your program via the XMODEM protocol. I use ExtraPuTTY. Note: you can control where in RAM your programs load via your .prg files. I've been coding using Visual Studio and RetroAssembler. https://enginedesigns.net/retroassembler/
Run your program by using the address + "R" at the monitor prompt. For example, if you load your program at $1000, you would type 1000R and then enter. Make sure to jump or rts out to $C385 at the end of your program. This is the exit point that will return you to your monitor.
The project includes a QSPI (Quad SPI) driver written for the specs of the 23LC512 by Microchip. The SRAM is connected to PMOD JA.
"L" clears the Zero Page and resets the stack from the monitor. I am currently working on a design that allows the user to replace the ROM monitor at will.
The other monitor function work as a typical WozMon would: (e.g.), https://www.sbprojects.net/projects/apple1/wozmon.php
Feel free to contact me through the 6502 forum: memberlist.php?mode=viewprofile&u=3597
Enjoy!
Jonathan
PS I really want to design a method of replacing the ROM via XMODEM, without having to re-synthesize and implement the whole darn thing each time I update the Monitor ROM.
