Working SBC-3
I've finished my SBC-3 finally. It powers up and I can type commands into the monitor, but I can't XMODEM in either direction! It just gives ''Transfer error!" and a register dump. I'm using the default settings of 9600/8n1 but have also tried taking it down to 2400/8n1. I think the parameters are correct though, as a message to start sending and a bunch of C's come up on the terminal.
Edit: Bah. I've already read this somewhere when I took account of it in my own 6502 SBC. It's Tera Term repeating the first packet.
Started Assembly
Daryl & the Group,
I finally got up my courage to start assembly following the guidelines, especially the SMT advice. I must admit that this was my first real attempt at SMT soldering.
The guidelines are great. I used a ton of flux, a very small chisel point on my iron, and small diameter solder (it did have a core). The other item I found essential was Solder-Wick (the real stuff not the Radio Shack version). With a strong light and magnifying helmet it was just a matter of a little patience.
IC2 was tough but after I thought I was done I cleaned the fux off the board and did a close insopection. I think everything is good but the proof of the poudding will come later when I power it up after adding everything else.
After IC2, IC5 was easy.
I have mounted C18 & C19 on the bottom and trimmed the leads as tight as possible. The IC4 socket fits OK with that approach without having to drill any holes in it.
I have a lot more to add and then the testing will be critical but I am happy with my progress and especially the IC2 & IC5 results.
Rich
Rich
Rich Leary
On the SBC, press "U" <enter>
The teraterm window should show a prompt and a series of "C"'s.
Click File -> Transfer -> XMODEM ->SEND
Select the file to send from the PC to the SBC. It should have the starting address as the first two bytes. Be sure not to overwrite the Monitor code in upper block 0.
Under the file selection are three bubbles: Checksum, CRC, and 1K. The bubble should be on CRC. Now click OPEN and the file should be transferred.
To copy a file to a block other than 0, type the <block #>U<Enter>,
For example, 02U<Enter> will load a file into block 2.
For instance, upload the yosemite.bin (found to the tools folder of the support file) to block 2. Then type 00030:2<enter> to see the image. type (blindly) 00030:1<enter> to return to the text page.
Hope this helps!
If not, you can email me for more help.
I wrote:
The xmodemsend command is not mapped into the monitor's command set. I did a quick test and was able to send a file, however, it did not work as designed and I'll need to further test it.
Add that to the list of things to re-check.
Up!
I finished my SBC-3.1 and it is working. I still need to test the XMODEM transfers but I suspect that will not be a problem.
So far only used a monochrome monitor. Will try a color one soon.
I had one momentary concern when I could not get the > prompt. Turns out I had not installed the two jumpers between the VIA chips. Once I did that following the picture of Daryl's board all was well.
Rich
Rich
Rich Leary
Re: Up!
RichLeary wrote:
... I had one momentary concern when I could not get the > prompt. Turns out I had not installed the two jumpers between the VIA chips. Once I did that following the picture of Daryl's board all was well.
Thanks for pointing that out. I did overlook the instructions for placing the jumpers. I'll get those update tomorrow as well.
thanks
Keyboard
Daryl,
I have noticed something strange with keyboards. I have four PS2 keyboards including two brand new Microsoft 500 keyboards. The Microsoft keyboards do not work withy the SBC3. The NUM LOCK light does not come on and there is no response to any key.
I also tested a Kensington keyboard but since that one used a USB to PS2 adapter I was not too surprised when it did not work.
The one that I have that works is an older Dell keyboard. I also have a newer HP keyboard but have not tested it yet.
Any thoughts?
Rich
Any thoughts?
Rich
Rich Leary
Heat Sink
All,
One tip I meant to post when I first finished by SBC3 was one regarding the heatsink. I mounted mine so the fins were on the outside of the board. That eliminated any conflict with the caps and might actually improve cooling air flow.
That does restrict mounting but since the power plug sticks out on the same side it did not seem like a big restriction.
Rich
Rich
Rich Leary
Re: Keyboard
RichLeary wrote:
Daryl,
Any thoughts?
Rich
Any thoughts?
Rich
Here are some possible thoughts:
It could be timing related. However, as I remember, the keyboard clocks at the 10-30 khz rate so that should not really be an issue for a 8MHz microcontroller.
Its also possible that the keyboards are defaulting to something other than scan-code set 2, which I believe is the usual default.
Here is a link to a helpful website.
http://www.beyondlogic.org/keyboard/key ... ?the_id=16
Now, in order to figure this out, you would have to use another medium to communicate with the keyboard to determ what is being sent. I wrote a simple program to interface a pc keyboard through a 6522. You could use that on your SBC-2 along with the simple circuit (see the IO section of my website) to try to figure it out.
Alternatively, if you want to send me one, I can do the same and try to figure out the problem.
