I'm disappointed that very few people use a 65816's MX or EMU pin. I presume that Bill Mensch is more disappointed.
The MX pin provides a 65816's two modal 8/16 bits during each clock phase and is intended to extend functionality, for example, during 16 bit I/O. The EMU pin provides emulation/native status and may be used within a privilege system. At the very least, 65816 enthusiasts should consider adding a turbo light to their systems.
A more advanced use involves WS2812 LEDs (sometime sold at a 3x inflated price under the NeoPixel brand). These lights presumably use a analog servo style capacitor and comparator arrangement to derive Morse code type data from a self clocking signal. They can be daisy-chained into arrangements exceeding 1000 lights. However, they are quite bright given that they are intended for signage and the RGB or RGBW lights typically draw 20mA per section.
WS2812 protocol is very simple. One byte per channel is sent most significant bit first. There is no padding byte for any variant and the order of each channel varies although green, red, blue may be the most common variant; possibly to aid heat dissipation of the gallium green and gallium blue channels.
A zero bit is represent by a pulse which is shorter than 350ns. A one bit is represented by a pulse which is longer than 700ns. In either case, a cycle shorter than 900ns should not occur because one device within the daisy-chain may be conveying a long pulse to the next device. The shift register chain (which may exceed 32000 bits) is set live after a period of inactivity. Different variants have an inactivity period which ranges from 6000ns to 50000ns. Inactivity presumably sets a 256 cycle PWM duty which is run from an internal oscillator. In different applications, it may be beneficial to shift out one byte, three bytes, four bytes or the entire chain before shifting falls into the dormant state.
With masked interrupts, appropriate NOP cycles and a latch for EMU pin validity, it is possible to repeatedly clear or set emulation mode within a 65816. If one or more WS2812 LEDs are daisy-chained to the 65816's EMU pin, appropriate RGB data can be shifted to the programmable LEDs. By this mechanism, it is possible to send debug information or general purpose status to a short chain of WS2812 lights.
If you have a large quantity of WS2812 LEDs, it is possible to skip transfer via the EMU pin. Instead, apply the
double 8*8 binary matrix transpose and drive up to eight chains concurrently. 6502/65816 is particularly suited to this task given that the transpose may require less than five clock cycles per bit. However, if you have a very small quantity of WS2812 lights, functionality specific to 65816 provides a relatively transparent output channel.
