It is currently Tue Jun 04, 2024 3:50 am
 Post subject: GAL16V8 Memory decoder
PostPosted: Thu Sep 23, 2021 3:58 pm
Hello,
I am not sure if this belongs to this forum, but maybe someone could help me. I am trying to reverse engineer a memory decoder fom an old studio FX unit. It seems to be simple combinatorial logic.
I am reading the input > output combinations with arduino and then I am trying to replicate those tables with WinCUPL, but I can't get it right. I am having problem with the "SYNCDT" signal. I don't know how to write the logic equations correctly.
I am posting my .PLD file and the tables from the original and newly programmed chip. The problem is with last few lines 0122 - 0127, the SYNCDT signal should be LOW, but it stays HIGH and when I try to write some more equations, I get compiler error "The number of product terms needed to implement the logic expression for the given variable exceeds the capacity of the output pin for which it was declared."
Any help would be super cool,
thank you.
A.
PLD File:
Name     Lexicon M300 MDEC 1.01 ;
PartNo   00 ;
Date     13.09.2021 ;
Revision 01 ;
Designer  ;
Company  PLD lousk ;
Assembly None ;
Location  ;
Device   g16v8;
PIN     [1..7] = [ A0 ..6]; /* Upper addresses   */
PIN     8=AS; /* Addres srobe                    */
PIN     9=DMAACK; /* DMA Acknowledge             */
PIN     11=RORMP;/* ROM Re-mapping               */
PIN     12=!PERIPH ;  /* PERIPH                         */
PIN     13=!DUART ;   /* DUART                          */
PIN     14=!ZRAM2 ;   /* ZRAM2                          */
PIN     15=!ZRAM1 ;   /* ZRAM1                          */
PIN     16=!SYNCDT ;  /* SYNCDT                         */
PIN     17=!RAM0 ;    /* RAM0                           */
PIN     18=!ROM1 ;    /* ROM1                           */
PIN     19=!ROM0 ;    /* ROM0                           */
/* *****************Declarations************** */
/* **************EQUATIONS************ */
ROM0 = ((!A0 & !A1 & !A2 & A3) & !AS & RORMP) # ((!A0 & !A1 & !A2 & !A3) & !AS & !RORMP);
ROM1 = (!A0 & !A1 & A2) & !AS;
RAM0 = (!A0 & !A1 & !A2 & !A3 & !A4) & !AS & RORMP;
SYNCDT =
    AS
  # !A0 & A1
  # A0 & !A1
  # A0 & !A2
  # A0 & !A3
  # !A2 & A3 & !RORMP
  # A0 & !A4 & !A5 & !A6
  # A0 & !A4 & A5 & !A6
  # !A2 & !A3 & A4 & RORMP;
ZRAM1 = !DMAACK & !AS;
ZRAM2 = !DMAACK & ((A0 & A3) # (A0 & A2) # (A0 & A1))  & !AS;
DUART = !AS & (A0 & A1 & A2 & A3 & !A4 & !A5 & !A6);
PERIPH = !AS & (A0 & A1 & A2 & A3 & !A4 & !A5 & A6);
Read from the original chip:
Table 2 - AS/ LOW
STEP   RORMP DMAACK AS/   A19-A13      ROM0   ROM1   RAM0   SYNCDT   ZRAM1   ZRAM2   DUART   PERIPH
0000   110         0000000      H   H   L   H   H   H   H   H
0001   110         0000001      H   H   L   H   H   H   H   H
0002   110         0000010      H   H   L   H   H   H   H   H
0003   110         0000011      H   H   L   H   H   H   H   H
0004   110         0000100      H   H   H   L   H   H   H   H
0005   110         0000101      H   H   H   L   H   H   H   H
0006   110         0000110      H   H   H   L   H   H   H   H
0007   110         0000111      H   H   H   L   H   H   H   H
0008   110         0001000      L   H   H   H   H   H   H   H
0009   110         0001001      L   H   H   H   H   H   H   H
0010   110         0001010      L   H   H   H   H   H   H   H
0011   110         0001011      L   H   H   H   H   H   H   H
0012   110         0001100      L   H   H   H   H   H   H   H
0013   110         0001101      L   H   H   H   H   H   H   H
0014   110         0001110      L   H   H   H   H   H   H   H
0015   110         0001111      L   H   H   H   H   H   H   H
0016   110         0010000      H   L   H   H   H   H   H   H
0017   110         0010001      H   L   H   H   H   H   H   H
0018   110         0010010      H   L   H   H   H   H   H   H
0019   110         0010011      H   L   H   H   H   H   H   H
