I wrote a zero page allocator for Kick Assembler.
geon
Post by geon »
https://github.com/geon/zpallocator/blo ... xample.asm
The idea is to be able to use the zero page for all variables. You allocate a zp address when you need it, and when you are done with it (ie. at the end of the macro/function scope), you deallocate it.
	// BackgroundColor will contain a free zp address.
	.var backgroundColor = allocateZpByte()
	// Do stuff with backgroundColor
	lda #BROWN
	sta backgroundColor
	deallocateZpByte(backgroundColor)
This way, I can write macros and pass arguments by reference without worrying about collisions.
I could use some help to define a couple of ranges of reserved zp addresses. I don't care about basic, so I can use $02-$70 or so without problem, but I might want to use some kernal routines like screen io and the jiffy clock. I'm not sure what other areas of the zp are important.
fachat
Re: I wrote a zero page allocator for Kick Assembler.
Post by fachat »
geon wrote:
https://github.com/geon/zpallocator/blob/master/zpallocator.example.asm
Not sure I understand. It looks like you're allocating at build time, right? How do you handle run time conflicts like one routine reusing the location reserved by another routine but calling each other?
André
geon
Post by geon »
Yes.
For a function, you would need to allocate the address permanently. It works better with macros.
fachat
Post by fachat »
Then don't you use macros in functions?
Did you try to 'simulate' it e.g. with a paper walk through?
Writing up how it works for a few real world test cases helps a great deal in understanding if it really works or where the pitfalls are.
geon
Post by geon »
Actually no. Or rather, I haven't used functions at all so far, just macros.
Yes, I do TDD. I'll have to look at functions.
This sort of thing is easily done at run-time with the 65C816. Functions (subroutines) save the current value of DP (direct page pointer) on the stack, reserve stack space as needed and then point DP to that space. when the function exits it releases the stack space and restores DP to its entry value.
Well done geon, thanks for sharing your creation!
