The LCD is connected for 4-bit mode to VIA1 Port A 0 through 5
V1A0 - D4
V1A1 - D5
V1A2 - D6
V1A3 - D7
V1A4 - RS
V1A5 - EN
.setcpu "6502"
VIA1_ORB = $B100
VIA1_ORA = $B101
VIA1_DDRB = $B102
VIA1_DDRA = $B103
.segment "VECTORS"
.word nmi
.word reset
.word irq
.zeropage
tmp1: .byte $00
.code
reset: jmp main
nmi: rti
irq: rti
main: jsr reset_lcd
ldx #$0
loop: lda hello,x
beq hold
jsr send_lcd_data
inx
jmp loop
hold: jmp hold
send_lcd_nibble:
; XD XD EN RS D7 D6 D5 D4
; write the nibble
sta VIA1_ORA
ora #%00100000 ; Turn on enable pin
sta VIA1_ORA
AND #%11011111 ; Turn off enable pin
sta VIA1_ORA
RTS
send_lcd_instr:
pha
lsr A
lsr A
lsr A
lsr A
jsr send_lcd_nibble
PLA
AND #%00001111
JMP send_lcd_nibble
send_lcd_data:
pha
LSR A
LSR A
LSR A
LSR A
ora #%00010000
JSR send_lcd_nibble
PLA
AND #%00001111
ORA #%00010000
jmp send_lcd_nibble
reset_lcd:
lda #$FF
sta VIA1_DDRA
lda #$00
sta VIA1_ORA
lda #50
jsr _delay_ms
lda #$03 ;0011 - Do Setup
sta VIA1_ORA
ldx #$23 ;100011 - Same value, but with enable
stx VIA1_ORA ; Do the Enable
sta VIA1_ORA ; Send again without enable
lda #50
jsr _delay_ms
ldx #$23
stx VIA1_ORA ; with enable
lda #$03
sta VIA1_ORA ; wihtout enable
lda #50
jsr _delay_ms
ldx #$23
lda #$03
lda #50
jsr _delay_ms
lda #$02
sta VIA1_ORA ; 4 - bit address (0010),
ldx #$22 ;
stx VIA1_ORA ; 4 - bit address (with enable)
sta VIA1_ORA ; 4 - bit address (no enable)
lda #$2B
jsr send_lcd_instr ; two line display, 5x10 font
lda #$0C
jsr send_lcd_instr ; Display on, no cursur, no blink
lda #$01
jsr send_lcd_instr ; Clear the screen
lda #$06
sta send_lcd_instr ;
lda #$02
rts
; stole this from somewhere, it's hardcoded for 1MHz
_delay_ms: sta tmp1 ; 3
txa ; 2
pha ; 3
tya ; 2
pha ; 3
ldx tmp1 ; 3
ldy #190 ; 2
@loop1: dey ; 190 * 2
bne @loop1 ; 190 * 3 - 1
@loop2: dex ; 2
beq @return ; (x - 1) * 2 + 3
nop ; 2
ldy #198 ; 2
@loop3: dey ; 198 * 2
bne @loop3 ; 198 * 3 - 1
jmp @loop2 ; 3
@return: pla ; 4
tay ; 2
pla ; 4
tax ; 2
lda tmp1 ; 3
rts ; 6 (+ 6 for JSR)
hello: .byte "Hello, World!",$00