0020   110         0010100      H   L   H   H   H   H   H   H
0021   110         0010101      H   L   H   H   H   H   H   H
0022   110         0010110      H   L   H   H   H   H   H   H
0023   110         0010111      H   L   H   H   H   H   H   H
0024   110         0011000      H   L   H   H   H   H   H   H
0025   110         0011001      H   L   H   H   H   H   H   H
0026   110         0011010      H   L   H   H   H   H   H   H
0027   110         0011011      H   L   H   H   H   H   H   H
0028   110         0011100      H   L   H   H   H   H   H   H
0029   110         0011101      H   L   H   H   H   H   H   H
0030   110         0011110      H   L   H   H   H   H   H   H
0031   110         0011111      H   L   H   H   H   H   H   H
0032   110         0100000      H   H   H   L   H   H   H   H
0033   110         0100001      H   H   H   L   H   H   H   H
0034   110         0100010      H   H   H   L   H   H   H   H
0035   110         0100011      H   H   H   L   H   H   H   H
0036   110         0100100      H   H   H   L   H   H   H   H
0037   110         0100101      H   H   H   L   H   H   H   H
0038   110         0100110      H   H   H   L   H   H   H   H
0039   110         0100111      H   H   H   L   H   H   H   H
0040   110         0101000      H   H   H   L   H   H   H   H
0041   110         0101001      H   H   H   L   H   H   H   H
0042   110         0101010      H   H   H   L   H   H   H   H
0043   110         0101011      H   H   H   L   H   H   H   H
0044   110         0101100      H   H   H   L   H   H   H   H
0045   110         0101101      H   H   H   L   H   H   H   H
0046   110         0101110      H   H   H   L   H   H   H   H
0047   110         0101111      H   H   H   L   H   H   H   H
0048   110         0110000      H   H   H   L   H   H   H   H
0049   110         0110001      H   H   H   L   H   H   H   H
0050   110         0110010      H   H   H   L   H   H   H   H
0051   110         0110011      H   H   H   L   H   H   H   H
0052   110         0110100      H   H   H   L   H   H   H   H
0053   110         0110101      H   H   H   L   H   H   H   H
0054   110         0110110      H   H   H   L   H   H   H   H
0055   110         0110111      H   H   H   L   H   H   H   H
0056   110         0111000      H   H   H   L   H   H   H   H
0057   110         0111001      H   H   H   L   H   H   H   H
0058   110         0111010      H   H   H   L   H   H   H   H
0059   110         0111011      H   H   H   L   H   H   H   H
0060   110         0111100      H   H   H   L   H   H   H   H
0061   110         0111101      H   H   H   L   H   H   H   H
0062   110         0111110      H   H   H   L   H   H   H   H
0063   110         0111111      H   H   H   L   H   H   H   H
0064   110         1000000      H   H   H   L   H   H   H   H
0065   110         1000001      H   H   H   L   H   H   H   H
0066   110         1000010      H   H   H   L   H   H   H   H
0067   110         1000011      H   H   H   L   H   H   H   H
0068   110         1000100      H   H   H   L   H   H   H   H
0069   110         1000101      H   H   H   L   H   H   H   H
0070   110         1000110      H   H   H   L   H   H   H   H
0071   110         1000111      H   H   H   L   H   H   H   H
0072   110         1001000      H   H   H   L   H   H   H   H
0073   110         1001001      H   H   H   L   H   H   H   H
0074   110         1001010      H   H   H   L   H   H   H   H
0075   110         1001011      H   H   H   L   H   H   H   H
0076   110         1001100      H   H   H   L   H   H   H   H
0077   110         1001101      H   H   H   L   H   H   H   H
0078   110         1001110      H   H   H   L   H   H   H   H
0079   110         1001111      H   H   H   L   H   H   H   H
0080   110         1010000      H   H   H   L   H   H   H   H
0081   110         1010001      H   H   H   L   H   H   H   H
0082   110         1010010      H   H   H   L   H   H   H   H
