From what I can tell from reading the data sheet (https://www.lcd-module.de/eng/pdf/zubeh ... hinese.pdf) each data frame consists of 3 bytes:
1.) Sync bit - 5 1's followed by RW, RS and an additional zero to complete the byte (last 3 are 0's in my case)
2.) Most significant nibble followed by 4 0's
3.) Least significant nibble followed by 4 0's
I have my LCD hooked up like this:
VCC -> Connect to 5V
GND -> Connect to GND
RS -> Connect to 5V
RW (MOSI) -> VIA PA0
E (CLOCK) -> VIA PA1
PSB -> Connect to GND
RST -> Connect to 5V
A (or BLA) -> Connect to 5V
K (or BLK) -> Connect to GND
Here is the code I'm using to send a SPI byte:
SYNC_START = %00000010
lcd_spi_send:
stz PORTA
; Step 1.) send 5 1s
ldx #5
ldy #SYNC_START
sty PORTA
@startsync:
; pulse clock 5 times
inc PORTA
dec PORTA
dex
bne @startsync
; Step 2.) send 3 0s
; RW, RS, and extra 0
; to round out byte
stz PORTA
ldx #3
@endbits:
; pulse clock 3 times
inc PORTA
dec PORTA
dex
bne @endbits
; Step 3.) first nibble
ldy #00000010 ; constant for mosi high
ldx #4
@nibble_1:
asl A ; put bit into carry
bcs @mosi_1_1
stz PORTA ; clock = 0, mosi = 0
inc PORTA ; pulse clock
dec PORTA
jmp @dec_1
@mosi_1_1:
sty PORTA ; clock = 0, mosi = 1
dec PORTA
@dec_1:
dex
bne @nibble_1
; Step 4.) 4 sync bits
stz PORTA
ldx #4
@sync_bits_1:
inc PORTA
dec PORTA
dex
bne @sync_bits_1
; Step 5.) second nibble
ldx #4
@nibble_2:
bcs @mosi_1_2
dec PORTA
jmp @dec_2
@mosi_1_2:
dec PORTA
@dec_2:
dex
bne @nibble_2
; Step 6.) 4 sync bits
stz PORTA
ldx #4
@sync_bits_2:
inc PORTA
dec PORTA
dex
bne @sync_bits_2
rts
lda #%11111111 ; PORT A to output
sta DDRA
; Basic function mode
lda #%00110000
jsr lcd_spi_send
jsr delay
; clear screen
lda #%00000001
jsr lcd_spi_send
jsr delay
; entry mode set
lda #%00000110
jsr lcd_spi_send
jsr delay
; display control
lda #%00001100
jsr lcd_spi_send
jsr delay
lda #%00000010
jsr lcd_spi_send
jsr delay
delay:
ldy #$ff
ldx #$ff
@loop:
dex
bne @loop
dey
bne @loop
rts
