cjs suggested using "the SW16RB.TXT listing and just trim off the address and data columns at the left." So, I did that, and fixed some of the directives ("DFS"), but I still can't get the damn thing to work. I don't know if I mis-copied something - I proof read it a bunch of times.
There is a "PLA" after A is already pulled off the stack once, after the save routine:
SW16 JSR SAVE16 ;PRESERVE 6502 REG CONTENTS
PLA
STA R15L ;INIT SWEET16 PC
PLA ;FROM RETURN
STA R15H ; ADDRESSAnd what about this bit:
ACC .byte 0
XREG .byte 0
YREG .byte 0
STATUS .byte 0
;-------------------------------I don't know. Any takers?
Jonathan
;* APPLE-II PSEUDO *
;* MACHINE INTERPRETER *
;* COPYRIGHT 1977 *
;* APPLE COMPUTER INC *
;* ALL RIGHTS RESERVED *
;* S. WOZNIAK *
; TITLE "SWEET16 INTERPRETER"
R0L .EQU $0
R0H .EQU $1
R14H .EQU $1D
R15L .EQU $1E
R15H .EQU $1F
SW16PAG .EQU $F7
; SAVE .EQU $FF4A
; RESTORE .EQU $FF3F
.ORG $F689 ;adjust
PLA
PLA ;FROM RETURN
STA R15H ; ADDRESS
SW16B JSR SW16C ;INTERPRET AND EXECUTE
JMP SW16B ;ONE SWEET16 INSTR.
SW16C INC R15L
BNE SW16D ;INCR SWEET16 PC FOR FETCH
INC R15H
SW16D LDA #SW16PAG
PHA ;PUSH ON STACK FOR RTS
LDY #$0
LDA (R15L),Y ;FETCH INSTR
AND #$F ;MASK REG SPECIFICATION
ASL ;DOUBLE FOR TWO BYTE REGISTERS
TAX ;TO X REG FOR INDEXING
LSR
EOR (R15L),Y ;NOW HAVE OPCODE
BEQ TOBR ;IF ZERO THEN NON-REG OP
STX R14H ;INDICATE'PRIOR RESULT REG'
LSR
LSR ;OPCODE*2 TO LSB'S
LSR
TAY ;TO Y REG FOR INDEXING
LDA OPTBL-2,Y ;LOW ORDER ADR BYTE
PHA ;ONTO STACK
RTS ;GOTO REG-OP ROUTINE
TOBR INC R15L
BNE TOBR2 ;INCR PC
INC R15H
TOBR2 LDA BRTBL,X ;LOW ORDER ADR BYTE
PHA ;ONTO STACK FOR NON-REG OP
LDA R14H ;'PRIOR RESULT REG' INDEX
LSR ;PREPARE CARRY FOR BC, BNC.
RTS ;GOTO NON-REG OP ROUTINE
RTNZ PLA ;POP RETURN ADDRESS
PLA
JSR RESTORE16 ;RESTORE 6502 REG CONTENTS
JMP (R15L) ;RETURN TO 6502 CODE VIA PC
SETZ LDA (R15L),Y ;HIGH-ORDER BYTE OF CONSTANT
STA R0H,X
DEY
LDA (R15L),Y ;LOW-ORDER BYTE OF CONSTANT
STA R0L,X
TYA ;Y-REG CONTAINS 1
SEC
ADC R15L ;ADD 2 TO PC
STA R15L
BCC SET2
INC R15H
SET2 RTS
OPTBL .lobyte SET-1 ;1X
BRTBL .lobyte RTN-1 ;0
.lobyte LD-1 ;2X
.lobyte BR-1 ;1
.lobyte ST-1 ;3X
.lobyte BNC-1 ;2
.lobyte LDAT-1 ;4X
.lobyte BC-1 ;3
.lobyte STAT-1 ;5X
.lobyte BP-1 ;4
.lobyte LDDAT-1 ;6X
.lobyte BM-1 ;5
.lobyte STDAT-1 ;7X
.lobyte BZ-1 ;6
.lobyte POP-1 ;8X
.lobyte BNZ-1 ;7
.lobyte STPAT-1 ;9X
.lobyte BM1-1 ;8
.lobyte ADD-1 ;AX
.lobyte BNM1-1 ;9
.lobyte SUB-1 ;BX
.lobyte BK-1 ;A
.lobyte POPD-1 ;CX
.lobyte RS-1 ;B
.lobyte CPR-1 ;DX
.lobyte BS-1 ;C
.lobyte INR-1 ;EX
.lobyte NUL-1 ;D
.lobyte DCR-1 ;FX
.lobyte NUL-1 ;E
.lobyte NUL-1 ;UNUSED
.lobyte NUL-1 ;F
; NB: The code from `SET` must be on a single page.