0083   110         1010011      H   H   H   L   H   H   H   H
0084   110         1010100      H   H   H   L   H   H   H   H
0085   110         1010101      H   H   H   L   H   H   H   H
0086   110         1010110      H   H   H   L   H   H   H   H
0087   110         1010111      H   H   H   L   H   H   H   H
0088   110         1011000      H   H   H   L   H   H   H   H
0089   110         1011001      H   H   H   L   H   H   H   H
0090   110         1011010      H   H   H   L   H   H   H   H
0091   110         1011011      H   H   H   L   H   H   H   H
0092   110         1011100      H   H   H   L   H   H   H   H
0093   110         1011101      H   H   H   L   H   H   H   H
0094   110         1011110      H   H   H   L   H   H   H   H
0095   110         1011111      H   H   H   L   H   H   H   H
0096   110         1100000      H   H   H   L   H   H   H   H
0097   110         1100001      H   H   H   L   H   H   H   H
0098   110         1100010      H   H   H   L   H   H   H   H
0099   110         1100011      H   H   H   L   H   H   H   H
0100   110         1100100      H   H   H   L   H   H   H   H
0101   110         1100101      H   H   H   L   H   H   H   H
0102   110         1100110      H   H   H   L   H   H   H   H
0103   110         1100111      H   H   H   L   H   H   H   H
0104   110         1101000      H   H   H   L   H   H   H   H
0105   110         1101001      H   H   H   L   H   H   H   H
0106   110         1101010      H   H   H   L   H   H   H   H
0107   110         1101011      H   H   H   L   H   H   H   H
0108   110         1101100      H   H   H   L   H   H   H   H
0109   110         1101101      H   H   H   L   H   H   H   H
0110   110         1101110      H   H   H   L   H   H   H   H
0111   110         1101111      H   H   H   L   H   H   H   H
0112   110         1110000      H   H   H   L   H   H   H   H
0113   110         1110001      H   H   H   L   H   H   H   H
0114   110         1110010      H   H   H   L   H   H   H   H
0115   110         1110011      H   H   H   L   H   H   H   H
0116   110         1110100      H   H   H   L   H   H   H   H
0117   110         1110101      H   H   H   L   H   H   H   H
0118   110         1110110      H   H   H   L   H   H   H   H
0119   110         1110111      H   H   H   L   H   H   H   H
0120   110         1111000      H   H   H   L   H   H   L   H
0121   110         1111001      H   H   H   H   H   H   H   L
0122   110         1111010      H   H   H   L   H   H   H   H
0123   110         1111011      H   H   H   L   H   H   H   H
0124   110         1111100      H   H   H   L   H   H   H   H
0125   110         1111101      H   H   H   L   H   H   H   H
0126   110         1111110      H   H   H   L   H   H   H   H
0127   110         1111111      H   H   H   L   H   H   H   H
------------Done-------------
Read from the new chip:
0123   110         1111011      H   H   H   H   H   H   H   H
0124   110         1111100      H   H   H   H   H   H   H   H
0125   110         1111101      H   H   H   H   H   H   H   H
0126   110         1111110      H   H   H   H   H   H   H   H
0127   110         1111111      H   H   H   H   H   H   H   H
PostPosted: Thu Sep 23, 2021 4:21 pm
It looks like A5 is irrelevant here so you could collapse these two into one term. Would that help?
Overall though it looks like syncdt is high when address is 00000xx or 0001xxx or 001xxxx or 1111001 - that's only four product terms needed.
PostPosted: Thu Sep 23, 2021 5:11 pm
When I collapsed those two to
  # A0 & !A4 & !A6
the output is still the same.
And yes, thats right for the table I posted, but it is a bit more complicated, because the SYNCDT is a bit different when RORMP is LOW (the whole thing is active LOW) and it is also always LOW (trough the whole table) when AS/ is HIGH (AS indicates that there is a valid address on the input). I can post the other two tables - with AS/ HIGIH and RORMP LOW if it helps.
Anyway, thank you!
