It is currently Sun Nov 24, 2024 10:37 am
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Sat Aug 07, 2021 10:39 pm
To generate manual reset that stretches for the nominal 250ms, the reset button should connect to the VCC terminal of mcp130 and the VCC terminal should connect to 5V supply through a 1K or so current limiting resistor.
In other words, two parts are required to do the work of one. :D
In other words, you get to choose one priority (space saving) or another (cost saving), according to prevailing circumstances.
PostPosted: Sat Aug 07, 2021 11:46 pm
OR...I can turn a deficit into a "feature": :D
I can connect the reset button directly to the reset line and have the option of either a debounced, 250mS long reset or a not debounced, not stretched reset. Why do I want a bouncy but deterministic reset? Because there is a tiny delay between the release of master reset and when a CF disk starts accessing its disk content. Some of my bootstrap-via-CF approach exploits that delay to hijack the bootstrapping to an alternative boot method. One of those "hit a key immediately after releasing reset" trick...
PostPosted: Sun Aug 08, 2021 12:56 am
Would you like fries with your burger, sir? :D
The cost vs. space dichotomy seems to be unavoidable everywhere one goes.
Users browsing this forum: No registered users and 51 guests
cron