SET BPL SETZ ;ALWAYS TAKEN
LD LDA R0L,X
BK .EQU *-1
STA R0L
LDA R0H,X ;MOVE RX TO R0
STA R0H
RTS
ST LDA R0L
STA R0L,X ;MOVE R0 TO RX
LDA R0H
STA R0H,X
RTS
STAT LDA R0L
STAT2 STA (R0L,X) ;STORE BYTE INDIRECT
LDY #$0
STAT3 STY R14H ;INDICATE R0 IS RESULT NEG
INR INC R0L,X
BNE INR2 ;INCR RX
INC R0H,X
INR2 RTS
LDAT LDA (R0L,X) ;LOAD INDIRECT (RX)
STA R0L ;TO R0
LDY #$0
STY R0H ;ZERO HIGH-ORDER R0 BYTE
BEQ STAT3 ;ALWAYS TAKEN
POP LDY #$0 ;HIGH ORDER BYTE = 0
BEQ POP2 ;ALWAYS TAKEN
POPD JSR DCR ;DECR RX
LDA (R0L,X) ;POP HIGH ORDER BYTE @RX
TAY ;SAVE IN Y-REG
POP2 JSR DCR ;DECR RX
LDA (R0L,X) ;LOW-ORDER BYTE
STA R0L ;TO R0
STY R0H
POP3 LDY #$0 ;INDICATE R0 AS LAST RESULT REG
STY R14H
RTS
LDDAT JSR LDAT ;LOW-ORDER BYTE TO R0, INCR RX
LDA (R0L,X) ;HIGH-ORDER BYTE TO R0
STA R0H
JMP INR ;INCR RX
STDAT JSR STAT ;STORE INDIRECT LOW-ORDER
LDA R0H ;BYTE AND INCR RX. THEN
STA (R0L,X) ;STORE HIGH-ORDER BYTE.
JMP INR ;INCR RX AND RETURN
STPAT JSR DCR ;DECR RX
LDA R0L
STA (R0L,X) ;STORE R0 LOW BYTE @RX
JMP POP3 ;INDICATE R0 AS LAST RSLT REG
DCR LDA R0L,X
BNE DCR2 ;DECR RX
DEC R0H,X
DCR2 DEC R0L,X
RTS
SUB LDY #$0 ;RESULT TO R0
CPR SEC ;NOTE Y-REG = 13*2 FOR CPR
LDA R0L
SBC R0L,X
STA R0L,Y ;R0-RX TO RY
LDA R0H
SBC R0H,X
SUB2 STA R0H,Y
TYA ;LAST RESULT REG*2
ADC #$0 ;CARRY TO LSB
STA R14H
RTS
ADD LDA R0L
ADC R0L,X
STA R0L ;R0+RX TO R0
LDA R0H
ADC R0H,X
LDY #$0 ;R0 FOR RESULT
BEQ SUB2 ;FINISH ADD
BS LDA R15L ;NOTE X-REG IS 12*2!
JSR STAT2 ;PUSH LOW PC BYTE VIA R12
LDA R15H
JSR STAT2 ;PUSH HIGH-ORDER PC BYTE
BR CLC
BNC BCS BNC2 ;NO CARRY TEST
BR1 LDA (R15L),Y ;DISPLACEMENT BYTE
BPL BR2
DEY
BR2 ADC R15L ;ADD TO PC
STA R15L
TYA
ADC R15H
STA R15H
BNC2 RTS
BC BCS BR
RTS
BP ASL ;DOUBLE RESULT-REG INDEX
LDA R0H,X ;TEST FOR PLUS
BPL BR1 ;BRANCH IF SO
RTS
BM ASL ;DOUBLE RESULT-REG INDEX
TAX
LDA R0H,X ;TEST FOR MINUS
BMI BR1
RTS
BZ ASL ;DOUBLE RESULT-REG INDEX
TAX
LDA R0L,X ;TEST FOR ZERO
ORA R0H,X ;(BOTH BYTES)
BEQ BR1 ;BRANCH IF SO
RTS
BNZ ASL ;DOUBLE RESULT-REG INDEX
TAX
LDA R0L,X ;TEST FOR NON-ZERO
BNE BR1 ;BRANCH IF SO
RTS
BM1 ASL ;DOUBLE RESULT-REG INDEX
TAX
LDA R0L,X ;CHECK BOTH BYTES
AND R0H,X ;FOR $FF (MINUS 1)
EOR #$FF
RTS
BNM1 ASL ;DOUBLE RESULT-REG INDEX
TAX
LDA R0L,X
AND R0H,X ;CHECK BOTH BYTES FOR NO $FF
EOR #$FF
BNE BR1 ;BRANCH IF NOT MINUS 1
NUL RTS
RS LDX #$18 ;12*2 FOR R12 AS STACK POINTER
JSR DCR ;DECR STACK POINTER
LDA (R0L,X) ;POP HIGH RETURN ADDRESS TO PC
STA R15H
JSR DCR ;SAME FOR LOW-ORDER BYTE
LDA (R0L,X)
STA R15L
RTS
RTN JMP RTNZ
ACC .byte 0
XREG .byte 0
YREG .byte 0
STATUS .byte 0
SAVE16
STA ACC
STX XREG
STY YREG
PHP
PLA
STA STATUS
CLD
RTS
RESTORE16
LDA STATUS
PHA
LDA ACC
LDX XREG
LDY YREG
PLP
RTS