PostPosted: Thu Sep 23, 2021 6:36 pm
Welcome, anonyfous! It's possible - maybe even likely - that many of the entries in the recovered truth table are actually don't-cares, because they can't happen or because it makes no difference. In which case, your recovered equations are over-specified, and use more resources. But even if this is so, I can't think of an easy way to make use of it: I think perhaps you'd need to reconstruct a higher level view of what's being accomplished, and make a new design to accomplish the same.
PostPosted: Thu Sep 23, 2021 7:50 pm
Hmm, I think you are right, because a while ago I was able to get it done, both GALs now behave the same when I put them trough the arduino scan, but when I put the newly programmed chip to the Lexicon it throws an bus error. I guess this will be harder than I thought.
PostPosted: Thu Sep 23, 2021 8:02 pm
Anyway here are the tables that I was able to read, the AS/ signal indicates a valid address, so there are only five tables as the rest of the input combinations when the AS/ is HIGH throws the same output as shown in table 1. I am not sure that I undestand what the DMAACK signal does, because it selects (according to table 4 and 5) two memory chips at the same time which doesn't seem right to me, but I have no idea where to go next.
Final PLD:
Name     LEXICON ;
PartNo   00 ;
Date     13.09.2021 ;
Revision 01 ;
Designer  ;
Company  Private ;
Assembly None ;
Location  U24;
Device   g16v8a;
PIN     [1..7] = [ A0 ..6]; /* addresses   */
PIN     16=SYNCDT ;  /* SYNCDT                         */
SYNCDT =
    !A0 & !A1 & !A2 & !A3 & !A4 & RORMP & !AS
  # !A0 & !A1 & !A2 & !A3 & !RORMP & !AS
  # !A0 & !A1 & !A2 & A3 & RORMP & !AS
  # !A0 & !A1 & A2 & !AS
  #  A0 &  A1 & A2 & A3 & !A4 & !A5 & A6 & !AS;
ZRAM1 = !DMAACK & !AS & A0;
U24_ver1.01_updated.txt [23.98 KiB]
Downloaded 75 times
PostPosted: Fri Sep 24, 2021 10:53 am
Maybe I am onto something. When tried to count the addresses the opposite way from 1111111 to 0000000 I have found that the ZRAM outputs are different (ZRAM outs are only active (LOW) when DMAACK input is LOW). I am not sure what that means, but I have found this in the service manual.
The 68008 has an asynchronous bus interface. This means that when the 68008
initiates a bus cycle, it will normally not finish the cycle until it has received
acknowledgment from the addressed device (DTACK/). The Host board contains circuitry to handle a number of device-dependent cases:
Most of the on-board devices are sufficiently fast to issue a DTACK/ on the first
8MHz cycle after data strobe. This creates a psuedo-synchronous cycle with 0
wait states for reads and 1 wait state for writes.
Other devices, specifically the DUART (U20) and the DSP board Slave ZRAM,
will take a longer and indeterminate amount of time to respond. Either case
drives U35 pin 12 high and this in turn will drive U46 pin 12 low on the next edge
of 8MHz. This will hold off DTACK/ until either the DUART acknowledge
(DDTACK/) or the ZRAM acknowledge (DMAACK) is asserted.
As mentioned above, the 68008 suspends processing during a bus cycle until
DTACK/ is asserted. This means the system will hang if DTACK/ does not work
as expected. The 68008 can recover from an unterminated bus cycle (DTACK/
not asserted) if a circuit is provided that drives the BERR/ input low after some
time interval. The BERR/ generator is a 74HC393 (U36) wired as a divide-by-256
counter, and an inverter (U34). When AS/ is asserted at the beginning of a bus
cycle, the counter begins counting 4MHz cycles. If 128 cycles are counted (32
usec) and AS/ is still asserted, pin 6 of the 393 goes high. This is inverted to
generate the BERR/ signal. BERR/ causes the 68008 to begin exception
processing. AS/ is released, which resets U36, clearing the BERR/ signal. In a
normal cycle, AS/ is de-asserted in less than 32 usec and the counter is reset
before BERR/ is asserted.
PostPosted: Thu Dec 08, 2022 5:15 pm
hi, this is interesting.
What lexicon unit is this for?
I'm thinking of reading some GALs on my Quantec QRS/XL effects unit to help out someone with a faulty unit.
From cursory reading i believe you can read 16v8s even with the security bit engaged, you just cannot access the logic matrix.
